It is appreciated if you could keep responses on the public mailing list.
What nightly build artifact did you grab. Did you grab both the release and the the rest config extension?
http://gridlock.openplans.org/geoserver/1.7.x/geoserver-1.7.x-latest-war.zip
http://gridlock.openplans.org/geoserver/1.7.x/ext-latest/geoserver-1.7.3-SNAPSHOT-restconfig-plugin.zip
-Justin
sovireak.moeung@anonymised.com wrote:
Hi, thanks for your answer, but how can i get the fixed version 1.7.4 of the Rest Api. I have tryed the nightly build version, but it's not fixed, i have the same problem.
Sovireak
Justin Deoliveira-6 wrote:
I believe this is a know issue, and thankfully one that has been fixed:
http://jira.codehaus.org/browse/GEOS-2825
If you grab the latest nightly build it should work:
-Justin
Sovireak wrote:
I am a new user of Geoserver, and i just wanted to know more about the
Rest
Api.
I am using the GeoExt Styler 1.7.3, and when i click on "Save", the
Styler
use the Rest Api to save temporarily the sld but not seem to save the
sld
in the Geoserver datastore. So when i restart my Geoserver, the sld are
not
modified. Can you tell me how can i modify the sld source in order to
save
the sld changes directly in the geoserver datastore ?Thanks
Justin Deoliveira
OpenGeo - http://opengeo.org
Enterprise support for open source geospatial.------------------------------------------------------------------------------
This SF.net email is sponsored by:
High Quality Requirements in a Collaborative Environment.
Download a free trial of Rational Requirements Composer Now!
http://p.sf.net/sfu/www-ibm-com
Geoserver-users mailing list
https://lists.sourceforge.net/lists/listinfo/geoserver-usersQuoted from: http://www.nabble.com/GeoExt-Styler-1.7.3-and-Rest-API-tp22987840p22995789.html
Justin Deoliveira
