After upgrading to GeoServer 2.11.1, I am getting the warning and stack trace
below for WMS GetMap requests for the OpenLayers format using EPSG:4326. It
doesn't appear to break anything and I verified that this warning does not
occur in 2.10.3. I am unable to test 2.11.0 because it is not in Nexus.
Any thoughts?
16:26:30,639 WARN [org.geoserver.wms.map] (default task-4) Failed to
determine CRS axis order, assuming is EN:
org.opengis.referencing.NoSuchAuthorityCodeException: No code
"CRS:GC,DEF,CRS,EPSG,4326" from authority "Web Map Service CRS" found for
object of type "CoordinateReferenceSystem".
at
org.geotools.referencing.factory.AbstractAuthorityFactory.noSuchAuthorityCode(AbstractAuthorityFactory.java:952)
[gt-referencing-17.1.jar:]
at
org.geotools.referencing.factory.wms.WebCRSFactory.createCoordinateReferenceSystem(WebCRSFactory.java:207)
at
org.geotools.referencing.factory.AuthorityFactoryAdapter.createCoordinateReferenceSystem(AuthorityFactoryAdapter.java:802)
at
at
org.geotools.referencing.factory.FallbackAuthorityFactory.createCoordinateReferenceSystem(FallbackAuthorityFactory.java:640)
at
at
at
org.geotools.referencing.factory.ThreadedAuthorityFactory.createCoordinateReferenceSystem(ThreadedAuthorityFactory.java:731)
at
org.geotools.referencing.DefaultAuthorityFactory.createCoordinateReferenceSystem(DefaultAuthorityFactory.java:179)
at org.geotools.referencing.CRS.decode(CRS.java:525)
at org.geotools.referencing.CRS.decode(CRS.java:453)
at
org.geoserver.wms.map.OpenLayersMapOutputFormat.isWms13FlippedCRS(OpenLayersMapOutputFormat.java:263)
[gs-wms-2.11.1.jar:2.11.1]
at
org.geoserver.wms.map.OpenLayersMapOutputFormat.produceMap(OpenLayersMapOutputFormat.java:170)
at
org.geoserver.wms.map.OpenLayersMapOutputFormat.produceMap(OpenLayersMapOutputFormat.java:62)
... removed rest of stack trace
Caused by: java.lang.NumberFormatException: For input string:
"GC,DEF,CRS,EPSG,4326"
at
java.lang.NumberFormatException.forInputString(NumberFormatException.java:65)
[rt.jar:1.8.0_121]
at java.lang.Integer.parseInt(Integer.java:580) [rt.jar:1.8.0_121]
at java.lang.Integer.parseInt(Integer.java:615) [rt.jar:1.8.0_121]
at
org.geotools.referencing.factory.wms.WebCRSFactory.createCoordinateReferenceSystem(WebCRSFactory.java:204)
... 148 more
Steve Ikeoka
View this message in context: http://osgeo-org.1560.x6.nabble.com/GeoServer-2-11-1-OpenLayers-CRS-Warnings-tp5323388.html
