Hrm. I wonder if this might be a side effect of building with our new
'dummy' jar (so we're not violating any licenses).
Gabriel or Saul, have you had a chance to try out RC2 and the arcsde
jar? Can you check if it works for you, and if not then maybe send
Brent a recently built jar that does work so we can upload it?
Sorry for the hassle Chris, thanks for your patience. This would be
much easier if we convinced ESRI to open source arcsde
Chris Tweedie wrote:
Brent, thanks for uploading but i'm still getting the same error when
adding the store using RC2,
java.lang.NoSuchMethodError:
org.geotools.data.arcsde.PooledConnection.getLayers()Ljava/util/List;
.. this is with the common-pool.jar 1.3. I am currently using the older
sde plugin from 1.3 but would love to test out any GT improvements
I dont suppose anyone else has tried the newer plugin on their
environment?
Chris
On Mon, 30 Oct 2006 19:27:43 -0800, Brent Owens <bowens@anonymised.com>
wrote:
Thanks for the catch on the missing SDE download Chris. I will build it
and upload it as soon as I can.
Brent Owens
(The Open Planning Project)
Couple of things at a quick glance for SDE stuff,
1. Should Commons-pool.jar be bundled with arcsde plugin for future
releases? Seems as though this is the only one that requires the
library
2. The latest builds of the plugins didnt include arcsde
3. Using the latest available arcsde-plugin + commonspool ...
connection
still fails to SDE 9.1 + Ora 10g with the following
161563 [INFO] org.geotools.data.arcsde.ArcSDEConnectionPool - Created
pool org.apache.commons.pool.impl.GenericObjectPool@anonymised.com
at
org.geotools.data.arcsde.ArcSDEConnectionPool.getAvailableLayerNames(ArcSDEConnectionPool.java:373)
at
org.geotools.data.arcsde.ArcSDEDataStore.getTypeNames(ArcSDEDataStore.java:142)
at
org.vfny.geoserver.action.data.DataDataStoresEditorAction.execute(DataDataStoresEditorAction.java:144)
at
org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:98)
at
org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:431)
at
org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:236)
at
org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
at
org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:252)
at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:173)
at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:122)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:202)
at
at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:178)
at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:126)
at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:105)
at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:107)
at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:148)
at
org.apache.jk.server.JkCoyoteHandler.invoke(JkCoyoteHandler.java:199)
at
org.apache.jk.common.HandlerRequest.invoke(HandlerRequest.java:282)
at org.apache.jk.common.ChannelSocket.invoke(ChannelSocket.java:754)
at
org.apache.jk.common.ChannelSocket.processConnection(ChannelSocket.java:684)
at
org.apache.jk.common.ChannelSocket$SocketConnection.runIt(ChannelSocket.java:876)
at
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:684)
at java.lang.Thread.run(Unknown Source)
On Mon, 30 Oct 2006 16:34:48 -0800, Brent Owens <bowens@anonymised.com>
wrote:
The GeoServer team is proud to announce the second release candidate
of
the 1.4 series. You can download the release here:
http://docs.codehaus.org/display/GEOS/GeoServer+1.4.0-RC2
This release includes:
- New version of imbedded Jetty server
- More documentation
- GML Datastore extra
- German Translation
- More bug fixes
- Plus much, much more
The issue log for this release is here:
http://jira.codehaus.org/secure/IssueNavigator.jspa?reset=true&pid=10311&fixfor=12967
Based on GeoTools 2.2.2-SNAPSHOT
The GeoServer Team
Using Tomcat but need to do more? Need to support web services,
security?
Get stuff done quickly with pre-integrated technology to make your
job
easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache
Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-users mailing list
Chris Tweedie
security?
Get stuff done quickly with pre-integrated technology to make your job
easier
Geronimo
Chris Tweedie
security?
easier
Geronimo
Geoserver-devel mailing list
!DSPAM:1003,45480af9108681702038478!
