Hello community,
GeoServer 1.3.4 has been released. You can grab it here: http://docs.codehaus.org/display/GEOS/GeoServer+1.3.4
It is a small upgrade from 1.3.3 with a new version of the integrated MapBuilder client and more robust SLD support for KML.
The GeoServer Team
Hi
I have written a EJB3 annotations tutorial here which I have already posted to the PostGIS group, I thought might be interesting to the GeoServer group since transactions are useful for WFS-T, WPS (Web Processing Service) and EJB3 makes this easy.
http://postgis.refractions.net/support/wiki/index.php?SpatialEJB3
The tutorial is in �draft�, it covers using Java 5 annotations to persist spatial objects to
PostGIS, exposing Java 5 pojos as a web service, and finally using Python as a client to
JBoss web services to update PostGIS.
Apologies for its draft nature, hopefully it is of use to somewhere.
This work is a contribution to in the current investigation by the OSGEO GeoData group led by Jo Walsh in creating simple RESTful
Catalog interfaces - http://wiki.osgeo.org/index.php/Simple_Catalog_Interface
My aim is to transfer the ingest mechanism so that a web Crawler can update PostGIS; the scalability of the queue, and the fact I can seamlessly cluster JBoss make this useful.
Possible extension ideas are;
Spatial EJB-QL makes it useful for a catalog.
Having discussed this with Markus, the code is available under the LGPL since it is a work that builds off the PostGIS JDBC driver.
Apologies if you have already received this off the postgis list.
thanks,
Norman
