[Geoserver-users] GeoServer 1.7.0-beta2 ArcSDE cannot create new feature type
Can anyone help or have experienced the same problem?
Installed GeoServer 1.7.0-beta2 and the ArcSDE extension
gt-arcsde-2.5-SNAPSHOT.jar
Added ArcSDE libraries jsde_sdk-9.1.jar, jsde_sdkres-9.1.jar,
jpe_sdk-9.1.jar to PATH.
Startup geoserver and use the User interface to create ArcSDE datastore and
then 'Create new FeatureType'
A list of ArcSDE tables are correctly displayed but when I click on button
'New' it just says
'Obtaining FID strategy for SDE_BODC_SPATIAL_OBJECTS'
I checked on the console ...
org.geotools.data.DataSourceException: Obtaining FID strategy for
SDE_BODC_SPATIAL_OBJECTS:
        at
org.geotools.arcsde.data.FIDReader.getFidReader(FIDReader.java:165)
        at
org.geotools.arcsde.data.ArcSDEAdapter.fetchSchema(ArcSDEAdapter.java:273)
        at
org.geotools.arcsde.data.ArcSDEDataStore.getFeatureTypeInfo(ArcSDEDataStore.java:626)
        at
org.geotools.arcsde.data.ArcSDEDataStore.getSchema(ArcSDEDataStore.java:170)
        at
org.geoserver.catalog.util.LegacyCatalogImporter.readFeatureType(LegacyCatalogImporter.java:441)
        at
org.geoserver.catalog.util.LegacyCatalogImporter.imprt(LegacyCatalogImporter.java:154)
        at
org.geoserver.config.GeoServerLoader.initialize(GeoServerLoader.java:84)
        at
org.geoserver.config.GeoServerLoader.postProcessBeforeInitialization(GeoServerLoader.java:67)
Have I missed something or not carrying out the correct procedure?
My operating system is Linux, with Oracle 8.1.7, ArcSDE 9.1, java version
"1.6.0_10-beta"
Any help or hints would be appreciated. Thanks
Quincyme
View this message in context: http://www.nabble.com/GeoServer-1.7.0-beta2-ArcSDE-cannot-create-new-feature-type-tp18979677p18979677.html
I'm afraid the problem you're reporting may be related to the different
environments the extension is developed against and your're testing with.
I can only test with arcsde 9.2 and don't have oracle 8.
Unfortunatelly the exception message is not good enough, I'm gonna send you
another jar to try out that will print a more descriptive message.
Gabriel
'New' it just says
        at
        at
        at
.java:626) at
) at
logImporter.java:441) at
r.java:154) at
        at
verLoader.java:67)
"1.6.0_10-beta"
Quincyme
Hi Gabriel,
I've enclosed the log file as requested.
The GUI says
Obtaining FID strategy for SDE_BODC_SPATIAL_OBJECTS[SDE error -110]
[Error desc=THIS CONNECTION IS LOCKED TO A DIFFERENT THREAD.]
My arcsde table's spatial object field is called 'SHAPE' and is in standard
EPSG:4326.
I viewed it using an ESRI ArcExplorer 9.2.0 java version (free download/use)
and the
features display fine.
I'am not sure if there's perhaps something wrong with my arcsde table? but
hopefully things
will become clearer.
Many thanks and look forward to reply
Quincyme.
Gabriel
and
http://www.nabble.com/file/p19048285/geoserver-1.7.0-beta2.log
View this message in context: http://www.nabble.com/GeoServer-1.7.0-beta2-ArcSDE-cannot-create-new-feature-type-tp18979677p19048285.html
sorry wrong log. It should be this one...
http://www.nabble.com/file/p19048291/geoserver-1.7.0-beta2.startup.log
Hi Gabriel,
The GUI says
EPSG:4326.
and the
hopefully things
Quincyme.
Gabriel Roldán-5 wrote:
you
Gabriel
and
View this message in context: http://www.nabble.com/GeoServer-1.7.0-beta2-ArcSDE-cannot-create-new-feature-type-tp18979677p19048291.html
