Dear Support team,
we have installed Geo server 2.2 and deployed our application.we are able to see the IP address of the host who is using our apllication under (GeoServer 2.2\logs) but we are not able to see the username/hostname.So please provide us solution.
Thanks and Regards
Rakesh
Kumar,
try install and setting up the monitoring plugin:
http://docs.geoserver.org/stable/en/user/extensions/monitoring/reference.html#http
(look at Remote user attribute)
Carlo
2013/10/17 Rakesh Kumar Sharma <rakesh_ks@anonymised.com>
Dear Support team,
Thanks and Regards
Rakesh
October Webinars: Code for Performance
Free Intel webinars can help you accelerate application performance.
Explore tips for MPI, OpenMP, advanced profiling, and more. Get the most from
the latest Intel processors and coprocessors. See abstracts and register >
http://pubads.g.doubleclick.net/gampad/clk?id=60135031&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Dott. Carlo Cancellieri
@cancellieric
Software Engineer
Via Poggio alle Viti 1187
mobile: +39 3371094494
Kumar,
as default LayerPreview does not ask for user authentication since all the layer are configured for free access.
looking at the documentation I see:
Remote user | The username specified parsed of the request. Only available when request included credentials for authentication. | String |
This probably means that you have to force your client to use authentication on layer request.
Try to setup authentication rules for some layer forcing authorization requests:
http://docs.geoserver.org/stable/en/user/security/layer.html
This should add credentials to the request.
Carlo
2013/10/21 Rakesh Kumar Sharma <rakesh_ks@anonymised.com>
Dear sir,
Waiting for your reply…
Thanks and Regards
Rakesh
Rakesh Kumar Sharma wrote:
Dear carlo cancellieri,
yes, I have configured through audit mode only .I am able to get all the information like StartTime, EndTime,TotalTime,RemoteAddr,RemoteHost,Host name but only RemoteUser details is not coming.
I have already included the following line in content.ftl file
${remoteUser!“”}.
Thanks and Regards
Rakesh
carlo cancellieri wrote:
Kumar,
How did you configured it?
I suggest to configure it in audit mode, take a look here:
http://docs.geoserver.org/stable/en/user/extensions/monitoring/audit.html#log-files
Carlo
@cancellieric
Software Engineer
@cancellieric
Software Engineer
Rakesh,
could you attach the complete Request dump (headers, request, etc…)? I’d like to verify if LayerPreviews attach the user information to the request.
Carlo
PS: keep the List in CC, in the case some other people may want to participate.
2013/10/22 Rakesh Kumar Sharma <rakesh_ks@anonymised.com>
Dear Sir,
As per your instruction I have set authrntication rule for layer.Now its asking for username/password for desired user but still not able to record out the username of that geoserver user in that log file.wating for your reply
Thanks and Regards
Rakesh
Kumar,
Remote user |
String |
Carlo
@cancellieric
Software Engineer
2013/10/21 Rakesh Kumar Sharma <rakesh_ks@…5931…>
Dear sir,
Thanks and Regards
Rakesh
${remoteUser!“”}.
Thanks and Regards
Rakesh
Kumar,
Carlo
@cancellieric
Software Engineer
@cancellieric
Software Engineer
