[Geoserver-users] [GEOS-993] - Icons for KML placemarks should pick up point SLD stylings
Justin said that he added the SLD-support for points in kml output just in May .
(http://jira.codehaus.org/browse/GEOS-993 )
I tested it with the latest 1.5.x nightly build and following sld for a point layer, but it didn't work.
I got a default (gray) vector symbol instead the external graphic. If i set the KMScore=0, so that the output is an raster, the correct symbol is displayed.
greets
Ronald
   <NamedLayer>
    <Name>Default Point</Name>
    <UserStyle>
        <!-- they have names, titles and abstracts -->
      <Title>A boring default style</Title>
      <Abstract>Baustellenschilder</Abstract>
      <FeatureTypeStyle>
        <Rule>
          <Name>Rule 1</Name>
          <Title>PurpleFill</Title>
          <Abstract>Baustellensymbol 50px</Abstract>
          <PointSymbolizer>
            <Graphic>
            <ExternalGraphic>
                <OnlineResource
    xmlns:xlink="http://www.w3.org/1999/xlink&quot;
    xlink:type="simple"
    xlink:href="http://kataster.sv.rostock.de/images/baustelle.png&quot;/&gt;
                <Format>image/png</Format>
            </ExternalGraphic>
            <Size>50</Size>
      </Graphic>
    </PointSymbolizer>
        </Rule>
        </FeatureTypeStyle>
    </UserStyle>
  </NamedLayer>
</StyledLayerDescriptor>
Ronald Woita
http://geoportal.rostock.de
Hansestadt Rostock
Kataster-, Vermessungs- und Liegenschaftsamt
Holbeinplatz 14, 18069 Rostock
email: ronald.woita@anonymised.com
phone: +49 (0)381 - 381 6256
Hi Ronald,
Inspecting the code it appears that as written it will only pick up the icon if it is in the "styles" directory of your geoserver data directory.
So as a workaround right now if you copy the icon into the styles directory and reference via relative url, ie change http://kataster.sv.rostock.de/images/baustelle.png to baustelle.png it should work.
I scheduled a bug for this issue.
http://jira.codehaus.org/browse/GEOS-1221
-Justin
Ronald Woita wrote:
I tested it with the latest 1.5.x nightly build and following sld for a point layer, but it didn't work. I got a default (gray) vector symbol instead the external graphic. If i set the KMScore=0, so that the output is an raster, the correct symbol is displayed.
  greets Ronald
   <NamedLayer>
    <UserStyle>
      <FeatureTypeStyle>
        <Rule>
          <Name>Rule 1</Name>
          <PointSymbolizer>
            <Graphic>
            <ExternalGraphic>
                <OnlineResource
    xmlns:xlink="http://www.w3.org/1999/xlink&quot; xlink:type="simple" xlink:href="http://kataster.sv.rostock.de/images/baustelle.png&quot;/&gt;
            </ExternalGraphic>
            <Size>50</Size>
      </Graphic>
    </PointSymbolizer>
        </Rule>
        </FeatureTypeStyle>
    </UserStyle>
  </NamedLayer>
Ronald Woita
Hansestadt Rostock
email: ronald.woita@anonymised.com phone: +49 (0)381 - 381 6256
This SF.net email is sponsored by DB2 Express
Download DB2 Express C - the FREE version of DB2 express and take
control of your XML. No limits. Just data. Click to get it now.
http://sourceforge.net/powerbar/db2/
Geoserver-users mailing list
!DSPAM:4007,469b73d2298518362916074!
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
