[Geoserver-users] GeoRSS output and google maps
  I'm curious about Geoserver and GeoRSS.
Will application/rss+xml be available as an output format only using the
reflector or will this be possible?
http://localhost/geoserver/wms?request=GetMap&layers=geo:state&styles=state&
srs=EPSG:4326&bbox=-125,23,-65,53&WIDTH=1000&HEIGHT=500&format=application/r
ss%2Bxml
Is there a way to have georss:line or georss:polygon output?
Example:
<item>
<title>Coldwater Lake</title>
<description>Formed by the 1980 eruption of Mount St. Helens.</description>
      <georss:polygon>46.31409 -122.22616 46.31113
-122.22968 46.31083 -122.23320 46.29802 -122.25877 46.29245 -122.26641
46.29286 -122.26392 46.28746 -122.26744 46.28741 -122.26006 46.29049
-122.25955 46.29120 -122.25620 46.28924 -122.255430 46.30271 -122.23251
46.31284 -122.22315 46.31409 -122.22616</georss:polygon>
<icon>./icons/green.jpg</icon>
</item>
  Also in the little bit of experimenting I've done so far I can't
seem to change the bbox? Does the reflector use only the layer Min/Max
Bounding Box?
http://asus/geoserver152/wms/reflect?bbox=-100.0,30.0,-60.0,90.0&layers=geo:
state&format=application/rss%2Bxml
Right now GeoRSS is the only cross service (GE, VE, and Yahoo) overlay
format. It would be nice if Microsoft and Yahoo would support KML, but I
somehow don't think Microsoft will make that leap.
Thanks
Randy
-----Original Message-----
From: geoserver-users-bounces@lists.sourceforge.net
[mailto:geoserver-users-bounces@lists.sourceforge.net] On Behalf Of Justin
Deoliveira
Sent: Monday, August 06, 2007 3:57 PM
To: dlamoris@anonymised.com
Subject: Re: [Geoserver-users] GeoRSS output and google maps
I can also confirm that "application/rss+xml" does not work? It appears
the "+" has to be url encoded. So if you use:
"format=application/rss%2Bxml"
It should work. Which is a bit confusing because other formats with "+"
sign in them work without url encoding. for instance:
application/vnd.google-earth.kml+XML
Looks like KML does a special check:
format.startsWith("application/vnd.google-earth.kml").
Opening up a bug for this. Should be simple to fix. Should we get it
into 1.5.2a?
http://jira.codehaus.org/browse/GEOS-1271
This also begs the larger question if we should put in a "global" check
so this does not happen to other formats which use a "+" sign.
-Justin
Geoserver-users mailing list
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
Randy George wrote:
ss%2Bxml
Definitely, the reflector is just a shortcut so you don't have to fill in all of the parameters.
The code is written to do it... its pretty trivial. Its just not really hooked up. Perhaps this is something we could do as a outputFormat option, that is an additional parameter specific to georss output.
Feel free to throw in a feature request for this.
Example:
<item>
</item>
Bounding Box?
Looks like you are right, the bounding box is ignored... hmmm thats not good... that means any georss request will give you back all features... yikes. Scheduling a jira:
http://jira.codehaus.org/browse/GEOS-1272
I would tend to agree :).
Thanks
Randy
Deoliveira
I can also confirm that "application/rss+xml" does not work? It appears the "+" has to be url encoded. So if you use:
It should work. Which is a bit confusing because other formats with "+" sign in them work without url encoding. for instance:
Opening up a bug for this. Should be simple to fix. Should we get it into 1.5.2a?
This also begs the larger question if we should put in a "global" check so this does not happen to other formats which use a "+" sign.
-Justin
Justin Deoliveira
Actually Microsoft said they'll support KML in virtual earth in september/october release: http://geothought.blogspot.com/2007/07/microsoft-virtual-earth-to-support-kml.html
But I do agree our GeoRSS output should improve.
Thanks
Randy
Deoliveira
-Justin
Yes, I see my original wms url was pointing at the wrong geoserver. It does
work except for the bbox.
Wouldn't the georss output depend on the backing data:
  the_geom: polygonProperty <georss:polygon>
  the_geom: lineStringProperty <georss:line>
   the_geom: pointProperty <georss:point> || <geo:lat>
<geo:long>
Using atom output I get a namespace error:
http://asus/geoserver152/wms?request=GetMap&layers=geo:state&styles=state&sr
s=EPSG:4326&bbox=-125,23,-65,53&WIDTH=1000&HEIGHT=500&format=application/ato
m%2Bxml
Reference to undeclared namespace prefix: 'georss'.
Line: 1 Character: 394
<?xml version="1.0" encoding="UTF-8"?><feed
xmlns="http://www.w3.org/2005/Atom&quot;
xmlns:geo="http://www.w3.org/2003/01/geo/wgs84_pos#&quot;&gt;&lt;title/&gt;&lt;link
href="http://localhost…"/><updated>Tue Aug 07 09:21:33 MDT
2007</updated><entry><title>state.1</title><link
href="http://localhost…"/><id>state.1</id><updated>Tue Aug 07 09:21:34 MDT
2007</updated><content>some
content</content><georss:where><geo:lat>64.49432030231523</geo:lat><geo:long
Adding xmlns:georss="http://www.georss.org/georss&quot; to the <feed> will fix.
Randy
From: Justin Deoliveira [mailto:jdeolive@anonymised.com]
Sent: Monday, August 06, 2007 7:46 PM
To: Randy George
Randy George wrote:
ss%2Bxml
Example:
<item>
</item>
Bounding Box?
Thanks
Randy
Deoliveira
into 1.5.2a?
-Justin
Justin Deoliveira
Hi Chris,
Yes, I saw Peter's note on the VE support of KML, but I guess I have a hard
time believing it. Perhaps a subset of KML, but I would think they are more
interested in WPF/E support.
Randy
Sent: Monday, August 06, 2007 10:16 PM
To: Justin Deoliveira
Cc: Randy George; geoserver-users@lists.sourceforge.net
l.html
Thanks
Randy
Justin
Deoliveira
into 1.5.2a?
-Justin
<geo:long>
Yup, and for points I guess there would be no change. But currently for lines and polygons points are still output. The reason being that most of the mashup clients only support points. Although I beleive yahoo supports additional geometries but via their extension? Not 100% sure.
Whats your application Randy? It should be pretty easy for us to come up with something that will work for you.
m%2Bxml
Thanks for the report. Scheduling an issue for it.
http://jira.codehaus.org/browse/GEOS-1273
Randy
From: Justin Deoliveira [mailto:jdeolive@anonymised.com] Sent: Monday, August 06, 2007 7:46 PM
To: Randy George
Randy George wrote:
ss%2Bxml
Example:
<item>
</item>
Bounding Box?
Thanks
Randy
Deoliveira
-Justin
Justin Deoliveira
As part of OWS-5 we're working on defining 'modules' of KML to make it easier for people to support sub-sets. Supporting the full of KML would be tough for anyone. I've never really heard of WPF, are they doing anything with it and mapping yet?
Chris
Randy George wrote:
Hi Chris,
Randy
From: Chris Holmes [mailto:cholmes@anonymised.com] Sent: Monday, August 06, 2007 10:16 PM
l.html
Thanks
Randy
Justin
Deoliveira
-Justin
!DSPAM:4005,46b89a67190082458217002!
