I think it does mean what it says. Its available to be used in the code.
It might or might not be active. That depends on what operations are used and the container you’re using, which is outside the scope of GeoServer.
Brad
From: Humphries, Graham Graham.Humphries@anonymised.com
Sent: Tuesday, 23 June 2020 10:50 AM
To: Tom S tom-sourceforge@anonymised.com; geoserver-users@lists.sourceforge.net
Subject: Re: [Geoserver-users] GeoServer 2.17.1 - Oracle 11.0.7 JDK - Strong cryptography available
I thought it means exactly what it says. To make it active there was some configuration required
From: Tom S [mailto:tom-sourceforge@anonymised.com]
Sent: Tuesday, 23 June 2020 9:20 AM
This does highlight a problem in the text - perhaps the text should read something like ‘Strong cryptography is active’ - available really means something different!
On 6/22/2020 3:40 PM, Brad Hards wrote:
I don’t think this is a problem – this is the way it should be.
If you see “not available” then there are steps to add it, but that doesn’t matter for your case.
Brad
Sent: Tuesday, 23 June 2020 5:58 AM
Subject: [Geoserver-users] GeoServer 2.17.1 - Oracle 11.0.7 JDK - Strong cryptography available
Friends,
I have a server with GeoServer 2.17.1 installed from Debian 9.
I use the Oracle 11.0.7 JDK.
java version “11.0.7” 2020-04-14 LTS
Java™ SE Runtime Environment 18.9 (build 11.0.7+8-LTS)
Java HotSpot™ 64-Bit Server VM 18.9 (build 11.0.7+8-LTS, mixed mode)
When I log in to the administrative interface, I get the message ‘Strong cryptography available’.
How can I solve?
What should you install or configure?
Regads,
Diego
Caros,
Possuo um servidore com GeoServer 2.17.1 instalado de Debian 9.
Utilizo o JDK da Oracle 11.0.7.
Ao logar na interface administrativa, recebo a mensagem ‘Strong cryptography available’.
Como posso resolver?
O que deve instalar ou configurar?
Atenciosamente,
Diego
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
- Earning your support instead of buying it, but Ian Turton: [http://www.ianturton.com/talks/foss4g.html#/](https://aus01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.ianturton.com%2Ftalks%2Ffoss4g.html%23%2F&data=02%7C01%7Cgraham.humphries%40stategrowth.tas.gov.au%7Cf5a6b864472541412eac08d81703257e%7C64ebab8accf44b5ca2d32b4e972d96b2%7C0%7C0%7C637284650388073375&sdata=qX4w8tMAcCjNKXWw6klv1Kx1rxOwVKA3cEs%2FP4ddxhE%3D&reserved=0)
- The GeoServer user list posting guidelines: [http://geoserver.org/comm/userlist-guidelines.html](https://aus01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fgeoserver.org%2Fcomm%2Fuserlist-guidelines.html&data=02%7C01%7Cgraham.humphries%40stategrowth.tas.gov.au%7Cf5a6b864472541412eac08d81703257e%7C64ebab8accf44b5ca2d32b4e972d96b2%7C0%7C0%7C637284650388083367&sdata=OZUfuxdU3jAA8814ssRBfbZg4sCvLSLSrheRVej5zKw%3D&reserved=0)
If you want to request a feature or an improvement, also see this: [https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer](https://aus01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2Fgeoserver%2Fgeoserver%2Fwiki%2FSuccessfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer&data=02%7C01%7Cgraham.humphries%40stategrowth.tas.gov.au%7Cf5a6b864472541412eac08d81703257e%7C64ebab8accf44b5ca2d32b4e972d96b2%7C0%7C0%7C637284650388083367&sdata=%2FKO5PZUEbmmeeMyo9XuRBedKFTLq7yywAqjmt48XJM8%3D&reserved=0)
[Geoserver-users@anonymised.coms.sourceforge.net](mailto:Geoserver-users@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-users](https://aus01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.sourceforge.net%2Flists%2Flistinfo%2Fgeoserver-users&data=02%7C01%7Cgraham.humphries%40stategrowth.tas.gov.au%7Cf5a6b864472541412eac08d81703257e%7C64ebab8accf44b5ca2d32b4e972d96b2%7C0%7C0%7C637284650388093362&sdata=YcVBmdPflDm%2FLunuAPCaMJ9zFm%2F14DrhnV6u0WCg8jU%3D&reserved=0)
CONFIDENTIALITY NOTICE AND DISCLAIMER
The information in this transmission may be confidential and/or protected by legal professional privilege, and is intended only for the person or persons to whom it is addressed. If you are not such a person, you are warned that any disclosure, copying or dissemination of the information is unauthorised. If you have received the transmission in error, please immediately contact this office by telephone, fax or email, to inform us of the error and to enable arrangements to be made for the destruction of the transmission, or its return at our cost. No liability is accepted for any unauthorised use of the information contained in this transmission.
