Hi
Based on previous advice, I’ve looked into GeoFence, as it seems to be the only way to script creation of users through REST. I don’t understand, why this is natively supported by Geoserver itself, but leave that aside for now.
I have downloaded the geofence.war and unpacked in my geoserver\webapps\geofence, but this doesn’t seem to start GeoFence with Geoserver on Jetty on Windows. The installation guide provided at
https://github.com/geosolutions-it/geofence/wiki/GeoFence-installation
only mentions how to install in Tomcat. Is it impossible to install in Jetty, which is distributed with the “Windows installer” package? If it’s possible, kindly provide instructions.
Thanks in advance,
Jacob Madsen
I'm trying to upgrade Geoserver from 2.3.5 to 2.8.1. According to to the doc there seems to be nothing special to do:
http://docs.geoserver.org/stable/en/user/datadirectory/migrating.html#migrating-data-directory
The war file can be deployed without problems. But after I stop geoserver to assign GEOSERVER_DATA_DIR in web.xml, it cannot be re-run again.
In the log this is the only exception I could notice:
INFORMATION: Illegal access: this web application instance has been stopped already. Could not load org.geotools.data.DefaultServiceInfo. The eventual following stack trace is caused by an error thrown for debugging purposes as well as to attempt to terminate the thread which caused the illegal access, and has no functional impact.
java.lang.IllegalStateException
at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1370)
at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1329)
at org.geotools.data.store.ContentDataStore.getInfo(ContentDataStore.java:292)
at org.geotools.gce.imagemosaic.catalog.GTDataStoreGranuleCatalog.finalize(GTDataStoreGranuleCatalog.java:749)
at java.lang.System$2.invokeFinalize(System.java:1270)
at java.lang.ref.Finalizer.runFinalizer(Finalizer.java:98)
at java.lang.ref.Finalizer.access$100(Finalizer.java:34)
at java.lang.ref.Finalizer$FinalizerThread.run(Finalizer.java:210)
I'd appreciate any hint!
Best regards,
NV
HI Nhahn,
you have to provide more information, like the entire stack trace, for example.
When subscribing to the list you were asked to read this document, it contains a list of info
that makes for a useful question:
http://geoserver.org/comm/userlist-guidelines.html
On Tue, Dec 1, 2015 at 2:51 PM, Nhan Vo <nhanvo@anonymised.com> wrote:
I’m trying to upgrade Geoserver from 2.3.5 to 2.8.1. According to to the
again.
at
at
at
at
I’d appreciate any hint!
Best regards,
NV
Go from Idea to Many App Stores Faster with Intel(R) XDK
Give your users amazing mobile app experiences with Intel(R) XDK.
Use one codebase in this all-in-one HTML5 development environment.
Design, debug & build mobile apps & 2D/3D high-impact games for multiple OSs.
http://pubads.g.doubleclick.net/gampad/clk?id=254741911&iu=/4140
Geoserver-users mailing list
Geosolutions’ Winter Holidays from 24/12 to 6/1
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
