[Geoserver-users] GeoServer 1.7.2 and SQL 2008
I have installed GeoServer 1.7.2 and want to expiment with SQL data access to see it the software will integrate into our existing data.
The datastore appears and will connect (as long as the databasename is not specified)
I have the user in SQL configured with the spatial database (spat) as the default database.
I wasn’t sure if GEOMETRY_COLUMNS and SPATIAL_REF_SYS were required or not, but I have created them and I believe the data is correct in them.
How does one create a featureset with the data from SQL 2008. When trying to create a new featureset, there are no items from the SQL datastore.
Thanks
Msg sent via CableONE.net MyMail - http://www.cableone.net
Yes, i believe this is an error with how the connection is established.
I wasn't sure if GEOMETRY_COLUMNS and SPATIAL_REF_SYS were required or not, but I have created them and I believe the data is correct in them.
They are not required no. As far as i know SQL Server does not have any notion of these tables, so the driver does not use them.
So you have some spatial tables in the database that are not being picked up when you try to create a new feature type? Or you want to create a new table all together?
Thanks
Create and Deploy Rich Internet Apps outside the browser with Adobe(R)AIR(TM)
software. With Adobe AIR, Ajax developers can use existing skills and code to
build responsive, highly engaging applications that combine the power of local
resources and data with the reach of the web. Download the Adobe AIR SDK and
Ajax docs to start building applications today-http://p.sf.net/sfu/adobe-com
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
