Oh, I know the problem. Jody moved the location of the 'edit' button.
CCing the user's list, as others may have had this issue as well. We should explicitly explain where the edit button is, since it's no longer obvious (I actually preferred the old way, the new way is a bit too obscure and takes too many clicks to edit).
To edit GeoServer docs, go to the column on the left and click on 'page operations'.
That will drop down:
'View'
'Edit'
'Attachments'
'Info'
Those used to be at the top, but are now more obscure, on the right. All the permissions should still be correct.
best regards,
Chris
Eduin Yezid Carrillo Vega wrote:
I still without write permissions. Look at attached file on previous email.
Thanks for your help
Eduin
2006/10/30, Eduin Yezid Carrillo Vega <yecarrillo@anonymised.com>:
Sure.
2006/10/30, Chris Holmes <cholmes@anonymised.com>:
> You should be fine, I just checked the permission scheme and it's not
> been changed. Are you logged in?
> > hello Chris. I think I lose my editing abilities in GEOSDOC. Please
> > recheck that.
> > Thanks
> Chris Holmes
> The Open Planning Project
> http://topp.openplans.org
>!DSPAM:1003,4547fafe103122223018498!
Chris Holmes
