[Geoserver-users] GDAL-Support for geoserver 2.7.0
I tried to install the GDAL plugin into geoserver 2.7.0.
The server Windows 2008 R2 64bit has the MVC++ 2010 64bit and MVC++ 2005 32bit and 64bit installed.
The installed packages are
  • geoserver-2.7.0-gdal-plugin.zip
    All jars copied to geoserver/WEB-INF/lib
  • gdal-data.zip
    Unziped to folder and GDAL_DATA environment variable set pointing to the folder
  • gdal-19-1600-x64-mrsid.msi
    Installed on server
  • gdal-19-1600-x64-ecw.msi
    Installed on server
  • GeoServer restarted
Unfortunately the needed MrSID datastore is not available. In the log I found the following:
2015-05-06 10:11:00,230 DEBUG [gce.arcgrid] - ArcGridFormatFactory is availaible.
2015-05-06 10:11:00,230 DEBUG [gdal.envihdr] - EnviHdrFormatFactory is not availaible.
2015-05-06 10:11:00,262 DEBUG [gdal.jp2ecw] - JP2ECWFormatFactory is not availaible.
2015-05-06 10:11:00,262 DEBUG [gdal.jp2mrisd] - JP2MrSIDFormatFactory is not availaible.
2015-05-06 10:11:00,262 DEBUG [gdal.ehdr] - EsriHdrFormatFactory is not availaible.
2015-05-06 10:11:00,262 DEBUG [gdal.dted] - DTEDFormatFactory is not availaible.
2015-05-06 10:11:00,262 DEBUG [gdal.mrsid] - MrSIDFormatFactory is not availaible.
2015-05-06 10:11:00,262 DEBUG [gdal.rpftoc] - RPFTOCFormatFactory is not availaible.
2015-05-06 10:11:00,262 DEBUG [gdal.ecw] - ECWFormatFactory is not availaible.
2015-05-06 10:11:00,262 DEBUG [gdal.nitf] - NITFFormatFactory is not availaible.
2015-05-06 10:11:00,262 DEBUG [gdal.erdasimg] - ErdasImgFormatFactory is not availaible.
2015-05-06 10:11:00,262 DEBUG [gdal.jp2k] - JP2KFormatFactory is not availaible.
How can I found out what’s going wrong?
Yours Rüdiger
Dear Ruediger,
from your packages installation list it seems to me that you have only installed the MrSID and ECW plugins but you didn’t install the GDAL core library.
Note that MrSID and ECW msi installers simply add 2 drivers to the main GDAL installation.
Quoting from GISInternals (I think you downloaded libs from there)
gdal-19-1600-x64-ecw.msi Installer for the GDAL ECW plugin (must be installed to the same directory as the GDAL core)
gdal-19-1600-x64-mrsid.msi Installer for the GDAL MrSID plugin (must be installed to the same directory as the GDAL core)
Therefore, you need to install the GDAL core binaries too.
Hope this helps.
Daniele
On Wed, May 6, 2015 at 11:05 AM, Gubler, Ruediger <rgubler@anonymised.com> wrote:
  • gdal-data.zip
    Installed on server
    Installed on server
Yours Rüdiger
One dashboard for servers and applications across Physical-Virtual-Cloud
Widest out-of-the-box monitoring support with 50+ applications
Performance metrics, stats and reports that give you Actionable Insights
Deep dive visibility with transaction tracing using APM Insight.
http://ad.doubleclick.net/ddm/clk/290420510;117567292;y
Geoserver-users mailing list
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
Have you set the environment variables GDAL_DRIVER_PATH and GDAL_DATA?
Mine look like
From: Gubler, Ruediger [mailto:rgubler@anonymised.com]
Sent: Wednesday, May 06, 2015 5:06 AM
To: ‘geoserver-users@lists.sourceforge.net’
Subject: [Geoserver-users] GDAL-Support for geoserver 2.7.0
  • gdal-data.zip
Installed on server
Installed on server
Yours Rüdiger
Yes, that variables are configured on my system.
The “gdalinfo.exe --formats” lists the MrSID format after setting the GDAL_DRIVER_PATH.
A other post says that the gdal core must be installed.
I added the folder containing the gdalinfo.exe to the path - is this correct?
Yours Rüdiger
Von: Ralph Dell [mailto:RDell@anonymised.com]
Gesendet: Mittwoch, 6. Mai 2015 14:12
An: Gubler, Ruediger; ‘geoserver-users@lists.sourceforge.net’
Betreff: RE: GDAL-Support for geoserver 2.7.0
Mine look like
  • gdal-data.zip
Installed on server
Installed on server
Yours Rüdiger
Hi Ruediger,
On Wed, May 6, 2015 at 3:41 PM, Gubler, Ruediger <rgubler@anonymised.com> wrote:
If you are referring to what is contained in this 1 archive (or a similar one you downloaded), I would say “yes”.
Since gdalinfo.exe is properly working, it sounds like the core GDAL DLLs are found.
Last thing to check is whether the java bindings are working properly.
I would try again a gdalinfo.bat call from the javainfo folder against a sample file.
If everything is ok, you should see a log like this when restarting GeoServer:
it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL INFO: GDAL Native Library loaded (version: 1.9.2)
Please, let us know if you still have issues.
Daniele
Yours Rüdiger
Mine look like
To:geoserver-users@anonymised.comet
  • gdal-data.zip
Installed on server
Installed on server
Yours Rüdiger
As Daniele suggested have you installed the gdal core? The download for it will be on the same page as you found the mrsid.msi
Sent: Wednesday, May 06, 2015 9:41 AM
Subject: Re: [Geoserver-users] GDAL-Support for geoserver 2.7.0
Yours Rüdiger
Mine look like
  • gdal-data.zip
Installed on server
Installed on server
Yours Rüdiger
I think I have identified the problem.
If I start tomcat from the console the GDAL support is present.
If I start from our service wrapper the GDAL support is missing.
The only difference we found is the case of the environment variables and a semicolon at the end of the path environment variable.
Console:
GDAL_DATA D:\init\GDAL_DATA
GDAL_DRIVER_PATH D:\init\GDAL_DRIVER
Path C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0;…;D:\init\GDAL_NATIVE
Service wrapper:
gdal_data D:\init\GDAL_DATA
gdal_driver_path D:\init\GDAL_DRIVER
path C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0;…;D:\init\GDAL_NATIVE;
Is it possible that the case of the environment variable or the semicolon is checked?
Yours Rüdiger
Von: dany.geotools@…84… [mailto:dany.geotools@…84…] Im Auftrag von Daniele Romagnoli
Gesendet: Mittwoch, 6. Mai 2015 16:13
Betreff: Re: [Geoserver-users] GDAL-Support for geoserver 2.7.0
Hi Ruediger,
On Wed, May 6, 2015 at 3:41 PM, Gubler, Ruediger <rgubler@…5482…> wrote:
Daniele
Yours Rüdiger
Von: Ralph Dell [mailto:RDell@…4195…]
Mine look like
To:geoserver-users@lists.sourceforge.net
  • gdal-data.zip
Installed on server
Installed on server
Yours Rüdiger
We found the solution.
The native dll path must be added to a additional property of our wrapper.
Thank you for the support.
Rüdiger
Von: Gubler, Ruediger
Gesendet: Donnerstag, 7. Mai 2015 09:51
An: ‘Daniele Romagnoli’
Cc: ‘geoserver-users@lists.sourceforge.net’
Console:
Service wrapper:
Yours Rüdiger
Hi Ruediger,
Daniele
Yours Rüdiger
Mine look like
  • gdal-data.zip
Installed on server
Installed on server
Yours Rüdiger
