[Geoserver-users] GeoServer 1.6.0-RC2 and mediaLib accelerator error
I'm just trying 1.6.0-RC2 for the first time and I've noticed than now after
I get the mediaLib accelerator error GeoServer stops outputting any messages
(except other exceptions). This makes it difficult for debugging.
Jon
View this message in context: http://www.nabble.com/GeoServer-1.6.0-RC2-and-mediaLib-accelerator-error-tp14915641p14915641.html
Jon Britton ha scritto:
Can you paste the error you're getting? Usually geoserver logs an "error" about medialib acceleration not being there (which is bad, since
pure java readers are slower) but this should not prevent GeoServer
from working or logging.
Btw, if you go in config/server what's the logging level you see?
It it's PRODUCTION then it's normal that you don't see much log,
you should move it down to DEFAULT if you want geoserver to be more
chatty.
The error I'm getting is the normal medialib acceleration exception, which I
used to get using 1.5.4 anyway. Logging is set to DEFAULT. If I view
non-raster data (such as the WFS-T demo) then logging works normally, even
after the mediaLib accelerator exception... but GeoServer still doesn't log
for raster data.
In fact, it might not have anything to do with the mediaLib exception. There
is one extra exception I've been getting with 1.6.0-RC2:
17 Jan 10:16:07 WARN [geoserver.ows] -
javax.imageio.IIOException: I/O error writing PNG file!
        at
com.sun.imageio.plugins.png.PNGImageWriter.write(PNGImageWriter.java:
1135)
        at org.geotools.image.ImageWorker.writePNG(ImageWorker.java:2655)
        at
org.vfny.geoserver.wms.responses.map.png.PNGMapProducer.formatImageOu
tputStream(PNGMapProducer.java:68)
        at
org.vfny.geoserver.wms.responses.map.metatile.MetatileMapProducer.wri
teTo(MetatileMapProducer.java:226)
        at
org.vfny.geoserver.wms.responses.GetMapResponse.writeTo(GetMapRespons
e.java:561)
        at
org.geoserver.ows.adapters.ResponseAdapter.write(ResponseAdapter.java
:60)
        at org.geoserver.ows.Dispatcher.response(Dispatcher.java:615)
        at
org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:19
2)
        at
org.springframework.web.servlet.mvc.AbstractController.handleRequest(
AbstractController.java:139)
        at
org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.ha
ndle(SimpleControllerHandlerAdapter.java:44)
        at
org.springframework.web.servlet.DispatcherServlet.doDispatch(Dispatch
erServlet.java:684)
That's only a partial stack trace (I can give it all if you like but it's
very long). This doesn't seem to affect the output at all, in fact my PNGs
seem fine.
Jon
after
messages
chatty.
Defy all challenges. Microsoft(R) Visual Studio 2008.
Geoserver-users mailing list
View this message in context: http://www.nabble.com/GeoServer-1.6.0-RC2-and-mediaLib-accelerator-error-tp14915641p14916044.html
for raster data.
What do you mean "does not log for raster data"?
        at
1135)
        at
        at
        at
e.java:561)
        at
:60)
        at
2)
        at
        at
        at
erServlet.java:684)
seem fine.
Yep, I would need the full stack trace.
If you're playing with raster data I also encourage you to install the native JAI and JAI image i/o extensions, you'll get way better performance when reading tiff files (and also faster JPEG/PNG encoding).
You can find the installers at jai.dev.java.net and https://jai-imageio.dev.java.net/.
I mean that I don't get any logs telling me about WMS requests, but I do for
WFS. Sorry, I rushed my post and probably didn't make sense!
I think I do already have those installed (I'll double check). Here is the
full stack trace.
17 Jan 10:55:58 WARN [geoserver.ows] -
        at
1135)
        at
        at
        at
e.java:561)
        at
:60)
        at
2)
        at
        at
        at
erServlet.java:684)
        at
org.springframework.web.servlet.DispatcherServlet.doService(Dispatche
rServlet.java:625)
        at
org.springframework.web.servlet.FrameworkServlet.processRequest(Frame
workServlet.java:392)
        at
org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServl
et.java:347)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
        at
org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:459
        at
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(Servlet
Handler.java:1054)
        at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCha
racterEncodingFilter.java:108)
        at
Handler.java:1045)
        at
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(F
ilterChainProxy.java:264)
        at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(Filt
erSecurityInterceptor.java:107)
        at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(Fi
lterSecurityInterceptor.java:72)
        at
ilterChainProxy.java:274)
        at
org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTra
nslationFilter.java:110)
        at
        at
org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFil
ter(AnonymousProcessingFilter.java:125)
        at
        at
org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicPr
ocessingFilter.java:178)
        at
        at
org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilte
r(HttpSessionContextIntegrationFilter.java:229)
        at
        at
org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.jav
a:148)
        at
org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.j
ava:98)
        at
Handler.java:1045)
        at
org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:3
58)
        at
org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:2
31)
        at
org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:6
29)
        at
org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:453)
        at
org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHand
lerCollection.java:149)
        at
org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.
java:123)
        at
org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:1
41)
        at org.mortbay.jetty.Server.handle(Server.java:303)
        at
org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:45
2)
        at
org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpCo
nnection.java:721)
        at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:509)
        at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:209)
        at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:349)
        at
org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.ja
va:320)
        at
org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool
.java:475)
Caused by: org.mortbay.jetty.EofException
        at org.mortbay.jetty.HttpGenerator.flush(HttpGenerator.java:649)
        at
org.mortbay.jetty.AbstractGenerator$Output.flush(AbstractGenerator.ja
va:540)
        at
org.mortbay.jetty.HttpConnection$Output.flush(HttpConnection.java:798
        at
org.vfny.geoserver.util.PartialBufferedOutputStream2.flush(PartialBuf
feredOutputStream2.java:185)
        at
javax.imageio.stream.MemoryCacheImageOutputStream.flushBefore(MemoryC
acheImageOutputStream.java:177)
        at
com.sun.imageio.plugins.png.ChunkStream.finish(PNGImageWriter.java:12
1)
        at
com.sun.imageio.plugins.png.PNGImageWriter.writeIEND(PNGImageWriter.j
ava:918)
        at
1131)
        ... 49 more
Caused by: java.io.IOException: An established connection was aborted by the
sof
tware in your host machine
        at sun.nio.ch.SocketDispatcher.write0(Native Method)
        at sun.nio.ch.SocketDispatcher.write(SocketDispatcher.java:33)
        at sun.nio.ch.IOUtil.writeFromNativeBuffer(IOUtil.java:104)
        at sun.nio.ch.IOUtil.write(IOUtil.java:60)
        at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:334)
        at
org.mortbay.io.nio.ChannelEndPoint.flush(ChannelEndPoint.java:165)
        at
org.mortbay.io.nio.SelectChannelEndPoint.flush(SelectChannelEndPoint.
java:183)
        at org.mortbay.jetty.HttpGenerator.flush(HttpGenerator.java:582)
        ... 56 more
17 Jan 10:55:58 INFO [geoserver.ows] - Problem writing exception information
bac
k to calling client:
        at
org.mortbay.jetty.HttpGenerator.addContent(HttpGenerator.java:119)
        at
org.mortbay.jetty.AbstractGenerator$Output.write(AbstractGenerator.ja
va:596)
        at
va:561)
        at
org.geoserver.ows.LegacyServiceExceptionHandler.handleServiceExceptio
n(LegacyServiceExceptionHandler.java:188)
        at org.geoserver.ows.Dispatcher.exception(Dispatcher.java:1179)
        at
8)
        at
        at
        at
erServlet.java:684)
        at
rServlet.java:625)
        at
        at
et.java:347)
        at
        at
Handler.java:1054)
        at
        at
Handler.java:1045)
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
a:148)
        at
ava:98)
        at
Handler.java:1045)
        at
58)
        at
31)
        at
29)
        at
        at
        at
java:123)
        at
41)
        at
2)
        at
nnection.java:721)
        at
va:320)
        at
.java:475)
sof
        at
        at
java:183)
        ... 48 more
View this message in context: http://www.nabble.com/GeoServer-1.6.0-RC2-and-mediaLib-accelerator-error-tp14915641p14916419.html
Hmmm... right, correct, in 1.6.x it seems there is no request logging
whatsoever anymore... I guess for DEFAULT profile we should (but not for
PRODUCTION, request logging might be expensive).
Can you open a jira issue about this? (jira.codehaus.org)
I think I do already have those installed (I'll double check).Here is the
full stack trace.
sof
Aahh. This happens when the clients do give up on a connection when
GeoServer is trying to write on it (usually because of a timeout of
sorts). In RC3 we should have fixed this, care to try it out? (it's
ready for download on sourceforge).
sof
sorts).
Hum, I did not express myself properly. The above stack trace is not
really an error on the geoserver part, it's just a normal exception
occurred because the client closed the connection on our face.
What we "fixed" in rc3 is that we try not to report these
stack traces anymore because, as you noticed, people take them
as errors whilst they are not.
Ok I've got RC3 now and I no longer get the exception.
Jon
View this message in context: http://www.nabble.com/GeoServer-1.6.0-RC2-and-mediaLib-accelerator-error-tp14915641p14918637.html
FYI, i have a patch for this sitting on my disk.
-Justin
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
