[Geoserver-users] GeoServer 2.20.2 Blobstore Error
Below is an error message when I try a create a blobstore for geowebcache.
It would clearly seem that the problem is the directory is not writable.
I have tried numerous things and am getting more confused.
Setting the directory to 777, creating/adding groups/users to get the tomcat user access and altering tomcat9.service as follows…
/etc/systemd/system/multi-user.target.wants/tomcat9.service
Security
User=tomcat
Group=tomcat
PrivateTmp=yes
AmbientCapabilities=CAP_NET_BIND_SERVICE
NoNewPrivileges=true
CacheDirectory=tomcat9
CacheDirectoryMode=750
ProtectSystem=strict
ReadWritePaths=/etc/tomcat9/Catalina/
ReadWritePaths=/var/lib/tomcat9/webapps/
ReadWritePaths=/var/log/tomcat9/
ReadWritePaths=/geoserver-blobstore
This is confusing because of context…I fired up an Azure Ubuntu 20.04 VM and went through the Geoserver Instructions to install the nice and easy Jetty version:
https://docs.geoserver.org/maintain/en/user/installation/linux.html
All worked fine and I created layers and published data etc…
I could also add a blobstore at the /geoserver-blobstore location without any errors.
This blobstore is a mounted managed Azure disk.
Okay, so this was my test bed but I needed to make it more robust and secure so decided to start again on the same VM.
I removed the GeoServer install.
Installed Tomcat9, secured it with certbot certs, redirected 8080 to 8443 and have a DNS domain name pointing to it, which all worked fine.
I dropped the geoserver.war file into the webapps folder, started Tomcat and geoserver is working under https at our domain name.
Except for this error message when trying to configure the blobstore…
Only obvious difference is the Tomcat approach.
So what could I be missing as have spent hours googling around this and changing users, groups, permissions etc… as it must be a Tomcat, Geoserver or GeoWebCache setting preventing that //geoserver-blobstore folder being seen a writable.
The folder is currently owner by root but I changed it to tomcat at one point but didn’t seem to make a difference.
GEOSERVER ERROR:
org.apache.wicket.WicketRuntimeException: Method onRequest of interface org.apache.wicket.behavior.IBehaviorListener targeted at org.apache.wicket.ajax.markup.html.form.AjaxSubmitLink$1@anonymised.com on component [AjaxSubmitLink [Component id = save]] threw an exception
at org.apache.wicket.RequestListenerInterface.internalInvoke(RequestListenerInterface.java:268)
at org.apache.wicket.RequestListenerInterface.invoke(RequestListenerInterface.java:241)
at org.apache.wicket.core.request.handler.ListenerInterfaceRequestHandler.invokeListener(ListenerInterfaceRequestHandler.java:248)
at org.apache.wicket.core.request.handler.ListenerInterfaceRequestHandler.respond(ListenerInterfaceRequestHandler.java:234)
at org.apache.wicket.request.cycle.RequestCycle$HandlerExecutor.respond(RequestCycle.java:895)
at org.apache.wicket.request.RequestHandlerStack.execute(RequestHandlerStack.java:64)
at org.apache.wicket.request.cycle.RequestCycle.execute(RequestCycle.java:265)
at org.apache.wicket.request.cycle.RequestCycle.processRequest(RequestCycle.java:222)
at org.apache.wicket.request.cycle.RequestCycle.processRequestAndDetach(RequestCycle.java:293)
at org.apache.wicket.protocol.http.WicketFilter.processRequestCycle(WicketFilter.java:261)
at org.apache.wicket.protocol.http.WicketFilter.processRequest(WicketFilter.java:203)
at org.apache.wicket.protocol.http.WicketServlet.doPost(WicketServlet.java:159)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:660)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:741)
at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:166)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:177)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:52)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:1040)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:943)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:1006)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:909)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:883)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:231)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:53)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:73)
at org.geoserver.ows.HTTPHeadersCollector.doFilter(HTTPHeadersCollector.java:48)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:70)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:43)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:39)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:320)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:71)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:127)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:91)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:75)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:119)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:200)
at org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter.doFilter(GeoServerUserNamePasswordAuthenticationFilter.java:122)
at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:158)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:105)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:215)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:178)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:142)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:358)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:271)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:102)
at org.geoserver.filters.XFrameOptionsFilter.doFilter(XFrameOptionsFilter.java:77)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:48)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:49)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:42)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:201)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:119)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:202)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:96)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:541)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:139)
at org.apache.catalina.valves.rewrite.RewriteValve.invoke(RewriteValve.java:555)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:92)
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:688)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:74)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:343)
at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:367)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:65)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:868)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1639)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.base/java.lang.Thread.run(Thread.java:829)
Caused by: java.lang.reflect.InvocationTargetException
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.apache.wicket.RequestListenerInterface.internalInvoke(RequestListenerInterface.java:258)
… 115 more
Caused by: org.geowebcache.config.ConfigurationPersistenceException: org.geowebcache.storage.StorageException: /geoserver-blobstore is not writable directory.
at org.geowebcache.config.XMLConfiguration.addBlobStore(XMLConfiguration.java:1023)
at org.geowebcache.storage.BlobStoreAggregator.addBlobStore(BlobStoreAggregator.java:261)
at org.geoserver.gwc.GWC.addBlobStore(GWC.java:2520)
at org.geoserver.gwc.web.blob.BlobStorePage.save(BlobStorePage.java:284)
at org.geoserver.gwc.web.blob.BlobStorePage$4.onSubmit(BlobStorePage.java:250)
at org.apache.wicket.ajax.markup.html.form.AjaxSubmitLink$1.onSubmit(AjaxSubmitLink.java:111)
at org.apache.wicket.ajax.form.AjaxFormSubmitBehavior$AjaxFormSubmitter.onSubmit(AjaxFormSubmitBehavior.java:218)
at org.apache.wicket.markup.html.form.Form.delegateSubmit(Form.java:1312)
at org.apache.wicket.markup.html.form.Form.process(Form.java:976)
at org.apache.wicket.markup.html.form.Form.onFormSubmitted(Form.java:797)
at org.apache.wicket.ajax.form.AjaxFormSubmitBehavior.onEvent(AjaxFormSubmitBehavior.java:174)
at org.apache.wicket.ajax.AjaxEventBehavior.respond(AjaxEventBehavior.java:155)
at org.apache.wicket.ajax.AbstractDefaultAjaxBehavior.onRequest(AbstractDefaultAjaxBehavior.java:601)
… 120 more
Caused by: org.geowebcache.storage.StorageException: /geoserver-blobstore is not writable directory.
at org.geowebcache.storage.blobstore.file.FileBlobStore.(FileBlobStore.java:110)
at org.geowebcache.config.FileBlobStoreInfo.createInstance(FileBlobStoreInfo.java:148)
at org.geowebcache.storage.CompositeBlobStore.loadBlobStore(CompositeBlobStore.java:434)
at org.geowebcache.storage.CompositeBlobStore.handleAddBlobStore(CompositeBlobStore.java:531)
at org.geowebcache.config.XMLConfiguration.lambda$addBlobStore$6(XMLConfiguration.java:1014)
at org.geowebcache.config.ListenerCollection.lambda$safeForEach$0(ListenerCollection.java:65)
at java.base/java.util.stream.ReferencePipeline$3$1.accept(ReferencePipeline.java:195)
at java.base/java.util.LinkedList$LLSpliterator.forEachRemaining(LinkedList.java:1239)
at java.base/java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:484)
at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:474)
at java.base/java.util.stream.ReduceOps$ReduceOp.evaluateSequential(ReduceOps.java:913)
at java.base/java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234)
at java.base/java.util.stream.ReferencePipeline.collect(ReferencePipeline.java:578)
at org.geowebcache.config.ListenerCollection.safeForEach(ListenerCollection.java:73)
at org.geowebcache.config.XMLConfiguration.addBlobStore(XMLConfiguration.java:1012)
… 132 more
It could be a tomcat 9 thing - see https://en-wiki.ikoula.com/en/Allow_a_Tomcat9_webapp_to_read/write_to_a_folder for a possible solution
Ian
Working now and your suggestion was part of the solution.
I had tried the tomcat service change but on double checking I had
instead of
ReadWritePaths=/geoserver-blobstore/
missing slash at end.
It didn’t work though on restart.
I then checked the other writable directories mentioned in that file and set the blobstore target to be the same as follows:
drwxrwxr-x 3 root tomcat 28 Feb 8 11:02 geoserver-blobstore
The 2 important bits in bold…set the folder writable to the tomcat group and set the folder group to tomcat.
Now its working.
Thanks for your help Ian.
Paul
Dr. Paul Lewis
Terrain_AI Data Platform Manager
Senior Research Fellow
National Centre for Geocomputation,
Office 2.13,
2nd Floor,
Iontas Building,
Maynooth University,
Maynooth,
Co.Kildare,
Ireland.
T: +353 1 7086187
E: paul.lewis@anonymised.com
W: https://www.maynoothuniversity.ie/national-centre-geocomputation-ncg/our-people
Sent: 08 February 2022 15:34
To: Paul Lewis Paul.Lewis@anonymised.com
Cc: geoserver-users@lists.sourceforge.net geoserver-users@anonymised.comsourceforge.net
Subject: [EXTERNAL] Re: [Geoserver-users] GeoServer 2.20.2 Blobstore Error
Warning
This email originated from outside of Maynooth University’s Mail System. Do not reply, click links or open attachments unless you recognise the sender and know the content is safe.
Ian
instead of
You could probably get away with changing the owner to tomcat rather than giving group write but it should work either way
Ian
