On Sat, May 14, 2016 at 1:48 PM, Miguel-Angel Manso-Callejo (UPM) <
m.manso@anonymised.com> wrote:
I think that this must not be happend. Geopackage is a standard and
different libraries must implement it and interoperate.
Agree that's the case, it should be interoperable.
However, both GeoTools and GeoServer geopackage modules are currently
unsupported, and have not reached
the quality level necessary to get them in a release, that's why they can
only be downloaded
in nightly builds..
Everybody is welcomed to get into the code and start improving it.
We recently had a few improvements in this direction that might have
addressed the issue you
reported (see the history at
https://github.com/geotools/geotools/commits/master/modules/unsupported/geopkg/src
I'd suggest you try out the 2.9.x series and the associated nightly builds,
it could be that it's working
now, if not, pull requests to fix the incompatibilities are most welcomed.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
