I do not quite understand what rights I have on my work computer so I changed to my home computer where I have full admin rights. I made installation a) as a normal user but running the installer as admin and b) when logged in as admin. The experience was better now but not perfect yet.
- The installer prints a lot of text about how the installation proceeds but it all disappears immediately when the installation is ready. It would be nice to have an option to get the messages into a file.
- I verified that the uninstaller does not remove GEOSERVER_DATA_DIR environment, even if the data directory folder is removed. Moreover, the installer does not set GEOSERVER_DATA_DIR right if some other location is specified for the data directory during the next installation. Because of that Geoserver does start, but without data even the new data directory is there.
- If installation is made into Program Files then only admin user can start the service manually with startup.bat. The reason is that Jetty wants to create a new directory into Program Files. It might be good to document this and suggest non-admins to use some other directory. ProgramData seems to be OK for the data directory.
- The installer still could did not install the Windows service for me. I could see some error messages flashing in the details window of the installer but I did not manage to read them properly. Maybe something about “invalid user or wrong password”. This happened even when I was logged in as admin.
-Jukka Rahkonen-
Lähettäjä: Jody Garnett <jody.garnett@…84…>
Lähetetty: maanantai 4. lokakuuta 2021 19.50
Vastaanottaja: Rahkonen Jukka (MML) <jukka.rahkonen@…6847…>
Kopio: GeoServer Users geoserver-users@lists.sourceforge.net
Aihe: Re: [Geoserver-users] GeoServer 2.20-RC windows installer testing requested
I think you need to be administrator to install a service? I am sorry I am not that familiar with windows permissions (power user vs administrator huh?)
Q: Did this situation you describe work with the previous geoserver 2.14 installer? Perhaps we can learn something.
ProgramData is the “approved” location for applications to manage their configuration; I often wonder why tomcat does not placed its webapps folder in ProgramData.
I am not sure what else I can determine due to your power user rights…
Jody
On Mon, Oct 4, 2021 at 12:56 AM Rahkonen Jukka (MML) <jukka.rahkonen@…6847…> wrote:
I was testing with my work computer as a localpower user. That user does not have full rights but I do not know exactly the limits. My observations:
- I used the Install as a service option but I could not start the service. Running the startService.bat did not start the service for me but yielded always these two lines
net start GeoServer
[Invalid service name] – translated from Finnish
Installer creates also the startup.bat file and next results are obtained by running that.
- Geoserver does not start if it is installed into the suggested location Program Files\GeoServer. With my rights it is not allowed to create a new layer during startup. Error:
Please wait while loading GeoServer…
2021-10-04 09:43:02.572:INFO::main: Logging initialized @1579ms to org.eclipse.jetty.util.log.StdErrLog
2021-10-04 09:43:02.873:INFO:oejs.Server:main: jetty-9.4.36.v20210114; built: 2021-01-14T16:44:28.689Z; git: 238ec6997c7806b055319a6d11f8ae7564adc0de; jvm 1.8.0_252-b09
2021-10-04 09:43:02.888:INFO:oejdp.ScanningAppProvider:main: Deployment monitor [file:///C:/Program%20Files/GeoServer/webapps/] at interval 1
2021-10-04 09:43:02.988:WARN:oejw.WebAppContext:main: Failed startup of context o.e.j.w.WebAppContext@…11119…{geoserver,/geoserver,null,STOPPED}{C:\Program Files\GeoServer\webapps\geoserver}
java.lang.IllegalStateException: Unable to create temp dir C:\Program Files\GeoServer\work\jetty-0_0_0_0-8080-geoserver-_geoserver-any-
- The first installation with the default settings created environmental variable GEOSERVER_DATA_DIR set to C:\ProgramData\GeoServer. It seems that uninstaller does not remove this variable and giving another path when running the installer again does not change GEOSERVER_DATA_DIR. Error:
04 lokakuuta 09:54:36 WARN [geoserver.platform] - Found Java environment variable GEOSERVER_DATA_DIR set to C:\ProgramData\GeoServer , but this path does not exist
04 lokakuuta 09:54:36 WARN [geoserver.platform] - Found System environment variable GEOSERVER_DATA_DIR set to C:\ProgramData\GeoServer , but this path does not exist
04 lokakuuta 09:54:36 INFO [geoserver.platform] - Falling back to embedded data directory: C:\ohjelmat\gs20rc\webapps\geoserver\data
However, the directory that I gave for the installer was created and populated. As a result Geoserver did not start right because it was searching the data_dir from a wrong place.
- Next I uninstalled again and removed the GEOSERVER_DATA_DIR environment variable before running the installer. I used a custom data_dir location but the installer did not set the variable at all. The data directory was created and populated and after setting the GEOSERVER_DATA_DIR manually I could run startup.bat and Geoserver 2.20-RC started.
Conclusion:
- There seems to be something to check with setting/removing/changing the location of the data_dir with installer and uninstaller
- The run as service alternative did not work at all for me
- Using directory “Program Files” may make troubles even the installation seems to be successful because Jetty wants to create a new directory when it starts. I do not know if using ProgramData may show similar issues because I used a custom data_dir location in most of my tests.
-Jukka Rahkonen-
Lähetetty: sunnuntai 3. lokakuuta 2021 20.26
Vastaanottaja: GeoServer Users <geoserver-users@lists.sourceforge.net>
Aihe: [Geoserver-users] GeoServer 2.20-RC windows installer testing requestedReporting in from the foss4g code sprint, and I noticed that Sander and Juan produces a GeoServer-install-2.20-RC.exe last week…
I do not have a windows environment handy, can I ask for testing please? Download is available from https://sourceforge.net/projects/geoserver/files/GeoServer/2.20-RC/
Jody Garnett
Jody Garnett
