[Geoserver-users] GeoServer 1.5 failing to restart
Hello,
I've downloaded the GeoServer demo and got it running under win and linux. I managed to import my own data (shapes and postgis), and all went well. (The GUI is very nice for first time users, making Geoserver a joy to use.)
All went well till I had to shutdown the service (running as a background process under linux). It couldn't find stop.jar (missing in the demo?) and I used some brute force to kill -9 it.
Now, when I start the geoserver and only see
~GeoServer1.5.0/bin$ ./startup.sh
GEOSERVER DATA DIR is /home/utaddei/GeoServer1.5.0/data_dir
1 [main] INFO org.mortbay.log - Logging to org.slf4j.impl.SimpleLogger@anonymised.com via org.mortbay.log.Slf4jLog
355 [main] INFO org.mortbay.log - jetty-6.0.1
577 [main] INFO org.mortbay.log - Started SelectChannelConnector @ 0.0.0.0:8080
I then freezes there. I can see a page, when I point my browser to http://my.server:8080 (that is, something is running), but pointing to http://my.server:8080/geoserver I see
<snip>
HTTP ERROR: 404
NOT_FOUND
RequestURI=/geoserver/welcome.do
Powered by Jetty://
</snip>
Any ideas about what's happening?
Ugo
Ugo Taddei ha scritto:
Hello,
Thank you :slight_smile:
Stop.jar was used in a old version of Jetty that we don't
use anymore. 1.5.0 should have a shutdown.sh command in geoserver/bin to
stop Geoserver.
<snip>
HTTP ERROR: 404
NOT_FOUND
Powered by Jetty://
</snip>
We need the full Geoserver log, which is not enabled by default in the
binary distribution unfortunately. Could you do the following?
Go in the data_dir, locate services.xml, and turn:
<loggingToFile value = "false" />
to
<loggingToFile value = "true" />
Now, let's hope that before failing Geoserver does dump some useful log
into the data_dir/logs directory (which should be created during startup
with logging enabled).
This is where the console output indicates that Geoserver has
started--until something is clicked/changed via the web interface (or
some other method).
<snip>
HTTP ERROR: 404
NOT_FOUND
Powered by Jetty://
</snip>
Looks like the welcome and other pages are not getting compiled...
Possibly Jetty's logs will offer more insight.
And...Ugo??? As in the legendary Ugo from the Visad project? I am
reading through your
tutorials since last night--thanks for your outstanding work!! I gotta
implement zoom now :slight_smile:
Alex
Hi Alexander
some other method).
<snip>
HTTP ERROR: 404
NOT_FOUND
Powered by Jetty://
</snip>
...and where do I find the logs? The ones from geoserver are empty (as nothing happended).
Thanx, thanx. Whether I'm legendary, I doubt. But I'm glad the tutorial helped you (and others!).
Alex
Ugo
hello Andrea,
Hello,
stop Geoserver.
Well, it shutdown.sh does call stop.jar:
exec "$_RUNJAVA" -DSTOP.PORT=8079 -DSTOP.KEY=geoserver -jar stop.jar
<snip>
HTTP ERROR: 404
NOT_FOUND
Powered by Jetty://
</snip>
to
I did that, but got no logs. I got a new version installed, and that is at least is ok. Hopefully I can copy my datastores/ftypes to the new version.
Thanks for helping.
Ugo
version.
There;s also the way to reuse your existing catalog and data even
after you upgrade:
http://docs.codehaus.org/display/GEOSDOC/3+GeoServer+Data+Directory
Alex
hi,
version.
after you upgrade:
Alex
Yep. I did this and got them running again.
Ugo
This is actually a bug. It should be running start.jar with "--stop" as
a parameter. shutdown.bat has the correct behavior. Opening a jira for this.
http://jira.codehaus.org/browse/GEOS-1129
0.0.0.0:8080
<snip>
HTTP ERROR: 404
NOT_FOUND
Powered by Jetty://
</snip>
to
version.
Thanks for helping.
Ugo
This SF.net email is sponsored by DB2 Express
Download DB2 Express C - the FREE version of DB2 express and take
control of your XML. No limits. Just data. Click to get it now.
http://sourceforge.net/powerbar/db2/
Geoserver-users mailing list
!DSPAM:4007,4666bcd449001012714783!
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
hi,
version.
after you upgrade:
Alex
Good. Just in case you get stuck again, I'd like to have geoserver logs
available. Can you enable file logging in the geoserver configuration? :slight_smile:
