[Geoserver-users] GeoServer 2.16.4 next week, anyone up to test the nightlies?
we plan to start the release process of GeoServer 2.16.4 this Monday.
We’d appreciate if anyone could give the nightly builds a spin, to ensure
there are no regressions compared to 2.16.3, before the release is made.
Nightly builds can be found here:
https://build.geoserver.org/geoserver/2.16.x/
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
I had a chance to test the bin download, no blockers to report.
  1. LICENSE.txt and GPL.txt included
  2. Some oddness when running:
$ bin/startup.sh
GEOSERVER_HOME environment variable not found, using current
directory. If not set then running this script from other
directories will not work in the future.
However later in the startup it correctly detected the included data_dir.
Jody Garnett
