The GeoServer team is pleased to announce the release of GeoServer 2.10.2. Download bundles are provided (bin, war, dmg and exe) along with documentation and extensions.
GeoServer 2.10.2 is the latest stable release of GeoServer and is recommended for production deployment. This release is made in conjunction with GeoTools 16.2 and GeoWebCache 1.10.2. Thanks to all contributors.
New Features and Improvements:
- Promote YSLD module to extension
- Add jetty-servlets.jar file to default jetty to help users set up CORS
- Handle non error http codes (from HttpCodeException) as normal response
- Reducing output size of PDF with graphic fills by using tiling patterns
Bug Fixes:
- Disk quota usage page no longer shows negative bytes free
- New style editor can now detect and fix old GeoServer CSS styles (which were marked as SLD)
- Fixes to json output for layergroup
- Can not display table based pages in Turkish locale
- WMS 1.3.0 GetCapabilities response doesn’t validate against the schema when using LayerGroups
- Editing style and moving it into workspace loses the edits
- Style Edit Page: Apply then Submit causes WicketRuntimeException
- Force transformation of ROI and NoData to transparent/bg color in direct raster rendering path
And more! For more information on this release check the release notes (2.10.2 | 2.10.1 | 2.10.0 | 2.10-RC1 | 2.10-beta | 2.10-M0 )
About GeoServer 2.10
Articles, docs, blog posts and presentations:
- The YSLD extension added, with extensive documentation
- State of GeoServer 2016 (slideshare)
- The style editor has been refreshed with the best ideas from the css extension
- The styling workshop has been updated for foss4g 2016 and now includes both CSS and YSLD examples.
- Smart transparency in GeoServer with image/vnd.jpeg-png format (GeoSolutions)
- QGIS SLD export improvements (GeoSolutions)
Community modules
- A new community module to backup/restore and restore GeoServer configuration
- A resource browser is available allowing remote management of styles, icons and fonts (needs building from sources).
- A new WMTS multidimensional domain discovery community module for discovering patches of data in scattered data sets
