[Geoserver-users] GeoServer 2.21 - Cascaded WMS returns Connection reset
Hello everyone,
I have a problem with Cascaded WMS’s on GeoServer 2.21.
Some layers frequently report the error ‘Connection reset’ while some layers works fine.
This problem does not occur in a previous version 2.17.1 (using the same geoserver_data directory).
I have tested the latest version 2.22.0 with the same result.
My environment is:
  • Windows Server 2016 Standard
  • Java: Eclipse Adoptium JRE 11.0.15.10 hotspot
  • Tomcat 9.0.65
  • GeoServer 2.21
Some Questions:
  • Is this a known problem?
  • Is there a way of increasing the logging in this area of GeoServer to see if the problem is in GeoServer or in the remote WMS server?
  • Any suggestions on how I can investigate this problem further?
Best Regards
Mattias Andrén
16 Dec 10:59:45 ERROR [data.ows] - Failed to execute request http://maps.lantmateriet.se/topowebb/wms/v1?REQUEST=GetMap&FORMAT=image/png&SRS=EPSG:3009&BBOX=147344.0,6594688.0,161680.0,6609024.0&VERSION=1.1.1&STYLES=&SERVICE=WMS&WIDTH=1024&HEIGHT=1024&TRANSPARENT=TRUE&LAYERS=topowebbkartan
16 Dec 10:59:45 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Error rendering coverage on the fast path
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:303)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:205)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:82)
at org.geoserver.wms.GetMap.executeInternal(GetMap.java:344)
at org.geoserver.wms.GetMap.run(GetMap.java:203)
at org.geoserver.wms.GetMap.run(GetMap.java:113)
at org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:250)
at jdk.internal.reflect.GeneratedMethodAccessor330.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.base/java.lang.reflect.Method.invoke(Unknown Source)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:344)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:198)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:163)
at org.geoserver.kml.WebMapServiceKmlInterceptor.invoke(WebMapServiceKmlInterceptor.java:38)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:186)
at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:57)
at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:32)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:74)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:43)
at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:29)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:212)
at com.sun.proxy.$Proxy125.getMap(Unknown Source)
at jdk.internal.reflect.GeneratedMethodAccessor347.invoke(Unknown Source)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:867)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:268)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:177)
at org.geoserver.gwc.GWC.dispatchOwsRequest(GWC.java:1368)
at org.geoserver.gwc.layer.GeoServerTileLayer.dispatchGetMap(GeoServerTileLayer.java:693)
at org.geoserver.gwc.layer.GeoServerTileLayer.getMetatilingReponse(GeoServerTileLayer.java:613)
at org.geoserver.gwc.layer.GeoServerTileLayer.seedTile(GeoServerTileLayer.java:865)
at org.geowebcache.seed.SeedTask.doActionInternal(SeedTask.java:141)
at org.geowebcache.seed.GWCTask.doAction(GWCTask.java:78)
at org.geowebcache.seed.MTSeeder.call(MTSeeder.java:34)
at org.geowebcache.seed.MTSeeder.call(MTSeeder.java:23)
at org.geoserver.gwc.seed.SeederThreadLocalTransferExecutor.lambda$submit$1(SeederThreadLocalTransferExecutor.java:53)
at java.base/java.util.concurrent.FutureTask.run(Unknown Source)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.base/java.lang.Thread.run(Unknown Source)
Caused by: org.geoserver.platform.ServiceException: java.net.SocketException: Connection reset
at org.geoserver.wms.map.DirectRasterRenderer.render(DirectRasterRenderer.java:301)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:301)
… 43 more
Caused by: java.net.SocketException: Connection reset
at java.base/java.net.SocketInputStream.read(Unknown Source)
at org.apache.http.impl.io.SessionInputBufferImpl.streamRead(SessionInputBufferImpl.java:137)
at org.apache.http.impl.io.SessionInputBufferImpl.fillBuffer(SessionInputBufferImpl.java:153)
at org.apache.http.impl.io.SessionInputBufferImpl.readLine(SessionInputBufferImpl.java:282)
at org.apache.http.impl.conn.DefaultHttpResponseParser.parseHead(DefaultHttpResponseParser.java:138)
at org.apache.http.impl.conn.DefaultHttpResponseParser.parseHead(DefaultHttpResponseParser.java:56)
at org.apache.http.impl.io.AbstractMessageParser.parse(AbstractMessageParser.java:259)
at org.apache.http.impl.DefaultBHttpClientConnection.receiveResponseHeader(DefaultBHttpClientConnection.java:163)
at org.apache.http.impl.conn.CPoolProxy.receiveResponseHeader(CPoolProxy.java:157)
at org.apache.http.protocol.HttpRequestExecutor.doReceiveResponse(HttpRequestExecutor.java:273)
at org.apache.http.protocol.HttpRequestExecutor.execute(HttpRequestExecutor.java:125)
at org.apache.http.impl.execchain.MainClientExec.execute(MainClientExec.java:272)
at org.apache.http.impl.execchain.ProtocolExec.execute(ProtocolExec.java:186)
at org.apache.http.impl.execchain.RetryExec.execute(RetryExec.java:89)
at org.apache.http.impl.execchain.RedirectExec.execute(RedirectExec.java:110)
at org.apache.http.impl.client.InternalHttpClient.doExecute(InternalHttpClient.java:185)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:83)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:56)
at org.geotools.http.commons.MultithreadedHttpClient.executeMethod(MultithreadedHttpClient.java:174)
at org.geotools.http.commons.MultithreadedHttpClient.get(MultithreadedHttpClient.java:206)
at org.geotools.http.commons.MultithreadedHttpClient.get(MultithreadedHttpClient.java:186)
at org.geotools.data.ows.AbstractOpenWebService.internalIssueRequest(AbstractOpenWebService.java:455)
at org.geotools.ows.wms.WebMapServer.issueRequest(WebMapServer.java:454)
at org.geotools.ows.wms.map.WMSCoverageReader.getMap(WMSCoverageReader.java:338)
at org.geotools.ows.wms.map.WMSCoverageReader.read(WMSCoverageReader.java:321)
at org.geotools.renderer.lite.gridcoverage2d.GridCoverageReaderHelper.readSingleCoverage(GridCoverageReaderHelper.java:642)
at org.geotools.renderer.lite.gridcoverage2d.GridCoverageReaderHelper.readCoverage(GridCoverageReaderHelper.java:207)
at org.geotools.renderer.lite.gridcoverage2d.GridCoverageRenderer.renderImage(GridCoverageRenderer.java:705)
at org.geotools.renderer.lite.gridcoverage2d.GridCoverageRenderer.renderImage(GridCoverageRenderer.java:668)
at org.geoserver.wms.map.DirectRasterRenderer.readWithProjectionHandling(DirectRasterRenderer.java:720)
at org.geoserver.wms.map.DirectRasterRenderer.render(DirectRasterRenderer.java:245)
… 44 more
Mattias:
There is a way to increase the logging, see instruction here: https://docs.geoserver.org/stable/en/user/configuration/logging.html
Quickly the idea would be to make a custom logging configuration (copy one of the existing ones into a new file), and add some lines to log wms client interaction…
So the instructions have this example:
GeoTools Logger names match up with the package names in the project javadocs overview.
As an example package org.geotools.data.shapefile is listed, allowing level of shapefile logging to be controlled:
So I think you could use “org.geotools.ows.wms”:
Let us know what you find?
Jody Garnett
Thanks!
I tried increasing the logging as you suggested below, and It works.
I can now see the requests that are made.
I do not get any more information why the request is failing though.
Best Regards
Mattias Andrén
Från: Jody Garnett jody.garnett@anonymised.com
Skickat: den 18 december 2022 00:41
Till: Mattias Andrén mattias.andren@anonymised.com
Kopia: geoserver-users@lists.sourceforge.net
Ämne: Re: [Geoserver-users] GeoServer 2.21 - Cascaded WMS returns Connection reset
Mattias:
Jody Garnett
On Fri, Dec 16, 2022 at 6:05 AM Mattias Andrén via Geoserver-users <geoserver-users@lists.sourceforge.net> wrote:
Hello everyone,
My environment is:
  • Tomcat 9.0.65
  • GeoServer 2.21
Some Questions:
Best Regards
Mattias Andrén
… 43 more
… 44 more
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
If you make the requests you see logged yourself (using a browser or cURL) … do they work?
Other options:
  • are you comfortable with wireshark or similar to watch the two programs talk to each other?
  • is some kind of firewall watching and closing down connections?
You indicate you are upgrading from 2.17.1 … we did provide the option of using a different HTTP client in the GeoTools Java library used for WMS access.
I am not sure how you configure that from GeoServer (there should be a choice between the built-in java URL and HTTP connections, and the Apache HTTP library).
Jody Garnett
I was about to suggest the same. The default is with the Apache HTTP library with a connection pool and persistent connections,
which is faster but less reliable. The alternative is to turn that off, creating a new HTTP connection for each request.
To do so, un-check the “HTTP connection pooling” option:
https://docs.geoserver.org/latest/en/user/data/cascaded/wms.html#adding-an-external-wms
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
Thanks for the suggested workaround!
I have unchecked the “HTTP connection pooling” option as suggested below and do not get the “Connection reset” error any more.
I occasionally get a “read timeout” error, but not even close so many as before.
Is the performance affected when the “HTTP connection pooling” is unchecked?
Best Regards
Mattias Andrén
Från: Andrea Aime <andrea.aime@anonymised.com…>
Skickat: den 20 december 2022 10:37
Till: Jody Garnett jody.garnett@anonymised.com
Kopia: Mattias Andrén mattias.andren@anonymised.com; geoserver-users@lists.sourceforge.net
On Tue, Dec 20, 2022 at 9:54 AM Jody Garnett <jody.garnett@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
