[Geoserver-users] Geoserver 1.3.0-beta3 Release
Geoserver 1.3.0-beta3 is now released.
You can download it here:
The install instructions wiki is at:
http://docs.codehaus.org/display/GEOS/How+to+Download+and+Install+Geoserver
This install's wiki page is at:
http://docs.codehaus.org/pages/viewpage.action?pageId=24447
The Release Notes are here:
http://jira.codehaus.org/secure/IssueNavigator.jspa?reset=true&mode=hide&sorter/order=ASC&sorter/field=priority&pid=10311&fixfor=11662
This release has greatly improved the Geoserver WMS capabilities.
Major Changes
1. Geoserver now passes all WFS and WMS CITE tests
2. Geoserver WMS now does reprojection
     You can use "&SRS=NONE" if you dont want to do any reprojection.
3. Geoserver now allows you to define your geoserver data directory
(previously called "GEOSERVER_HOME") - see below
4. Added a bunch of "helpers" for SRS (spatial referencing system) since
people will have to define their SRSs now
5. Full SLD schema validation support
Minor Changes
1. bug fixes
2. set of lite renderer improvements
3. added a WFS lock tutorial
(http://docs.codehaus.org/display/GEOS/Feature+Locking)
4. upgraded to latest geotools
You can define your geoserver data directory in three ways:
1."GEOSERVER_DATA_DIR" system property.
   this will most likely have come from "java -DGEOSERVER_DATA_DIR=..."
or from you web container's GUI
2. "GEOSERVER_DATA_DIR" in the web.xml document:
     <context-param>
            <param-name>GEOSERVER_DATA_DIR</param-name>
            <param-value>c:\myGeoserverData</param-value>
     </context-param>
3. Defaults to the old behavior - ie. the application root - usually
"server/geoserver" in your .WAR.
To make a new one of these data directories, just:
1. create the data directory
2. copy "data/" from an already running geoserver
3. create a "WEB-INF/" directory
5. copy "catalog.xml" and "services.xml" into the WEB-INF/ directory
Dave
This mail sent through IMP: https://webmail.limegroup.com/
Hi David:
Are these changes available in the wcs-branch as well?
Alex
             dblasby@anonymised.com
             .org
             Sent by: To
             geoserver-users-a geoserver-devel@anonymised.com
             dmin@anonymised.com et,
             forge.net geoserver-users@anonymised.com
                                       et
        cc
             04/22/2005 05:38
             PM Subject
                                       1.3.0-beta3 Release
http://sourceforge.net/project/showfiles.php?group_id=25086&package_id=38410&release_id=322593
Major Changes
Minor Changes
1. bug fixes
     <context-param>
     </context-param>
Dave
SF email is sponsored by - The IT Product Guide
Read honest & candid reviews on hundreds of IT Products from real users.
Discover which products truly live up to the hype. Start reading now.
http://ads.osdn.com/?ad_id=6595&alloc_id=14396&op=click
Geoserver-users mailing list
Dave, would it be possible to tar and zip the war file in the release so that you can include the version information in the distribution. Eg:
geoserver-1.3.0-beta3-war.zip <http://prdownloads.sourceforge.net/geoserver/geoserver-1.3.0-beta3-bin.tar.gz?download&gt;
Currently I have a number of geoserver war files in my Download directory and I'm not sure which version they are.
Cameron Shorter
http://cameron.shorter.net
Good idea! :slight_smile: I renamed the war-files by myself
Ben
