I have leveraged the geoprocessing framework for ArcGIS Server which calls various tools in the ArcGIS Toolbox. Pretty easy to have a client application send a request to ArcGIS Server and then get a response and use that to display to a map.
Use case I currently have is to find slope of a polyline based on some elevation model and then insert points along the line at a spacing distance specific to a slope via a web map.
I looked at the Scripting Extension for Geoserver v2.3x. I looked at WPS which I guess is most mature with a Java library?
Please give me an insight as to my options to do this in a web map as well as what is the likely future of this type of development in the Geoserver ecosystem.
Thanks.
Justin
Hi Justin,
It does sound like you want WPS stuff. There’s the GeoServer WPS extension for that http://docs.geoserver.org/stable/en/user/extensions/wps/index.html?highlight=extension - I’ve not used it myself, but it looked fairly simple from the examples I’ve seen.
Also free & open-source, there’s also: http://zoo-project.org/ - http://pywps.wald.intevation.org/ - and a QGIS WPS plugin too.
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
On 18 September 2013 18:29, Justin Perez <Justin.Perez@anonymised.com> wrote:
Thanks.
Justin
LIMITED TIME SALE - Full Year of Microsoft Training For Just $49.99!
1,500+ hours of tutorials including VisualStudio 2012, Windows 8, SharePoint
2013, SQL 2012, MVC 4, more. BEST VALUE: New Multi-Library Power Pack includes
Mobile, Cloud, Java, and UX Design. Lowest price ever! Ends 9/20/13.
http://pubads.g.doubleclick.net/gampad/clk?id=58041151&iu=/4140/ostg.clktrk
Geoserver-users mailing list
