a recently instaled 1.6.0 final and i was editing two SLD in different tabs, but when I submit the SLD from one tab the SLD in the other get lost from styles catalog with this error:
pggeodb:uy_mvd_manzanas
org.vfny.geoserver.global.ConfigurationException: FeatureTypeInfo pggeodb:::uy_mvd_manzanas ignored - Style ‘manzanas’ not found
I can’t reproduce this un previous versions. The SLD file exists on the filesystem. Restarting tomcat/geoserver doesn’t seem to fix the problem.
any idea?.
thanks in advance
Facundo Garat Mayer
facundo@anonymised.com
Facundo Garat ha scritto:
org.vfny.geoserver.global.ConfigurationException: FeatureTypeInfo pggeodb:::uy_mvd_manzanas ignored - Style 'manzanas' not found
I can't reproduce this un previous versions. The SLD file exists on the filesystem. Restarting tomcat/geoserver doesn't seem to fix the problem.
any idea?.
Simple, don't do that. Are you sure you cannot reproduce it with older
versions? I bet this happened to me with 1.5.x as well.
The current UI is on the way of the dodo and we are not making
any maintenance on it, we just want to throw it away and redo it
from scratch. If you can cook up a patch that fixes the problem
it would be appreciated thought.
