[Geoserver-users] Geoserver 1.7.2. getfeatureinfo problem
Since we deployed the new version of Geoserver 1.7.2. we have a problem
with the leishmaniasis e-compendium our application developed with
OpenLayers and ExtJS
http://www.who.int/tools/geoserver/www/ecomp/index.htm
The layers are related to leishmaniasis and are generated with CQL
filter.
var res = new OpenLayers.Layer.WMS(
        "Reservoirs",
        url + "/wms?CQL_FILTER=subtopic_i<3",
           layers: 'WHO:leishecomp',
           styles: '',
           format: 'image/gif',
           transparent: 'true'
When you display a layer and click on a marker on the map, the
getfeatureinfo is not shown anymore. The layer WHO:leishecomp is still
available in Geoserver as a FeatureType. The datastore is a PostGIS db.
In the Geoserver Map Preview page, the layer can be displayed with
OpenLayers and the getfeatureinfo is working fine. Do you have any idea
of what can be the cause of the problem?
Nothing has changed in the code. We deployed the new version of
Geoserver 1.7.2. Here is the GetFeatureInfo code:
this.featureInfoForm = new
Ext.FormPanel(ECompendium.FEATURE_INFO_CONFIG);
    this.featureInfoForm.render("featureInfoForm");
    this.featureInfoForm.hide();
    this.featureInfoForm.on({
        clientvalidation: this.featureInfoClientValidation,
        scope: this
    // We use form.setValues(this.emptyFormValues) instead of
form.reset(),
    // because we have trackResetOnLoad enabled. By doing so, we do not
    // need to convert feature.attributes to an Ext.Record, but can use
    // form.setValues(feature.attributes) instead to show the feature's
    // attributes in the form.
    this.emptyFormValues = this.getFormValues();
    // panel for readonly GetFeatureInfo
    this.featureInfoPanel = new Ext.Panel({
        title: this.FEATURE_INFO_CONFIG.title,
        width: this.FEATURE_INFO_CONFIG.width,
        cls: "panel-content",
        autoScroll: true,
        collapsible: true
    this.featureInfoPanel.render("featureInfoPanel");
    this.featureInfoPanel.hide();
    this.featureInfoTemplate = new Ext.Template(
        this.FEATURE_INFO_TEMPLATE);
    editing.vectorLayer.events.register("featureselected", this,
this.showFeatureInfo);
    editing.vectorLayer.events.register("featureunselected", this,
this.hideFeatureInfo);
Johan Lemarchand
Public Health Information and GIS (GIS)
Health Statistics and Informatics (HSI)
Information Evidence and Research (IER)
World Health Organization
Tel: +41 22 791 1076
Email: lemarchandjo@anonymised.com
Lemarchand, Johan ha scritto:
This link does not work... but it's an easy fix, it's actually
just http://www.who.int/tools/geoserver/www/ecomp/index.html
But I don't see how to trigger a GetFeatureInfo request...
filter.
        "Reservoirs",
           styles: '',
           transparent: 'true'
Hmmm... not really. I've tried adding a cql filter to the preview
of topp:states and also to add reprojection to 900913 to the mix,
to see if it made any difference, and could not find any, GetFeatureInfo
seems to work. I would probably try to pinpoint the issue by looking
at exactly what GetFeatureInfo request is made by the client
using Firebug, that might shed some light on the matter.
Andrea Aime
OpenGeo - http://opengeo.org
The request made by the client using GetFeatureInfo is the a WFS POST
request:
Firebug needs to POST to the server to get this information for url:
http://www.who.int/tools/geoserver/wfs
This second POST can interfere with some sites. If you want to send the
POST again, open a new tab in Firefox, use URL 'about:config', set
boolean value 'extensions.firebug.allowDoublePost' to true
This value is reset every time you restart Firefox This problem will
disappear when https://bugzilla.mozilla.org/show_bug.cgi?id=430155 is
shipped.
-----Original Message-----
Sent: 12 March 2009 18:48
To: Lemarchand, Johan
Subject: Re: [Geoserver-users] Geoserver 1.7.2. getfeatureinfo problem
problem
filter.
        "Reservoirs",
           styles: '',
           transparent: 'true'
db.
idea
Andrea Aime
So it seems it is probably doing a GetFeature, rather than a GeFetaureInfo. I had to enable double posting in my latest version of firebug as well. Once you do that you should be able to easily inspect the contents. Nothing is being modified in this request so it should be safe.
request:
shipped.
From: Andrea Aime [mailto:aaime@anonymised.com] Sent: 12 March 2009 18:48
problem
filter.
        "Reservoirs",
           styles: '',
           transparent: 'true'
db.
idea
Justin Deoliveira
Johan, I found out that the WFS GetFeature (not GetFeatureInfo)
request is configured to query the vw_currentemsevents2 feature type.
This does not exist any more on your GeoServer instance.
You could try to remove and re-add the feature type, or, if it still
does not work, the data store that provides this feature type.
Something appears to be wrong with your database connection or
datastore setup, I see in your server web config application that not
all data sources load correctly.
Andreas.
On Thu, Mar 12, 2009 at 6:55 PM, Lemarchand, Johan <lemarchandjo@anonymised.com> wrote:
request:
shipped.
problem
filter.
"Reservoirs",
styles: '',
transparent: 'true'
db.
idea
Andrea Aime
Apps built with the Adobe(R) Flex(R) framework and Flex Builder(TM) are
powering Web 2.0 with engaging, cross-platform capabilities. Quickly and
easily build your RIAs with Flex Builder, the Eclipse(TM)based development
software that enables intelligent coding and step-through debugging.
Download the free 60 day trial. http://p.sf.net/sfu/www-adobe-com
Geoserver-users mailing list
Andreas Hocevar
OpenGeo - http://opengeo.org/
Andreas, the vw_currentemsevents2 feature type is not on the GeoServer instance because it corresponds to another application which is on our intranet instance. The WFS GetFeature should query the WHO:leishecomp feature type.
regards,
Johan
From: andreas.hocevar@anonymised.com [mailto:andreas.hocevar@anonymised.com] On Behalf Of Andreas Hocevar
Sent: 12 March 2009 19:19
Andreas.
request:
shipped.
problem
filter.
"Reservoirs",
styles: '',
transparent: 'true'
db.
idea
Andrea Aime
Andreas Hocevar
In the request:
<wfs:Query
typeName="WHO:leishecomp"
In the response:
Feature type could not be found for vw_currentemsevents2
Looks like a featuretype alias gone wrong? Do you have aliases configured for your layers?
David Winslow
regards,
Johan
Andreas.
> request:
> shipped.
>> Hi,
> problem
>> filter.
>> "Reservoirs",
>> styles: '',
>> transparent: 'true'
> db.
> idea
> Cheers
> Andrea
> Andrea Aime
> Geoserver-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
The feature type leishecomp has no alias configured. It is connected to
a datastore called "WHOGeodata".
I found a feature type called vw_currentemsevents2 connected to a
datastore called "ems".
Both datastores have exactly the same configuration and connect to the
same postgres database (whogeodata). But the table vw_currentemsevents2
is not in the postgres db.
We have a featuretype ems:vw_currentemsevents2 without any spatial data
source identified. I guess the problem might come from this bad
configuration.
Johan Lemarchand
From: David Winslow [mailto:dwinslow@anonymised.com]
Sent: 13 March 2009 14:41
Cc: Andreas Hocevar; geoserver-users@lists.sourceforge.net
In the request:
<wfs:Query
In the response:
David Winslow
feature type.
regards,
Johan
Andreas.
POST
> request:
the
is
> shipped.
problem
>> Hi,
> problem
>> filter.
>> "Reservoirs",
>> styles: '',
>> transparent: 'true'
still
> db.
> idea
GetFeatureInfo
> Cheers
> Andrea
> Andrea Aime
are
and
development
The WFS GetFeature is now working. It was configured to query the
vw_currentemsevents2 feature type. I tried to remove this feature type
and it works fine now. The datastore was not configured properly.
Johan
From: Lemarchand, Johan [mailto:lemarchandjo@anonymised.com]
Sent: 16 March 2009 09:41
To: David Winslow
Cc: geoserver-users@lists.sourceforge.net; Andreas Hocevar
configuration.
Johan Lemarchand
In the request:
<wfs:Query
In the response:
David Winslow
feature type.
regards,
Johan
Andreas.
POST
> request:
the
is
> shipped.
problem
>> Hi,
> problem
>> filter.
>> "Reservoirs",
>> styles: '',
>> transparent: 'true'
still
> db.
> idea
GetFeatureInfo
> Cheers
> Andrea
> Andrea Aime
are
and
development
development
