[Geoserver-users] GeoServer 1.7.0-beta2 ArcSDE cannot create new feature type
Hi Quincyme,
no its not related to your table, its a bug and I found the source, thanks for
the logs.
Btw, your table does not have a primary key, nor an sde managed rowid nor a
user managed row id, which is dangerous, since the only way we have to get a
feature id out of it is by using the SHAPE identifier, which may be null if
the table allows for null shapes. Also, it'll be read only.
You should create a rowid field for it, either managed by arcsde or by the
user. I guess you can easily do that with arccatlog or some command line
utility.
I'm gonna fix and send you a replacement jar asap.
Gabriel
On Tuesday 19 August 2008 09:56:46 am q luong wrote:
sorry wrong log. It should be this one
> From: luongq@anonymised.com
> To: groldan@anonymised.com
> CC: luongq@anonymised.com
> Subject: RE: [Geoserver-users] GeoServer 1.7.0-beta2 ArcSDE cannot create
> new feature type Date: Tue, 19 Aug 2008 12:43:24 +0000
> Hi Gabriel,
> I've enclosed the log file as requested.
> The GUI says
> Obtaining FID strategy for SDE_BODC_SPATIAL_OBJECTS[SDE error -110]
> [Error desc=THIS CONNECTION IS LOCKED TO A DIFFERENT THREAD.]
> My arcsde table's spatial object field is called 'SHAPE' and is in
> standard EPSG:4326. I viewed it using an ESRI ArcExplorer 9.2.0 java
> version (free download/use) and the features display fine.
> I'am not sure if there's perhaps something wrong with my arcsde table?
> but hopefully things will become clearer.
> Many thanks and look forward to reply
> Quincyme.
> > From: groldan@anonymised.com
> > To: luongq@anonymised.com
> > Subject: Re: [Geoserver-users] GeoServer 1.7.0-beta2 ArcSDE cannot
> > create new feature type Date: Mon, 18 Aug 2008 13:03:02 -0300
> > Hi again Quincyme,
> > Please replace the geotools arcsde jar by the attached one in
> > <geoserver>/WEB-INF/lib and restart geoserver, then set the logging
> > profile to GEOTOOLS_DEVELOPER_LOGGING and apply the configuration.
> > This should give us a better exception message and more logging, then
> > send me the output, hopefully the full <geoserver>/logs/geosever.log
> > file
> > Cheers,
> > Gabriel
> > On Thursday 14 August 2008 08:17:35 am quincyme wrote:
> > > Can anyone help or have experienced the same problem?
> > > Installed GeoServer 1.7.0-beta2 and the ArcSDE extension
> > > gt-arcsde-2.5-SNAPSHOT.jar
> > > Added ArcSDE libraries jsde_sdk-9.1.jar, jsde_sdkres-9.1.jar,
> > > jpe_sdk-9.1.jar to PATH.
> > > Startup geoserver and use the User interface to create ArcSDE
> > > datastore and then 'Create new FeatureType'
> > > A list of ArcSDE tables are correctly displayed but when I click on
> > > button 'New' it just says
> > > 'Obtaining FID strategy for SDE_BODC_SPATIAL_OBJECTS'
> > > I checked on the console ...
> > > org.geotools.data.DataSourceException: Obtaining FID strategy for
> > > SDE_BODC_SPATIAL_OBJECTS:
> > > at
> > > org.geotools.arcsde.data.FIDReader.getFidReader(FIDReader.java:165)
> > > at
> > > org.geotools.arcsde.data.ArcSDEAdapter.fetchSchema(ArcSDEAdapter.java
> > >:273) at
> > > org.geotools.arcsde.data.ArcSDEDataStore.getFeatureTypeInfo(ArcSDEDat
> > >aStore .java:626) at
> > > org.geotools.arcsde.data.ArcSDEDataStore.getSchema(ArcSDEDataStore.ja
> > >va:170 ) at
> > > org.geoserver.catalog.util.LegacyCatalogImporter.readFeatureType(Lega
> > >cyCata logImporter.java:441) at
> > > org.geoserver.catalog.util.LegacyCatalogImporter.imprt(LegacyCatalogI
> > >mporte r.java:154) at
> > > org.geoserver.config.GeoServerLoader.initialize(GeoServerLoader.java:
> > >84) at
> > > org.geoserver.config.GeoServerLoader.postProcessBeforeInitialization(
> > >GeoSer verLoader.java:67)
> > > Have I missed something or not carrying out the correct procedure?
> > > My operating system is Linux, with Oracle 8.1.7, ArcSDE 9.1, java
> > > version "1.6.0_10-beta"
> > > Any help or hints would be appreciated. Thanks
> > > Quincyme
> _________________________________________________________________
> Get Hotmail on your mobile from Vodafone
> http://clk.atdmt.com/UKM/go/107571435/direct/01/
Make a mini you on Windows Live Messenger!
http://clk.atdmt.com/UKM/go/107571437/direct/01/
Hey Gabriel,
I'm having the exact same issue trying to move a client to Geoserver 1.7.
Could you please forward me that JAR as well? Or a link to it?
Amr.
Gabriel Roldán wrote:
Hi Quincyme,
no its not related to your table, its a bug and I found the source, thanks for the logs.
Btw, your table does not have a primary key, nor an sde managed rowid nor a user managed row id, which is dangerous, since the only way we have to get a feature id out of it is by using the SHAPE identifier, which may be null if the table allows for null shapes. Also, it'll be read only.
You should create a rowid field for it, either managed by arcsde or by the user. I guess you can easily do that with arccatlog or some command line utility.
Gabriel
Hi Gabriel,
The GUI says
Quincyme.
Hi again Quincyme,
file
Gabriel
        at
        at
:273) at
va:170 ) at
84) at
Quincyme
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-users mailing list
Refractions Research
Suite 300 - 1207 Douglas St
Victoria, BC, V8W 2E7, Canada
ph: (250) 383-3022
fax:(250) 383-2140
