[Geoserver-users] GDAL_GRID Function in Geoerver or GeoTools
Hi All,
   How can i use GDAL_GRID gdal function in geoserver or geotools.
   I need to use IDW interpolation technique.
Thanks ..
View this message in context: http://osgeo-org.1560.x6.nabble.com/GDAL-GRID-Function-in-Geoerver-or-GeoTools-tp5275299.html
Does Any body use GDAL library in Geoserver ??
  Or there is another way to do IDW interpolation in geoesrver.
View this message in context: http://osgeo-org.1560.x6.nabble.com/GDAL-GRID-Function-in-Geoerver-or-GeoTools-tp5275299p5275675.html
It is commonly used for data import:
http://docs.geoserver.org/stable/en/user/data/raster/gdal.html
It is also used in some export extensions.
I don't know. I have seen you ask this question quite a few times - if
anyone knew the answer, I think you would have a response by now. If it is
that important to you, perhaps a commercial support option might be worth
investigating.
Brad
