Hello,
I’ve been trying to install GeoServer 1.5-beta2 and am not having much success and was hoping someone with a better working knowledge of GeoServer could help.
Setup info: Microsoft w2k3, Java SE 6( v1.6.0), Java EE 5(_02), Apache Tomcat 5.5.20
The machine is a 64-bit machine so by default installs GeoServer into a 32-bit (x86) specific Program Files dir (C:\Program Files (x86)\GeoServer 1.5.0-beta2). Initially i thought the problem could be down to some unsupported characters in the path ( e.g. ellipse brackets) messing up the lookup of some initialisation property, so reinstalled to a more neutral location (C:\GeoServer 1.5.0-beta2), but the problem remained.
I’m familiar with installing and configuring earlier ‘stable’ versions of GeoServer and have tried installing GeoServer 1.5-beta2 from WAR and Windows Installer. I’ve included a copy of the error in question from Tomcat’s logs.
Apache Tomcat logs;
catalina*.log
SEVERE: Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘config’ defined in URL [jar:file:/C:/GeoServer%201.5.0-beta2/webapps/geoserver/WEB-INF/lib/main-1.5.0-beta1.jar!/applicationContext.xml ]: Initialization of bean failed; nested exception is org.springframework.beans.factory.BeanInitializationException: Error creating xml config reader; nested exception is org.vfny.geoserver.global.ConfigurationException: java.lang.NullPointerException
at org.vfny.geoserver.global.xml.XMLConfigReader.loadCatalog(XMLConfigReader.java:339)
at org.vfny.geoserver.global.xml.XMLConfigReader.load (XMLConfigReader.java:222)
at org.vfny.geoserver.global.xml.XMLConfigReader.(XMLConfigReader.java:170)
at org.vfny.geoserver.global.Config.setApplicationContext(Config.java:43)
at org.springframework.context.support.ApplicationContextAwareProcessor.postProcessBeforeInitialization (ApplicationContextAwareProcessor.java:84)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:248)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:362)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java :226)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:147)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java :275)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:318)
at org.springframework.web.context.support.AbstractRefreshableWebApplicationContext.refresh (AbstractRefreshableWebApplicationContext.java:134)
at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:230)
at org.springframework.web.context.ContextLoader.initWebApplicationContext (ContextLoader.java:156)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:48)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java :3763)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4211)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1013)
at org.apache.catalina.core.StandardHost.start (StandardHost.java:718)
at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:442)
at org.apache.catalina.core.StandardService.start (StandardService.java:450)
at org.apache.catalina.core.StandardServer.start(StandardServer.java:709)
at org.apache.catalina.startup.Catalina.start(Catalina.java:551)
at sun.reflect.NativeMethodAccessorImpl.invoke0 (Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:294)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:432)
Caused by: java.lang.NullPointerException
at org.vfny.geoserver.global.xml.XMLConfigReader.loadFeatureTypes (XMLConfigReader.java:1313)
at org.vfny.geoserver.global.xml.XMLConfigReader.loadCatalog(XMLConfigReader.java:335)
… 29 more
05-Feb-2007 20:09:28 org.apache.catalina.core.StandardContext start
SEVERE: Error listenerStart
SEVERE: Context [/geoserver] startup failed due to previous errors
The following, unedited snippet comes from GeoServer’s web.xml file and relates to the Spring applicationContext.xml file within which GeoServer is unable to locate the bean defined with the name ‘config’.
contextConfigLocation classpath*:/applicationContext.xml ---Any help/suggestions on how to resolve this would be greatly appreciated.
Many thanks,
Simon Abele
