Hi all gui,
I go to demo link of Geoserver, and click to Map View. I want to get GeoRSS but I get error, only my layers.
Nguyễn Đình Toán
Neu khong doc duoc tieng Viet, vui long vao menu View → chon Encoding → chon Unicode (UTF-8). Cam on.
Hi all gui,
Nguyễn Đình Toán
Can you include more information about the error you are getting? A stack trace from the console or the log would be helpful. Also, which kind of datasource is your layer?
Toan Nguyen wrote:
Hi all gui,
I go to demo link of Geoserver, and click to Map View. I want to get GeoRSS but I get error, only my layers.--
Nguyễn Đình Toán-------------------------
Neu khong doc duoc tieng Viet, vui long vao menu View --> chon Encoding --> chon Unicode (UTF-8). Cam on. !DSPAM:4007,482cf086243901849620573!------------------------------------------------------------------------
This SF.net email is sponsored by: Microsoft Defy all challenges. Microsoft(R) Visual Studio 2008. http://clk.atdmt.com/MRT/go/vse0120000070mrt/direct/01/!DSPAM:4007,482cf086243901849620573!
Geoserver-users mailing list
https://lists.sourceforge.net/lists/listinfo/geoserver-users!DSPAM:4007,482cf086243901849620573!
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
Toan Nguyen ha scritto:
Hi all gui,
I may be wrong, but as far as I remember the GeoRSS feeds needs to be
obtained from a publicly visible server with a public IP: this
is because the GoogleMaps & co. API do not parse the RSS on the
client side, but on their server side.
If I'm correct, the demo with ship with is not hitting the local
geoserver, but sigma.openplans.org instead, which has been down for some time yesterday. May that be the reason?
On the other side, if you use OpenLayers instead of the proprietary
API, I believe you'll be able to see GeoRSS without limitations
due to API key and server location.
I see
Thank you very much.
Nguyễn Đình Toán
Right... but it sounds like this is just viewing it in the browser? I seem to remember a bug with GeoRSS in 1.5.x... like it never really working correctly. I could be wrong.
Toan, are you willing to upgrade to a 1.6 version. Support will definitely be better there.
Hi all gui,
I go to demo link of Geoserver, and click to Map View. I want to get GeoRSS but I get error, only my layers.I may be wrong, but as far as I remember the GeoRSS feeds needs to be
geoserver, but sigma.openplans.org instead, which has been down for some time yesterday. May that be the reason?On the other side, if you use OpenLayers instead of the proprietary
due to API key and server location.Cheers
Andrea-------------------------------------------------------------------------
https://lists.sourceforge.net/lists/listinfo/geoserver-users!DSPAM:4007,482d2b55317708992556831!
Justin Deoliveira
I have update to 1.6.3 version before, but there are some error in this version. So, I use version 1.5.3 for safety :D. I dont know if they fix this error.
Nguyễn Đình Toán
So the question remains, are you simply trying to view the georss feed in your web browser?
definitely be better there.I have update to 1.6.3 version before, but there are some error in this version. So, I use version 1.5.3 for safety :D. I dont know if they fix this error.
Neu khong doc duoc tieng Viet, vui long vao menu View --> chon Encoding --> chon Unicode (UTF-8). Cam on. !DSPAM:4007,482da5fe210975332866982!
Justin Deoliveira
Not only view the georss feed in browser, but I want to get it into my program. Beauce I want to use mapbuilder to build a map like gmap. When the map is loaded, have some mark ready on the map. I think I can use georss for this, but I dont know exactly.
Nguyễn Đình Toán
