I'm exploring the use of Geoserver to display image data and am trying to
follow the tutorial at:
http://geoserver.org/display/GEOSDOC/Load+NASA+Blue+Marble+Data
I'm doing OK until the instructions say to "Select Image Pyramidal Plugin",
but Geoserver 1.7.2 does not appear to have a Image Pyramidal plugin.
I notice the webapps/geoserver/WEB-INF/lib directory has
gt-imagemosaic-2.5.3.jar but there is no gt-imagepyramid*
I have a copy of geotools which does have gt-imagepyramid-2.5-SNAPSHOT.jar
What do I have to do to enable the Image Pyramidal plugin in Geoserver 1.7.2?
Regards
Gordon
Gordon Keith
Programmer/Data Analyst
Marine Acoustics
CSIRO Marine and Atmospheric Research
http://www.cmar.csiro.au
perl -e 'print $i=pack(c5,(41*2),sqrt(7056),(unpack(c,H)-2),oct(115),10);'
Hi Gordon,
The plugin is available as a downloadable extension. If you visit:
http://geoserver.org/display/GEOS/Stable
Scroll down to "Extensions", you should find Image Pyramid under "Coveragestore".
-Justin
Gordon Keith wrote:
I'm exploring the use of Geoserver to display image data and am trying to follow the tutorial at: http://geoserver.org/display/GEOSDOC/Load+NASA+Blue+Marble+Data
I'm doing OK until the instructions say to "Select Image Pyramidal Plugin", but Geoserver 1.7.2 does not appear to have a Image Pyramidal plugin.
I notice the webapps/geoserver/WEB-INF/lib directory has gt-imagemosaic-2.5.3.jar but there is no gt-imagepyramid*
Regards
Gordon
Justin Deoliveira
OpenGeo - http://opengeo.org
