[Geoserver-users] GeoServer 1.7.4 and SQL 2008
Hi all!
This is my first post here and I am new to GeoServer and WMS/WFS. I have
Windows 2003, MS SQL 2008, GeoServer 1.7.4 standalone with 1.7.4 SQL Plugin
installed. Everything is on the same machine.
I can create new Feature Data Set, connect to the SQL (no database name only
user and password) and I can create New FeatureType. In database I have only
one table with:
ID,
Name(varchar)
Shore (geometry) - one simple polygon.
But now SRS in UNKNOWN - I am not sure where this value should be stored in
SQL table. If I understand well I can use 31467 in this case. And even with
typing 31467 into the srs field the bounding box could not be calculated.
The following exception was thrown:
class java.lang.RuntimeException: java.io.IOException
class java.io.IOException:
class org.opengis.referencing.NoSuchAuthorityCodeException: No code
"EPSG:101" from authority "European Petroleum Survey Group" found for object
of type "IdentifiedObject".
Details:
  at
org.geotools.jdbc.JDBCFeatureSource.getBoundsInternal(JDBCFeatureSource.java:441)
  at
org.geotools.jdbc.JDBCFeatureStore.getBoundsInternal(JDBCFeatureStore.java:150)
  at
org.geotools.data.store.ContentFeatureSource.getBounds(ContentFeatureSource.java:357)
  at
org.geotools.data.store.ContentFeatureSource.getBounds(ContentFeatureSource.java:329)
  at
org.geoserver.feature.FeatureSourceUtils.getBoundingBoxEnvelope(FeatureSourceUtils.java:44)
  at
org.vfny.geoserver.util.DataStoreUtils.getBoundingBoxEnvelope(DataStoreUtils.java:318)
  at
org.vfny.geoserver.action.data.TypesEditorAction.executeBBox(TypesEditorAction.java:236)
  at
org.vfny.geoserver.action.data.TypesEditorAction.execute(TypesEditorAction.java:138)
  at org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:101)
  at
org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:431)
  at
org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:236)
  at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
  at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
  at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
  at
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
  at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
  at
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
  at
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
  at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
  at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
  at
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
  at
org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
  at
  at
org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
  at
  at
org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142)
  at
  at
org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81)
  at
  at
org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:217)
  at
  at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:106)
  at
  at
org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
  at
  at
org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
  at
org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
  at
  at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
  at
  at
org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:163)
  at
  at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
  at
  at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
  at
org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
  at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
  at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
  at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
  at
org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
  at
org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
  at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
  at org.mortbay.jetty.Server.handle(Server.java:324)
  at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
  at
org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:842)
  at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:648)
  at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
  at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
  at
org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
  at
org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
Caused by: java.io.IOException
  at
org.geotools.data.sqlserver.SQLServerDialect.decodeGeometry(SQLServerDialect.java:188)
  at
org.geotools.data.sqlserver.SQLServerDialect.decodeGeometryEnvelope(SQLServerDialect.java:212)
  at org.geotools.jdbc.JDBCDataStore.getBounds(JDBCDataStore.java:853)
  at
org.geotools.jdbc.JDBCFeatureSource.getBoundsInternal(JDBCFeatureSource.java:434)
  ... 61 more
Caused by: org.opengis.referencing.NoSuchAuthorityCodeException: No code
  at
org.geotools.referencing.factory.AbstractAuthorityFactory.noSuchAuthorityCode(AbstractAuthorityFactory.java:949)
  at
org.geotools.referencing.factory.PropertyAuthorityFactory.getWKT(PropertyAuthorityFactory.java:314)
  at
org.geotools.referencing.factory.PropertyAuthorityFactory.createCoordinateReferenceSystem(PropertyAuthorityFactory.java:388)
  at
org.geotools.referencing.factory.BufferedAuthorityFactory.createCoordinateReferenceSystem(BufferedAuthorityFactory.java:781)
  at
org.geotools.referencing.factory.AuthorityFactoryAdapter.createCoordinateReferenceSystem(AuthorityFactoryAdapter.java:798)
  at
org.geotools.referencing.factory.FallbackAuthorityFactory.createCoordinateReferenceSystem(FallbackAuthorityFactory.java:638)
  at
  at
org.geotools.referencing.factory.ThreadedAuthorityFactory.createCoordinateReferenceSystem(ThreadedAuthorityFactory.java:729)
  at
org.geotools.referencing.DefaultAuthorityFactory.createCoordinateReferenceSystem(DefaultAuthorityFactory.java:179)
  at org.geotools.referencing.CRS.decode(CRS.java:420)
  at org.geotools.referencing.CRS.decode(CRS.java:348)
  at
org.geotools.data.sqlserver.SQLServerDialect.decodeGeometry(SQLServerDialect.java:185)
  ... 64 more
What I basically need to do is to get very simple polygons from SQL 2008 via
WFS, add 1-2 new polygons to this layer and save it back to database. I hope
it even possible :slight_smile:
I will be very grateful for help!
Cacek
View this message in context: http://www.nabble.com/GeoServer-1.7.4-and-SQL-2008-tp23595915p23595915.html
Hi Cacek,
This is a known issue:
http://jira.codehaus.org/browse/GEOS-2997
As the error states, 101 is not a valid SRS code. The workaround for now until the above is fixed would be to set the property SRID on the table. You should be able to do this with a batch update.
Also, how did you import the data into the database? Does the tool you are using allow you to specify the SRS?
-Justin
Cacek wrote:
Hi all!
installed. Everything is on the same machine. I can create new Feature Data Set, connect to the SQL (no database name only
one table with:
ID, Name(varchar) Shore (geometry) - one simple polygon.
class java.io.IOException: class org.opengis.referencing.NoSuchAuthorityCodeException: No code
of type "IdentifiedObject". Details:
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  ... 61 more
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  ... 64 more
Cacek
Justin Deoliveira
OpenGeo - http://opengeo.org
