I'm getting the following error when trying to do a basic GET request from my 1.6.0-beta server:
http://…/geoserver/wfs?request=GetFeature&service=WFS&version=1.1.0&typename=PlaceName&maxFeatures=1
<ows:ExceptionReport version="1.0.0"
xsi:schemaLocation="http://www.opengis.net/ows http://office.refractions.net:21880/geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:ows="http://www.opengis.net/ows">
<ows:Exception exceptionCode="NoApplicableCode">
<ows:ExceptionText>java.lang.NullPointerException
java.lang.NullPointerException</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
The following output is logged during the request - the exception appears to occur in the org.geotools.gml2 package, which appears to be provided by gt2-xml-gml2-2.4-SNAPSHOT.jar, which apparently is an unsupported module of geotools... all in all it looks like an awful mess to debug, especially for me who doesn't already have a geoserver build environment set up. Can anyone guess what would cause an exception there, that only happens for *most* of my postgis tables when setup using the basic default configuration in the web config GUI? I can't see how the tables that do respond to a basic request are different from the ones that cause this exception.
2163579753 [btpool0-0] INFO org.geoserver.wfs -
Request: getFeature
handle = null
service = WFS
version = 1.1.0
query = [net.opengis.wfs.impl.QueryTypeImpl@anonymised.com (group: null, propertyName: null, function: null, filter: null, sortBy: null, featureVersion: null, handle: null, srsName: null, typeName: [{http://www.geobase.ca/interop-pilot-2007\}PlaceName])]
maxFeatures = 1
outputFormat = text/xml; subtype=gml/3.1.1
resultType = results
traverseXlinkDepth = null
traverseXlinkExpiry = null
Result:
2163579790 [btpool0-0] WARN org.geoserver.ows -
at org.geotools.gml2.FeaturePropertyExtractor.properties(FeaturePropertyExtractor.java:60)
at org.geotools.xml.Encoder.encode(Encoder.java:527)
at org.geoserver.wfs.xml.GML3OutputFormat.write(GML3OutputFormat.java:106)
at org.geoserver.wfs.WFSGetFeatureOutputFormat.write(WFSGetFeatureOutputFormat.java:98)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:611)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:210)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:139)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:44)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:684)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:625)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:392)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:347)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:459)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1054)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:178)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1045)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:358)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:231)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:629)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:453)
at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:149)
at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:123)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:141)
at org.mortbay.jetty.Server.handle(Server.java:303)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:452)
at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:721)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:509)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:209)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:349)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:320)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:475)
2163579816 [Finalizer] ERROR org.geotools.data.jdbc - There's code leaving readers, writers or iterators unclosed (you got an unclosed QueryData object, which is usually held by a reader or a writer).
Call reader/writer.close() or FeatureCollection.close(iterator) after using them to ensure they do not hold state such as JDCB connections.
QueryData was open against feature type: PlaceName
