[Geoserver-users] GeoServer 1.4.0 released!
I uninstalled everything, deleted old environment variables and restarted
the server.
After reinstalling 1.4.0 again, it now works.
Richard
-----Original Message-----
From: Richard Matsunaga [mailto:richard.matsunaga@anonymised.com]
Sent: December 15, 2006 11:53 AM
To: 'Brent Owens'; 'geoserver-users@lists.sourceforge.net'
Subject: RE: [Geoserver-users] GeoServer 1.4.0 released!
C:\Program Files\GeoServer 1.4.0\bin>startup GEOSERVER_HOME environment
variable not found. Using current directory. Please set GEOSERVER_HOME for
future uses.
The system cannot find the path specified.
'C:\Program' is not recognized as an internal or external command, operable
program or batch file.
I did notice that my GEOSERVER_DATA_DIR environment variable was not removed
in the RC5 uninstall. Updating this to the new folder path didn't change
anything. I don't recall if there was ever a GEOSERVER_HOME variable in
previous releases. I don't think so.
Looking at the batch file, it seems like it doesn't really need this
variable anyway. Adding it doesn't seem to help, it just changes the error
message on startup.
Richard
From: Brent Owens [mailto:brentowens@anonymised.com]
Sent: December 15, 2006 11:28 AM
To: Richard Matsunaga
Subject: Re: [Geoserver-users] GeoServer 1.4.0 released!
Could you run the batch (startup) file from the command line and send us the
log that it outputs?
It will help us better track down what happened.
thanks
Brent Owens
(The Open Planning Project)
Richard Matsunaga wrote:
I just installed 1.4.0 and GeoServer won't start. The command window
opens and then closes almost immediately.
I previously had RC4 and RC5 running fine on the same machine.
Richard
Date: Wed, 13 Dec 2006 10:09:01 -0800
Subject: [Geoserver-users] GeoServer 1.4.0 released!
To: geoserver users <geoserver-users@lists.sourceforge.net>,
  Geoserver-devel <geoserver-devel@lists.sourceforge.net>
Message-ID: <458041BD.4010101@anonymised.com>
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
GeoServer 1.4.0 is the next major stable release of the series that
brings many new features and improved functionality. The big push of
1.4.0 is the transition of GeoServer's architecture to Spring to be
more programmer friendly, allowing modular addition of new plug-in
services.
The major changes for this release are:
Spring framework
Updated embedded Jetty
More KML styling
German translation
Name extensions for WMS .shp and .pds results On-the-fly log level
changing KML reprojection
Many bug fixes and additional services are in this release including:
request caching, windows service option, and datastores for ArcSDE,
Oracle, DB2, MySQL, GML, WFS, and VPF.
The modular Spring framework opens new doors for developers to create
interesting and exciting plug-ins that are easy to distribute and install.
You can download GeoServer and its extensions at the official download
page: http://docs.codehaus.org/display/GEOS/GeoServer+1.4.0
Brent Owens
hmm, interesting. I guess it was using the old data directory from the release candidates, which was a little different (and not totally correct).
I will file a bug report to fix the uninstaller so the environment variable is removed.
Thanks for your help Richard.
Brent Owens
the server.
Richard
From: Richard Matsunaga [mailto:richard.matsunaga@anonymised.com] Sent: December 15, 2006 11:53 AM
future uses.
message on startup.
Richard
thanks
Brent Owens
I just installed 1.4.0 and GeoServer won't start. The command window opens and then closes almost immediately.
Richard
GeoServer 1.4.0 is the next major stable release of the series that brings many new features and improved functionality. The big push of 1.4.0 is the transition of GeoServer's architecture to Spring to be more programmer friendly, allowing modular addition of new plug-in
services.
Spring framework
More KML styling
German translation
Name extensions for WMS .shp and .pds results On-the-fly log level changing KML reprojection
Many bug fixes and additional services are in this release including: request caching, windows service option, and datastores for ArcSDE, Oracle, DB2, MySQL, GML, WFS, and VPF.
The modular Spring framework opens new doors for developers to create interesting and exciting plug-ins that are easy to distribute and install.
Brent Owens
I lurk on this list, but wanted to say congratulations for getting the 1.4 release out the door! :slight_smile:
Brent Owens
the server.
Richard
future uses.
message on startup.
Richard
thanks
Brent Owens
Richard
services.
Spring framework
More KML styling
German translation
Brent Owens
opinions on IT & business topics through brief surveys - and earn cash
Geoserver-users mailing list
Thanks Greg!
Brent Owens
Brent Owens
the server.
Richard
future uses.
message on startup.
Richard
thanks
Brent Owens
Richard
services.
Spring framework
More KML styling
German translation
Brent Owens
