[Geoserver-users] GeoServer 1.7.3 release date
hello all,
is there an estimated release date for version 1.7.3 yet?
TIA + cheers;
rsn
We have started tracking release dates here:
http://geoserver.org/display/GEOS/Roadmap
Currently scheduled for Feb 23, so soon. Is there a feature in 1.7.3 you are waiting for? Are you aware of the nightly builds?
-Justin
Raif S. Naffah wrote:
hello all,
TIA + cheers;
rsn
Open Source Business Conference (OSBC), March 24-25, 2009, San Francisco, CA
-OSBC tackles the biggest issue in open source: Open Sourcing the Enterprise
-Strategies to boost innovation and cut costs with open source participation
-Receive a $600 discount off the registration fee with the source code: SFAD
http://p.sf.net/sfu/XcvMzF8H
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
hello Justin,
On Tue, 17 Feb 2009 09:36:55 am Justin Deoliveira wrote:
thanks. that's most helpful.
the reason for the question is more product planing on our part since we
bundle GeoServer with our product. having an estimate of a release
date gives us the chance to better plan our product integration, QA and
release.
-Justin
> hello all,
cheers;
rsn
The following is the POST GetFeature request:
<wfs:GetFeature service="WFS" version="1.0.0"
  outputFormat="GML2" xmlns:vagis="http://www.openroadsconsulting.com/vagis&quot;
  xmlns:wfs="http://www.opengis.net/wfs&quot; xmlns:ogc="http://www.opengis.net/ogc&quot;
  xmlns:gml="http://www.opengis.net/gml&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;
  xsi:schemaLocation="http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd&quot;&gt;
  <wfs:Query typeName="vagis:va_jurisdictions">
    <wfs:PropertyName>juris_code</wfs:PropertyName>
    <ogc:Filter xmlns:ogc="http://www.opengis.net/ogc&quot; xmlns:gml="http://www.opengis.net/gml&quot;&gt;
      <ogc:PropertyIsEqualTo>
        <ogc:PropertyName>juris_name_display</ogc:PropertyName>
        <ogc:Literal>Charlottesville (City)</ogc:Literal>
      </ogc:PropertyIsEqualTo>
    </ogc:Filter>
  </wfs:Query>
</wfs:GetFeature>
This is the resulting error:
<ows:ExceptionReport version="1.0.0"
  xsi:schemaLocation="http://www.opengis.net/ows http://209.96.234.116:8080/geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd&quot;
  xmlns:ows="http://www.opengis.net/ows&quot; xmlns:xml="http://www.w3.org/XML/1998/namespace&quot;&gt;
  <ows:Exception exceptionCode="MissingParameterValue">
    <ows:ExceptionText>The query should specify either
      typeName or a featureId filter</ows:ExceptionText>
  </ows:Exception>
</ows:ExceptionReport>
Any idea what it means?
Thanks, David
David R Robison
Open Roads Consulting, Inc.
103 Watson Road, Chesapeake, VA 23320
phone: (757) 546-3401
e-mail: drrobison@anonymised.com
web: http://openroadsconsulting.com
blog: http://therobe.blogspot.com
book: http://www.xulonpress.com/book_detail.php?id=2579
This e-mail communication (including any attachments) may contain confidential and/or privileged material intended solely for the individual or entity to which it is addressed. If you are not the intended recipient, you should immediately stop reading this message and delete it from all computers that it resides on. Any unauthorized reading, distribution, copying or other use of this communication (or its attachments) is strictly prohibited. If you have received this communication in error, please notify us immediately.
Hi David,
The error message seems to indicate to me that it is not being treated like a POST request. How is this request being made? The content of the request seems to be fine to me.
-Justin
    </ogc:Filter>
  </wfs:Query>
</wfs:GetFeature>
  </ows:Exception>
Thanks, David
Justin Deoliveira
I am using wget to test the call. The command I use is:
wget --verbose --post-file=TestJurisByName.in.xml --output-document=TestJurisByName.out.xml http://xxx.xxx.xxx.xxx:8080/geoserver/wfs/GetFeature
David
Hi David,
-Justin
    </ogc:Filter>
  </wfs:Query>
</wfs:GetFeature>
  </ows:Exception>
Thanks, David
David R Robison
Hi David,
I just tried a quick example similar to this with wget and i had to explicity set the "Content-Type" header in order for the xml to be processed properly. Can you try adding:
--header 'Content-Type: text/xml' and try again?
By default it will be set to "application/x-www-form-urlencoded" and the body will be parsed as a key value pair set.
Let us know if that fixes it.
-Justin
David
Hi David,
-Justin
    </ogc:Filter>
  </wfs:Query>
</wfs:GetFeature>
  </ows:Exception>
Thanks, David
Justin Deoliveira
With the header set I get the following error:
<?xml version="1.0" ?>
<ServiceExceptionReport
version="1.2.0"
xmlns=["http://www.opengis.net/ogc"](http://www.opengis.net/ogc)
xmlns:xsi=["http://www.w3.org/2001/XMLSchema-instance"](http://www.w3.org/2001/XMLSchema-instance)
xsi:schemaLocation=["http://www.opengis.net/ogc http://schemas.opengis.net/wfs/1.0.0/OGC-exception.xsd"](http://www.opengis.net/ogchttp://schemas.opengis.net/wfs/1.0.0/OGC-exception.xsd)>
<ServiceException>
error:Translator error
Translator error
subclasses should override
</ServiceException></ServiceExceptionReport>
Any thoughts?
David R Robison
e-mail: [drrobison@anonymised.com](mailto:drrobison@anonymised.com)
web: [http://openroadsconsulting.com](http://openroadsconsulting.com)
blog: [http://therobe.blogspot.com](http://therobe.blogspot.com)
book: [http://www.xulonpress.com/book_detail.php?id=2579](http://www.xulonpress.com/book_detail.php?id=2579)
   version="1.2.0"
   xmlns="http://www.opengis.net/ogc&quot;
   xsi:schemaLocation="http://www.opengis.net/ogc http://schemas.opengis.net/wfs/1.0.0/OGC-exception.xsd&quot;&gt;
   <ServiceException>
Translator error
Any thoughts?
Reminds me of the error AbstractFeatureCollection throws when
getBounds has not been implemented in the subclasses.
Wondering, are you using your own custom datastore? If yes,
implement that method, otherwise, what datastore are you using?
Andrea Aime
This is a PostGIS data store. David
Andrea Aime wrote:
David R Robison
In that case, can you enable "verbose exceptions" in the configuration/server panel and give us the full error
that you get by making the request again? It should
be a complete stack trace.
Andrea Aime
Strange... could you include the entire stack trace? If you could also include the schema of your postgis table would help too.
   version="1.2.0"
   <ServiceException>
Translator error
Any thoughts?
David R Robison
Apps built with the Adobe(R) Flex(R) framework and Flex Builder(TM) are
powering Web 2.0 with engaging, cross-platform capabilities. Quickly and
easily build your RIAs with Flex Builder, the Eclipse(TM)based development
software that enables intelligent coding and step-through debugging.
Download the free 60 day trial. http://p.sf.net/sfu/www-adobe-com
Justin Deoliveira
For some reason, when I specified a property in the properties list, the geometry column was not being returned, this caused the getBounds call to fail. If I added the geometry column to the call, it worked fine. The resulting call is:
    <wfs:PropertyName>the_geom</wfs:PropertyName>
    </ogc:Filter>
  </wfs:Query>
</wfs:GetFeature>
the wget command is
wget --verbose --post-file=TestJurisByName.in.xml --output-document=TestJurisByName.out.xml --header="Content-Type: text/xml" http://xxx.xxx.xxx.xxx:8080/geoserver/wfs/GetFeature
thanks for everyone's help. David
   version="1.2.0"
   <ServiceException>
Translator error
Any thoughts?
David R Robison
David R Robison
Hi David,
Glad you found a working solution for now, but this case should be handled, the geometry property should not be necessary. I am pretty sure Andrea fixed this some time back. Andrea was the fix for this post 1.7.1?
   </ogc:Filter>
</wfs:Query>
</wfs:GetFeature>
the wget command is
   version="1.2.0"
   <ServiceException>
Translator error
Any thoughts?
David R Robison
Justin Deoliveira
