[Geoserver-users] GeoServer 1.3.2 release!
Hey all, we've got a new release for GeoServer. Feel free to forward this on to potentially interested lists or to write nice blog posts about it :slight_smile: We're feeling pretty good about the state of things, and would like to attract the next bump of interest.
The GeoServer Project is pleased to announce the release of version 1.3.2. We know it's not a very glamorous number - if our project members were focused on marketing instead of building great software we'd probably call it GeoServer XT, or perhaps GeoServer: Google Earth edition, to more accurately reflect what we've been up to. But we think it's a pretty great release, regardless of the name.
GeoServer is an open source, standards-based server of geospatial information, connecting spatial databases and files to the variety of clients that make up the 'geospatial web', and allowing user contributed editing through standard web-based interfaces. GeoServer can be downloaded at http://docs.codehaus.org/display/GEOS/Latest
Improvements for this release include an upgrade to GeoTools 2.2.x, and some performance tuning on the toolkit, with users reporting at least a 60-70% speed increase against PostGIS. There are also great user contributed fixes to create PDF maps from WMS and to adjust headers to allow caching, which can optimize GeoServer for tiling web mapping clients like Google Maps or OpenLayers. The other big set of improvements were supported by Google, in order to leverage GeoServer's data reading and map producing capabilities to allow anyone to make their existing data available on Google Earth. The bulk of the work was to create KML/KMZ output from the open standard WMS protocol, which is compatible with Google's network link. Also funded was a basic SLD creation wizard, so that map styles can be created through the web administration GUI.
With the latest additions GeoServer becomes an ideal server for Google Earth and beyond, especially for connecting with existing spatial databases. GeoServer supports PostGIS, ArcSDE, Oracle Spatial, DB2, MySQL, and Shapefiles and recent improvements with GeoTools 2.2.x pass the majority of the spatial processing back to the database. There is also a KMScore optimization, which has GeoServer render the features as a raster to be used as a Ground Overlay, for situations when there are too many features for Google Earth to efficiently portray. GeoServer is able to handle millions of rows in a geospatial database, and will perform quite nicely as long as the map is styled efficiently with the Styled Layer Descriptors (SLD) specification from the OGC. GeoServer remains 'standard by default', so all layers configured for Google Earth will also be available as standard WMS and WFS. GeoServer's transactional capabilities also allow a community of users to update spatial data, and have it available in a variety of formats.
About GeoServer
GeoServer is an Open Source server that connects your information to the GeoSpatial web. Its focus is ease of use and support for standards, including serving as WFS 1.0 Reference Implementation (and soon to be 1.1 as well). The goal is to serve as 'glue' for the geospatial web, connecting from legacy databases and formats to many diverse clients. GeoServer includes easy to use installers, web administration tools, and demos to get you going quickly. GeoServer's homepage is geoserver.org, and more information on features can be found at http://docs.codehaus.org/display/GEOS/Features The release can be downloaded at: http://docs.codehaus.org/display/GEOS/Latest The GeoServer Project is completely open source, in license and development process, built by a diverse community of contributors (http://docs.codehaus.org/display/GEOS/Contributors), whom you are encouraged to join. GeoServer is built on GeoTools, a project of the new Open Source GeoSpatial Foundation (http://osgeo.org).
Chris Holmes
The Open Planning Project
http://topp.openplans.org
Did you get the GeoTools 2.2.RC4 jars that were released for you? Trying to minimize IP exposure here ...
Jody
I try to use the kml output for GoogleEarth with this new version: with the
same url (only changing the output format) I see the map when
format=image/gif, but when I use format=application/vnd.google-earth.kml+XML
the reponse is empty,and I don't see anything in googleEarth.Why?
Regards:
F.Zuriaga
-----Mensaje original-----
De: geoserver-users-bounces@lists.sourceforge.net
[mailto:geoserver-users-bounces@lists.sourceforge.net] En nombre de Chris
Holmes
Enviado el: miércoles, 05 de julio de 2006 17:20
Para: geoserver-users@lists.sourceforge.net;
geoserver-devel@lists.sourceforge.net
Asunto: [Geoserver-users] GeoServer 1.3.2 release!
administration GUI.
About GeoServer
Chris Holmes
Sure you use the right coordinate system ? Google Earth supports WGS84
Regards:
F.Zuriaga
Holmes
administration GUI.
About GeoServer
Chris Holmes
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-users mailing list
And note that at this point GeoServer does not support reprojection with KML (though if you've got it returning a Ground Overlay, like a low KMScore, then it'll reproject fine with KMZ). We hope to get reprojection in soon. But as of now if it's stored in anything other than EPSG:4326 then it won't work right. And Steven is right in that it must be requested with EPSG:4326. If you use the geoserver/wms/kml_reflect?layers=yourLayer then GeoServer will make sure all the parameters are right (and you can add additional WMS params if you don't want it to use the defaults).
Chris
Regards:
F.Zuriaga
Holmes
administration GUI.
About GeoServer
Chris Holmes
Geoserver-devel mailing list
!DSPAM:1003,44ad1a3f192521702038478!
Chris Holmes
What version of google earth are you using? The new Beta version of GE does not work with network links at the moment.
Also, the projection needs to be in 4326. We will be adding in auto-reprojection in soon to Geoserver.
Brent Owens
(The Open Planning Project)
Regards:
F.Zuriaga
Holmes
administration GUI.
About GeoServer
Chris Holmes
O.K, I use the new version of GE 4. The projection in the network link is
4326, but the coordinate system of my layer is 23030 in Geoserver. When I
make the request to geoserver of this layer with SRS:4326 and coordinates of
bbox in 4326 coordinates, it seems to work fine.
To make the re-projection with geotools (2.1) I must to include bursa wolf
parameters in the wkt of EPSG:23030. I try to transform coordinates with
geotools 2.1 and wkt of EPSG:23030 with this parameters and it works very
well.
I modify the file epsg.properties included in gt2-epsg.jar in the /lib
directory of geoserver. But I can't verify if the transformation is correct
until geoserver works with the version 4.
Thanks...
F.Zuriaga
De: Brent Owens [mailto:brentowens@anonymised.com]
Enviado el: jueves, 06 de julio de 2006 17:24
Para: Fernando Zuriaga
CC: geoserver-users@lists.sourceforge.net;
Asunto: Re: [Geoserver-users] GeoServer 1.3.2 release!
Brent Owens
with the same url (only changing the output format) I see the map when
Regards:
F.Zuriaga
Chris Holmes Enviado el: miércoles, 05 de julio de 2006 17:20
databases.
About GeoServer
soon to be
downloaded
Chris Holmes
easier Download IBM WebSphere Application Server v.1.0.1 based on
Apache Geronimo
42 _______________________________________________
Yes, reprojection won't work at all if you're actually returning KML in GeoServer. It will work if you're producing a Ground Overlay though, like with a low KMScore.
well.
Where are you doing this reprojection? A part of GeoServer? Or just on your own? Yes, we know GeoTools projection works great, but the KML writer doesn't yet pass the right arguments to GeoTools. If you'd like to help work on this we can show you where the change needs to be made.
Yeah, we're waiting on Google to fix things, since it really doesn't seem to be an error on our side, since if you save the KML produced by the network link and view then everything works fine.
best regards,
Chris
Thanks...
F.Zuriaga
De: Brent Owens [mailto:brentowens@anonymised.com] Enviado el: jueves, 06 de julio de 2006 17:24
Brent Owens
I try to use the kml output for GoogleEarth with this new version: with the same url (only changing the output format) I see the map when format=image/gif, but when I use format=application/vnd.google-earth.kml+XML
Regards:
F.Zuriaga
[mailto:geoserver-users-bounces@lists.sourceforge.net] En nombre de Chris Holmes Enviado el: miércoles, 05 de julio de 2006 17:20
databases.
About GeoServer
Chris Holmes
Get stuff done quickly with pre-integrated technology to make your job easier Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
!DSPAM:1003,44ae797c77687785049143!
Chris Holmes
Nice!!
Now that the official 1.3.2 release is out it looks like it is time to branch 1.3.x and get 1.4.x onto trunk. To do so we will need a couple of things.
1. Code freeze on trunk
2. Geotools 2.2.x version mess cleaned up
3. 1.4.x syncs with trunk
4. WCS branch syncs with trunk
5. Do the switch
How does that sound. I will be traveling the next few days, so how about we give people until Monday until we call the official code freeze? This will give us a couple of days for people to try out the release and give some time for any last minute changes, although I figure 1.3.2 is pretty solid :).
Alessio, does doing a sync up on WCS work for you?
-Justin
About GeoServer
!DSPAM:1004,44abd8ba105161702038478!
Justin Deoliveira
jdeolive@anonymised.com
Justin Deoliveira wrote:
Nice!!
Think we are straight, looks like just lack of communication. How about we freeze on GeoTools 2.2.RC4 ?
5. Do the switch
Missed one ...
6. Transfer Developers Guide from GEOSDEV to GEOSDOC.
-Justin
