I’m working on a project using GeoServer and would like to use the GDAL extension for GeoServer to add the GDAL raster formats. So following the basic instructions on the GeoServer webpage I can get it to work by added the GDAL native library path to LD_LIBRARY_PATH or copying them to the /usr/lib64 directory. http://docs.geoserver.org/stable/en/user/data/raster/gdal.html
Environment
CentOS 6.3 x64
GeoServer 2.2.4
GDAL 1.9.2
JBoss 7.1.1
Java 1.6.0_29 x64
The issue I’m running into is that the project I’m working on requires we use JBoss modules and doesn’t allow us to add libraries into the LD_LIBRARY_PATH. So I created a module in the modules/org/gdal/main directory. The module is read, but the GDAL native libraries in the modules/org/gdal/main/lib/linux-x86_64 aren’t working because I’m getting the following message.
02:47:22,622 WARNING [it.geosolutions.imageio.gdalframework] (MSC service thread 1-6) Failed to load the GDAL native libs. This is not a problem unless you need to use the GDAL plugins: they won’t be enabled. java.lang.UnsatisfiedLinkError: no gdaljni in java.library.path
Does anyone know how to make this work or if it is even possible?
module.xml
<module xmlns="urn:jboss:module:1.1" name="org.gdal">
<resources>
<resource-root path="."/>
<resource-root path="lib"/>
</resources>
</module>
jboss-deployment-structure.xml
<jboss-deployment-structure>
<deployment>
<dependencies>
<module name="org.gdal" />
</dependencies>
</deployment>
</jboss-deployment-structure>
View this message in context: GeoServer 2.2.4 and GDAL Native Libs on JBoss 7.1.1 using modules
Dear Max,
I talked to other guys here and we have not yet played with jboss 7 and gdal.
Could please file an enhancement request for this on GeoServer's JIRA?
Simone Giannecchini
GeoServer training in Milan, 6th & 7th June 2013! Visit
http://geoserver.geo-solutions.it for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
On Mon, Apr 15, 2013 at 5:08 PM, Max Guscoff <mguscoff@anonymised.com> wrote:
I'm working on a project using GeoServer and would like to use the GDAL
Environment
CentOS 6.3 x64
GeoServer 2.2.4
GDAL 1.9.2
JBoss 7.1.1
Java 1.6.0_29 x64
The issue I'm running into is that the project I'm working on requires we
use JBoss modules and doesn't allow us to add libraries into the
modules/org/gdal/main/lib/linux-x86_64 aren't working because I'm getting
unless you need to use the GDAL plugins: they won't be enabled.
module.xml
<resources>
</resources>
</module>
<deployment>
<dependencies>
</dependencies>
</deployment>
7.1.1 using modules
Precog is a next-generation analytics platform capable of advanced
analytics on semi-structured data. The platform includes APIs for building
apps and a phenomenal toolset for data science. Developers can use
our toolset for easy data analysis & visualization. Get a free account!
http://www2.precog.com/precogplatform/slashdotnewsletter
Geoserver-users mailing list
