Hi everyone
I'm having strange problems with GetFeatureinfo requests when restricting
access to some of layer attributes. After that column order in getfeaturinfo
request results is messed up - reordered. I could see that following
requests change that order again.
This kind of rule order works:
Instance: default-gs / Service: WMS / Workspace: myworkspace / Layer:
mylayer / Grant: Allow (do not touch "Details")
All Deny at the end
If I select Details and put some of the attributes on "Deny" - and wioth
catalogue mode on "Deny", column order gets messed up.
I'm having Oracle JDK 1.8_144, Tomcat 7.0.69, Geoserver 2.10 master,
PostgreSQL 9.6.x on CentOS 7. Geofence version is 3.2.x nightly. Any idea
why this could happen? Am I missing something or that could be some bug?
You can see the issue at:
http://gis.hrsume.hr/hrsume/wms
Layer "ods" has the most number of attributes.
Thanks & Best regards
Davor
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geoserver-2-10-external-Geofence-3-2-GetFeatureInfo-problem-tp5329591.html
If you have not specified a freemarker template for the request then I do not expect there to be any specific attribute order implied in the getfeatureinfo specification. If you have to have a fixed order of some of the attributes then a freemarker template is probably the best way to go.
Ian
On 28 Jul 2017 9:04 a.m., “dracic” <davor.racic@anonymised.com> wrote:
Hi everyone
I’m having strange problems with GetFeatureinfo requests when restricting
mylayer / Grant: Allow (do not touch “Details”)
All Deny at the end
If I select Details and put some of the attributes on “Deny” - and wioth
catalogue mode on “Deny”, column order gets messed up.
I’m having Oracle JDK 1.8_144, Tomcat 7.0.69, Geoserver 2.10 master,
Layer “ods” has the most number of attributes.
Davor
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
Geoserver-users@anonymised.com.382…sourceforge.net
I have tried with default templates and custom templates with the same
result. When I say "order" I mean column order as in PostGIS table DDL or in
Feature Type Details in Layer Properties. When you say "If you have not
specification." does that mean that every subsequent GetFeatureInfo request
can have different column order, because that is also my problem when I use
Geofence?
I can post my templates here:
header.ftl:
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<html>
<head>
<title>GeoServer GetFeatureInfo output</title>
</head>
<body>
content.ftl:
<caption>layer names: ${type.name}</caption>
fid
<#list type.attributes as attribute>
<#if !attribute.isGeometry>
${attribute.name}
</#if>
</#list>
<#assign odd=false>
<#list features as feature>
<#if odd>
<#else>
</#if>
<#assign odd=!odd>
${feature.fid}
<#list feature.attributes as attribute>
${attribute.value?string}
</#if>
</#list>
</#list>
<br/>
Bes regards
Davor
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geoserver-2-10-external-Geofence-3-2-GetFeatureInfo-problem-tp5329591p5329628.html
Geofence?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geoserver-2-10-external-Geofence-3-2-GetFeatureInfo-problem-tp5329591p5329629.html
Sorry, those were default templates. This is my custom setup:
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geoserver-2-10-external-Geofence-3-2-GetFeatureInfo-problem-tp5329591p5329630.html
So with the previous template with no Geofence rule limiting attribute
access, GetFeatureinfo request orders columns as they are listed in tabel or
layer property. With Geofence rule, they have no particular order, and
subsequent request can have even different order from previous requests.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geoserver-2-10-external-Geofence-3-2-GetFeatureInfo-problem-tp5329591p5329633.html
That is what I would expect, if you require a specific order then you should enforce it in the template (which by the way Nabble is deleting before they reach the list, please use a proper mail client).
So something like in content.ftl:
${feature.STATE_NAME.value} has these characteristics:
Ok. I think I’m not clear enough. I do not want any specific order. I would like generic behavior - which is the one when Geofence rules don’t apply and that is that the attributes are ordered in the way they are listed in database tables or in attribute list in geoserver layer properties. So that is the way that Geoserver displays attributes by default. The other issue is that when Geofence rule is applied, subsequent Getfeatureinfo requests have different attribute order. It changes constantly. This cannot be expected behavior in any case.
For example layer - gj. If you click at least 10timeson features in qgis or any web mapping map that can display external wms and do Getfeatureinfo, you will see at least 4 or 5 different attribute orders.
Best regards
Davor
- ${feature.PERSONS.value}
- $feature.MALE.value}
- $feature.EMPLOYED
[hidden email]
Ian Turton
But in freemarker a feature’s attributes are stored in a map so there is no expected order to them. If you require an order then you should define it.
Ian
Best regards
Davor
View this message in context: Re: Geoserver 2.10 & external Geofence 3.2 - GetFeatureInfo problem
- $feature.EMPLOYED
[hidden email]
Ian Turton
So when no ordering is present in freemarker template the normal behavior is that Geoserver orders attributes randomly for each Getfeatureinfo request? Is that what you are trying to tell me?
So my logic tells me that if this is the case, this would be the case with the default Geoserver template. But that is not the case. There is an order if there is not an explicit order in the template, and that is the order in which attributes are listed in the table definition. If that isn’t the case every Getfeatureinfo would have different attribute order. I haven’t seen this behavior in any Geoserver setup.
This behavior only exists when I apply attribute filter in Geofence - whether I have my own template or use the default one.
Best regards
Davor
Ian
[hidden email]
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/Geoserver-2-10-external-Geofence-3-2-GetFeatureInfo-problem-tp5329591p5329680.html
To unsubscribe from Geoserver 2.10 & external Geofence 3.2 - GetFeatureInfo problem, click here.
NAML
Best regards
Davor
[hidden email]
- $feature.EMPLOYED
[hidden email]
Ian Turton
Just to add one thing. The problem is not related only to html responses. The same issue is present with text, GML and GeoJSON responses. So my logic tells me that this has nothing to do with freemarker templates. It has to do with limiting attribute access through Geofence.
Best regards
Davor
Best regards
Davor
Ian
[hidden email]
NAML
Best regards
Davor
[hidden email]
- $feature.EMPLOYED
[hidden email]
Ian Turton
I'm saying that GeoServer and the WMS specification make no promises as to
the attribute order in a GetFeatureInfo request.
which attributes are listed in the table definition. If that isn't the case
every Getfeatureinfo would have different attribute order. I haven't seen
That some undefined behaviour occurs in a certain way in some cases in no
way implies that it will be that way for all cases.
So if you need a fixed order set up a template that defines that order,
otherwise ask for the info in another format and sort it your self to match
your requirements.
Ian
"I’m saying that GeoServer and the WMS specification make no promises as to the attribute order in a GetFeatureInfo request. "
Ian, please… Not all reasonable things have to be specified by some specification. Constant attribute order change in GetfeatureInfo responses is not something that is present in default Geoserver setup, so it is should not be there when using Geofence plugin.
Best regards
Davor
ned, 30. srp 2017. u 17:19 Ian Turton [via OSGeo.org] <[hidden email]> napisao je:
That some undefined behaviour occurs in a certain way in some cases in no way implies that it will be that way for all cases.
So if you need a fixed order set up a template that defines that order, otherwise ask for the info in another format and sort it your self to match your requirements.
Ian
