Ok. There was a misunderstanding then: I was thinking that you were
referring to the GDAL lib you have installed for GeoServer from ImageIO-EXT
since you didn't specified any version. Sorry about that.
That could be the problem instead.
Checking back your configs:
*From:* dany.geotools@anonymised.com [mailto:dany.geotools@anonymised.com] *On
Behalf Of *Daniele Romagnoli
*Sent:* Tuesday, April 5, 2016 2:37 PM
*To:* Керимкулов Жандос Сеитович
*Cc:* geoserver-users@lists.sourceforge.net
*Subject:* Re: [Geoserver-users] GDAL native lib error during instaling
to version 2.8.2
Hi Zhandos,
please read below...
On Tue, Apr 5, 2016 at 6:52 AM, zh.kerimkulov@anonymised.com <
zh.kerimkulov@anonymised.com> wrote:
Hi Daniele
Thanks for your tips and support.
Next my comments to your questions.
*1.* *I tried to run gdalinfo with param –formats so I got next*
root@anonymised.com:/var/lib/tomcat7/webapps/geoserver/gdal192# gdalinfo
--formats
*Supported Formats:*
* VRT -raster- (rw+v): Virtual Raster*
* GTiff -raster- (rw+vs): GeoTIFF*
* NITF -raster- (rw+vs): National Imagery Transmission Format*
* RPFTOC -raster- (rovs): Raster Product Format TOC format*
* ECRGTOC -raster- (rovs): ECRG TOC format*
* HFA -raster- (rw+v): Erdas Imagine Images (.img)*
* SAR_CEOS -raster- (rov): CEOS SAR Image*
* CEOS -raster- (rov): CEOS Image*
* JAXAPALSAR -raster- (rov): JAXA PALSAR Product Reader (Level 1.1/1.5)*
* GFF -raster- (rov): Ground-based SAR Applications Testbed File Format
(.gff)*
* ELAS -raster- (rw+v): ELAS*
* AIG -raster- (rov): Arc/Info Binary Grid*
* AAIGrid -raster- (rwv): Arc/Info ASCII Grid*
* GRASSASCIIGrid -raster- (rov): GRASS ASCII Grid*
* SDTS -raster- (rov): SDTS Raster*
* OGDI -raster- (ros): OGDI Bridge*
* DTED -raster- (rwv): DTED Elevation Raster*
* PNG -raster- (rwv): Portable Network Graphics*
* JPEG -raster- (rwv): JPEG JFIF*
* MEM -raster- (rw+): In Memory Raster*
* JDEM -raster- (rov): Japanese DEM (.mem)*
* GIF -raster- (rwv): Graphics Interchange Format (.gif)*
* BIGGIF -raster- (rov): Graphics Interchange Format (.gif)*
* ESAT -raster- (rov): Envisat Image Format*
* BSB -raster- (rov): Maptech BSB Nautical Charts*
* XPM -raster- (rwv): X11 PixMap Format*
* BMP -raster- (rw+v): MS Windows Device Independent Bitmap*
* DIMAP -raster- (rov): SPOT DIMAP*
* AirSAR -raster- (rov): AirSAR Polarimetric Image*
* RS2 -raster- (ros): RadarSat 2 XML Product*
* PCIDSK -raster,vector- (rw+v): PCIDSK Database File*
* PCRaster -raster- (rw+): PCRaster Raster File*
* ILWIS -raster- (rw+v): ILWIS Raster Map*
* SGI -raster- (rw+): SGI Image File Format 1.0*
* SRTMHGT -raster- (rwv): SRTMHGT File Format*
* Leveller -raster- (rw+): Leveller heightfield*
* Terragen -raster- (rw+): Terragen heightfield*
* GMT -raster- (rw): GMT NetCDF Grid Format*
* netCDF -raster- (rw+s): Network Common Data Format*
* HDF4 -raster- (ros): Hierarchical Data Format Release 4*
* HDF4Image -raster- (rw+): HDF4 Dataset*
* ISIS3 -raster- (rov): USGS Astrogeology ISIS cube (Version 3)*
* ISIS2 -raster- (rw+v): USGS Astrogeology ISIS cube (Version 2)*
* PDS -raster- (rov): NASA Planetary Data System*
* VICAR -raster- (rov): MIPL VICAR file*
* TIL -raster- (rov): EarthWatch .TIL*
* ERS -raster- (rw+v): ERMapper .ers Labelled*
* L1B -raster- (rovs): NOAA Polar Orbiter Level 1b Data Set*
* FIT -raster- (rwv): FIT Image*
* GRIB -raster- (rov): GRIdded Binary (.grb)*
* JPEG2000 -raster,vector- (rwv): JPEG-2000 part 1 (ISO/IEC 15444-1),
based on Jasper library*
* RMF -raster- (rw+v): Raster Matrix Format*
* MSGN -raster- (ro): EUMETSAT Archive native (.nat)*
* RST -raster- (rw+v): Idrisi Raster A.1*
* INGR -raster- (rw+v): Intergraph Raster*
* GSAG -raster- (rwv): Golden Software ASCII Grid (.grd)*
* GSBG -raster- (rw+v): Golden Software Binary Grid (.grd)*
* GS7BG -raster- (rw+v): Golden Software 7 Binary Grid (.grd)*
* COSAR -raster- (rov): COSAR Annotated Binary Matrix (TerraSAR-X)*
* TSX -raster- (rov): TerraSAR-X Product*
* COASP -raster- (ro): DRDC COASP SAR Processor Raster*
* R -raster- (rwv): R Object Data Store*
* MAP -raster- (rov): OziExplorer .MAP*
* PNM -raster- (rw+v): Portable Pixmap Format (netpbm)*
* DOQ1 -raster- (rov): USGS DOQ (Old Style)*
* DOQ2 -raster- (rov): USGS DOQ (New Style)*
* ENVI -raster- (rw+v): ENVI .hdr Labelled*
* EHdr -raster- (rw+v): ESRI .hdr Labelled*
* GenBin -raster- (rov): Generic Binary (.hdr Labelled)*
* PAux -raster- (rw+): PCI .aux Labelled*
* MFF -raster- (rw+v): Vexcel MFF Raster*
* MFF2 -raster- (rw+): Vexcel MFF2 (HKV) Raster*
* FujiBAS -raster- (ro): Fuji BAS Scanner Image*
* GSC -raster- (rov): GSC Geogrid*
* FAST -raster- (rov): EOSAT FAST Format*
* BT -raster- (rw+v): VTP .bt (Binary Terrain) 1.3 Format*
* LAN -raster- (rw+v): Erdas .LAN/.GIS*
* CPG -raster- (ro): Convair PolGASP*
* IDA -raster- (rw+v): Image Data and Analysis*
* NDF -raster- (rov): NLAPS Data Format*
* EIR -raster- (rov): Erdas Imagine Raw*
* DIPEx -raster- (rov): DIPEx*
* LCP -raster- (rwv): FARSITE v.4 Landscape File (.lcp)*
* GTX -raster- (rw+v): NOAA Vertical Datum .GTX*
* LOSLAS -raster- (rov): NADCON .los/.las Datum Grid Shift*
* NTv2 -raster- (rw+vs): NTv2 Datum Grid Shift*
* CTable2 -raster- (rw+v): CTable2 Datum Grid Shift*
* ACE2 -raster- (rov): ACE2*
* SNODAS -raster- (rov): Snow Data Assimilation System*
* KRO -raster- (rw+v): KOLOR Raw*
* ROI_PAC -raster- (rw+v): ROI_PAC raster*
* ARG -raster- (rwv): Azavea Raster Grid format*
* RIK -raster- (rov): Swedish Grid RIK (.rik)*
* USGSDEM -raster- (rwv): USGS Optional ASCII DEM (and CDED)*
* GXF -raster- (ro): GeoSoft Grid Exchange Format*
* BAG -raster- (ro): Bathymetry Attributed Grid*
* HDF5 -raster- (ros): Hierarchical Data Format Release 5*
* HDF5Image -raster- (ro): HDF5 Dataset*
* NWT_GRD -raster- (rov): Northwood Numeric Grid Format .grd/.tab*
* NWT_GRC -raster- (rov): Northwood Classified Grid Format .grc/.tab*
* ADRG -raster- (rw+vs): ARC Digitized Raster Graphics*
* SRP -raster- (rovs): Standard Raster Product (ASRP/USRP)*
* BLX -raster- (rw): Magellan topo (.blx)*
* Rasterlite -raster- (rws): Rasterlite*
* PostGISRaster -raster- (rws): PostGIS Raster driver*
* SAGA -raster- (rw+v): SAGA GIS Binary Grid (.sdat)*
* KMLSUPEROVERLAY -raster- (rwv): Kml Super Overlay*
* XYZ -raster- (rwv): ASCII Gridded XYZ*
* HF2 -raster- (rwv): HF2/HFZ heightfield raster*
* PDF -raster,vector- (w+): Geospatial PDF*
* OZI -raster- (rov): OziExplorer Image File*
* CTG -raster- (rov): USGS LULC Composite Theme Grid*
* E00GRID -raster- (rov): Arc/Info Export E00 GRID*
* ZMap -raster- (rwv): ZMap Plus Grid*
* NGSGEOID -raster- (rov): NOAA NGS Geoid Height Grids*
* MBTiles -raster- (rov): MBTiles*
* IRIS -raster- (rov): IRIS data (.PPI, .CAPPi etc)*
* GPKG -raster,vector- (rw+vs): GeoPackage*
The list of available formats looks really long to me. It seems like there
is another GDAL installation around on your machine which is used instead
of the downloaded one. (Could you try a "locate gdalinfo" command?)
I would use the gdalinfo.sh you can find within the *javainfo* folder
instead.
*2.* *I have configured the LD_LIBRARY_PATH with next commands*
*export LD_LIBRARY_PATH=/var/lib/tomcat7/webapps/geoserver/gdal192/*
*export PATH=$PATH:/var/lib/tomcat7/webapps/geoserver/gdal192/*
*export GDAL_DATA=/var/lib/tomcat7/webapps/geoserver/gdal-data/*
*3.* *The report what "ls -ls
/var/lib/tomcat7/webapps/geoserver/gdal192/" returns is:*
56 -rwxrwxrwx 1 tomcat7 odmin 54931 dec 10 2012 gdalinfo
4 drwxrwxrwx 2 tomcat7 odmin 4096 march 24 09:26 javainfo
112 -rwxrwxrwx 1 tomcat7 odmin 112705 nov. 22 2012 libgdalconstjni.so
1284 -rwxrwxrwx 1 tomcat7 odmin 1312184 nov. 22 2012 libgdaljni.so
4 -rwxrwxrwx 1 tomcat7 odmin 17 nov. 22 2012 libgdal.so
4 -rwxrwxrwx 1 tomcat7 odmin 17 nov. 22 2012 libgdal.so.1
43016 -rwxrwxrwx 1 tomcat7 odmin 44048076 nov. 22 2012 libgdal.so.1.16.2
4960 -rwxrwxrwx 1 tomcat7 odmin 5078163 nov. 26 2012 libltidsdk.so
4 -rwxrwxrwx 1 tomcat7 odmin 19 nov. 22 2012 libNCSCnet.so
4 -rwxrwxrwx 1 tomcat7 odmin 19 nov. 22 2012 libNCSCnet.so.0
580 -rwxrwxrwx 1 tomcat7 odmin 590457 nov. 22 2012
libNCSCnet.so.0.0.0
4 -rwxrwxrwx 1 tomcat7 odmin 19 nov. 22 2012 libNCSEcwC.so
4 -rwxrwxrwx 1 tomcat7 odmin 19 nov. 22 2012 libNCSEcwC.so.0
80 -rwxrwxrwx 1 tomcat7 odmin 81508 nov. 22 2012
libNCSEcwC.so.0.0.0
4 -rwxrwxrwx 1 tomcat7 odmin 18 nov. 22 2012 libNCSEcw.so
4 -rwxrwxrwx 1 tomcat7 odmin 18 nov. 22 2012 libNCSEcw.so.0
8444 -rwxrwxrwx 1 tomcat7 odmin 8644546 nov. 22 2012 libNCSEcw.so.0.0.0
4 -rwxrwxrwx 1 tomcat7 odmin 19 nov. 22 2012 libNCSUtil.so
4 -rwxrwxrwx 1 tomcat7 odmin 19 nov. 22 2012 libNCSUtil.so.0
700 -rwxrwxrwx 1 tomcat7 odmin 713782 nov. 22 2012
libNCSUtil.so.0.0.0
596 -rwxrwxrwx 1 tomcat7 odmin 608641 nov. 22 2012 libogrjni.so
464 -rwxrwxrwx 1 tomcat7 odmin 472066 nov. 22 2012 libosrjni.so
I don't see symbolic links in this output. How did you extract the tar.gz
on your disk?
Using the archive manager or the "tar -zxvf" command should preserve the
links so that your output should be similar to something like this:
4.0K drwxrwxr-x 2 dromagno dromagno 4.0K Mar 21 2013 javainfo
92K -rwxr-xr-x 1 dromagno dromagno 92K Dec 10 2012 libgdalconstjni.so
916K -rwxr-xr-x 1 dromagno dromagno 915K Dec 10 2012 libgdaljni.so
436K -rwxr-xr-x 1 dromagno dromagno 436K Dec 10 2012 libogrjni.so
340K -rwxr-xr-x 1 dromagno dromagno 339K Dec 10 2012 libosrjni.so
48K -rwxr-xr-x 1 dromagno dromagno 45K Dec 10 2012 gdalinfo
4.8M -rwxr-xr-x 1 dromagno dromagno 4.8M Dec 10 2012 libltidsdk.so
0 lrwxrwxrwx 1 dromagno dromagno 17 Dec 10 2012 *libgdal.so ->
libgdal.so.1.16.2*
0 lrwxrwxrwx 1 dromagno dromagno 17 Dec 10 2012 *libgdal.so.1 ->
libgdal.so.1.16.2*
34M -rwxr-xr-x 1 dromagno dromagno 34M Dec 10 2012 libgdal.so.1.16.2
0 lrwxrwxrwx 1 dromagno dromagno 19 Dec 10 2012 *libNCSCnet.so ->
libNCSCnet.so.0.0.0*
0 lrwxrwxrwx 1 dromagno dromagno 19 Dec 10 2012 *libNCSCnet.so.0 ->
456K -rwxr-xr-x 1 dromagno dromagno 456K Dec 10 2012 libNCSCnet.so.0.0.0
0 lrwxrwxrwx 1 dromagno dromagno 19 Dec 10 2012 *libNCSEcwC.so ->
libNCSEcwC.so.0.0.0*
0 lrwxrwxrwx 1 dromagno dromagno 19 Dec 10 2012 *libNCSEcwC.so.0 ->
76K -rwxr-xr-x 1 dromagno dromagno 73K Dec 10 2012 libNCSEcwC.so.0.0.0
0 lrwxrwxrwx 1 dromagno dromagno 18 Dec 10 2012 *libNCSEcw.so ->
libNCSEcw.so.0.0.0*
0 lrwxrwxrwx 1 dromagno dromagno 18 Dec 10 2012 *libNCSEcw.so.0 ->
libNCSEcw.so.0.0.0*
6.9M -rwxr-xr-x 1 dromagno dromagno 6.8M Dec 10 2012 libNCSEcw.so.0.0.0
0 lrwxrwxrwx 1 dromagno dromagno 19 Dec 10 2012 *libNCSUtil.so ->
libNCSUtil.so.0.0.0*
0 lrwxrwxrwx 1 dromagno dromagno 19 Dec 10 2012 *libNCSUtil.so.0 ->
580K -rwxr-xr-x 1 dromagno dromagno 579K Dec 10 2012 libNCSUtil.so.0.0.0
Note the symbolic links (I have marked them in bold).
Could you double check?
Hope this helps.
Daniele
*Sent:* Monday, April 4, 2016 6:38 PM
*To:* Керимкулов Жандос Сеитович; geoserver-users@lists.sourceforge.net
to version 2.8.2
Hi Zandos,
please keep the list on CC so that other users can provide their feedbacks
as well as retrieve information from the discussion in the future, though
search.
On Mon, Apr 4, 2016 at 2:26 PM, zh.kerimkulov@anonymised.com <
*Sent:* Monday, April 4, 2016 5:08 PM
to version 2.8.2
Hi Zandos,
thanks for having moved the discussion from JIRA to this list.
On Mon, Apr 4, 2016 at 12:18 PM, zh.kerimkulov@anonymised.com <
Hi there
During installation GDAL Image formats by
http://docs.geoserver.org/latest/en/user/data/raster/gdal.html i had next
errors on tomcat 7 logs.
24, 2016 10:55:50 AM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
WARNING: Failed to load the GDAL native libs. This is not a problem unless you need to use the GDAL plugins: they won't be enabled.
java.lang.UnsatisfiedLinkError: no gdaljni in java.library.path
This is the warning stating GeoServer (through GeoTools) is unable to load
your native libs.
I test it by bash gdalinfo.sh which has next code
#!/bin/bash
input=$1
export LD_LIBRARY_PATH=..:$LD_LIBRARY_PATH
CLASSPATH=imageio-ext-gdal-bindings-1.9.2.jar:.
java -classpath "${CLASSPATH}" gdalinfo $input
Which command did you executed?
Did you run "gdalinfo --formats" as suggested in the doc?
I downloaded GDAL192-Ubuntu12 –gcc4.6.3-x86-64.tar and inside
/gdal192/javainfo there is gdalinfo.sh script file.
Yep, what I was meaning is which options/params did you used with
"gdalinfo"? (as an instance: gdalinfo --formats)
So it give's me next error log
Native library load failed.
java.lang.UnsatisfiedLinkError: /var/lib/tomcat7/webapps/geoserver/gdal192/libgdaljni.so: ../libgdal.so.1: file too small
Exception in thread "main" java.lang.UnsatisfiedLinkError: org.gdal.gdal.gdalJNI.AllRegister()V
at org.gdal.gdal.gdalJNI.AllRegister(Native Method)
at org.gdal.gdal.gdal.AllRegister(gdal.java:475)
at gdalinfo.main(gdalinfo.java:87)
Could you please report how did you configured the LD_LIBRARY_PATH or your
tomcat scripts ?
Yes, of course, this is result of my echo command
echo $LD_LIBRARY_PATH
echo $GDAL_DATA
Do you have any chance to report what "ls -ls
/var/lib/tomcat7/webapps/geoserver/gdal192/" returns?
Daniele
I am using Geoserver 2.8.2 on Ubuntu 14.04 and with installed GDAL on my
server.
In Image IO-Ext download link
http://demo.geo-solutions.it/share/github/imageio-ext/releases/1.1.X/1.1.12/ native
libs available only for Ubuntu 12.04 version,
Note that this specific download should be installed on Ubuntu 12.04
version.
There is no guarantee that they would work on a 14.04 version of Ubuntu
(there may be conflict with dependency libraries, resulting into loading,
linking incompatibilities).
I would take a look to this discussion:
http://osgeo-org.1560.x6.nabble.com/Failed-to-load-the-GDAL-native-libs-GDAL-PLUGIN-cannot-be-enabled-td5222384.html
which covers the same topic.
Also 1 strange thing that this libs crash my current image mosaic layer.
What do you mean? Can you provide some more details on this?
Where I can find proper native libs?
See the link I provided above.
Please, let us know if you still have issues.
Daniele
Zhandos
Geoserver-users mailing list
Ing. Daniele Romagnoli
Senior Software Engineer
Via di Montramito 3/A
