[Geoserver-users] GeoServer 2.10-beta Released!
We are happy to announce the release of GeoServer 2.10-beta. Downloads are available (zip, war, dmg and exe) along with docs and extensions.
This is a beta release of GeoServer made in conjunction with GeoTools 16-beta.
Beta Testing
The GeoServer Team has been hard at work to bring you this beta release.
Here is our priorities for testing:
We one crititcal known issues to keep in mind when testing:
  • GEOS-7750 – The WMS and LegendSample beans used in GeoServerTileLayer may provoke a cyclic dependency when Spring beans are loaded. As a consequence tiled layers may not be loaded and are deleted by GWC integration. Please back up your data and configuration before testing the GeoServer 2.10-beta with data you care about.
Highlights from the release notes:
  • Add CSS nested rule support
  • Add CSS rendering transform support
  • Add WMTS multi dimensional community module
  • Add WCS 2.0 Demo Requests
  • OL3 Preview in tiled mode supports map wrapping
  • Make JDBCStore compatible with HazelCast Clustering
  • Changes to WMS GetFeatureInfo for coverages:
    • Band names now presented in responses as NCNames for all info_formats (spaces and leading digits replaced with underscores)
    • Support for continuous map wrapping for latitude/longitude projections
    • Support for coverages with native latitude/longitude coordinates and longitudes > 180 degrees East
Also, looking at the GeoTools 16-M0 release notes, we have:
  • Support Azimuthal Equidistant projection
  • Implement Vladimir’s Polygon label point algorithim
  • GeoPackage can write to boolean fields
For more information about the what is included in the GeoServer 2.10 release, also refer to the GeoServer 2.10-M0 release anouncement.
Security Considerations
This release includes several security enhancements (which are also included in the recent GeoServer 2.8.5 and 2.9.1 releases
  • Although we have not been able to reproduce from GeoServer, a remote execution vulnerability has been reported against both the Restlet and the Apache Commons BeanUtils libraries we use. We have patched our use of these libraries as a preventative measure. We would like to thank Kevin Smith for doing the bulk of the work, and Andrea Aime for providing a patched BeanUtils library addressing these vulnerabilities.
  • Layer security restrictions in CHALLENGE mode were not being correctly applied by embedded GeoWebCache. Thanks to Nick Muerdter for his responsible report of this vulnerability and for submitting a fix (that included a unit test!)
  • Carl Schroedl reported a vulnerability at application startup when working with a data directory on a network file system, a new configuration option has been provided to check that the directory exists. Thanks to Carl for following our responsible disclosure procedure, and to Ben Caradoc-Davies for implementing the new parameter.
If you wish to report a security vulnerability, please visit our website for instructions on responsible reporting.
About GeoServer 2.10
GeoServer 2.10 is scheduled for October release.
