Thanks for the replies. Suppose we keep the geometry column, how does it
compare in terms of performance between these two: sending a request to
GeoServer to update the feature geometry vs having our application access
PostGreSQL directly and call PostGIS functions to update the geometry
column?
Thanks.
Wai See
-----Original Message-----
From: geoserver-users-bounces@lists.sourceforge.net
[mailto:geoserver-users-bounces@lists.sourceforge.net] On Behalf Of Chris
Holmes
Sent: Sunday, September 24, 2006 10:22 PM
To: leewse@anonymised.com
Subject: Re: [Geoserver-users] Geometry column
You're actually probably wanting the 'geometryless' module, if you're
wanting to get geometries just from coordinates. It's a part of
geotools, but we're not shipping it with GeoServer yet. So if you look
at that code, you can find a jdbc datastore that just reads coordinates
from x and y columns.
best regards,
Chris
leewse@anonymised.com wrote:
Hi Ivan,
Thanks for reply. Please bear with me, but could you please elaborate on
these two points?
1.
it only needs
to know what GeoServer can offer.
2.
and if you want to draw map from plain coordinates you can export
postgres table to shape file.
Thanks a lot.
Wai See
Postgres/Postgis is only one of the sources GeoServer accepts. Thats
the nice thing with geoserver, your map doesnt need to know about
geometry column or postgres or about geoserver sources, it only needs
hope i helped
regards!
On 9/21/06, Lee Wai See <leewse@anonymised.com> wrote:
Our team has some questions which we hope GeoServer can help us with.
We are currently using PostgreSQL with PostGIS, and PostGIS stores the
geometries in a geometry column. Please correct me if I am wrong, but is
this only specific to PostGreSQL with PostGIS? In other words, if we
were to
change the database we want to use, can GeoServer still function without
this geometry column?
2. Then how would my map knows what to draw without the geometry
column?
Is it possible to draw a feature just from plain coordinates?
Lee Wai See
[This e-mail is confidential and may be priviledged. If you are not
the
intended recipient, please kindly notify us immediately and delete the
message
from your system; please do not copy or use it for any purpose, nor
disclose
its contents to any other person. Thank you.]
---ST Electronics Group---
No virus found in this outgoing message.
Checked by AVG Free Edition.
Version: 7.1.405 / Virus Database: 268.12.4/449 - Release Date:
9/15/2006
Join SourceForge.net's Techsay panel and you'll get the chance to share
your
opinions on IT & business topics through brief surveys -- and earn cash
Geoserver-users mailing list
Ivan Grcic
National IT coordinator
Iaeste Croatia
Email: ivan.grcic@anonymised.com
Tel: +385 98 567 457
your
!DSPAM:1003,45129245234807785049143!
Chris Holmes
The Open Planning Project
http://topp.openplans.org
No virus found in this incoming message.
Version: 7.1.405 / Virus Database: 268.12.8/455 - Release Date: 9/22/2006
