Looks like GeoServer in 2.3 version does not compute Lat/Lon Bounding Box if SRID for PostGIS table is -1 (not defined). Even if in New layer publishing menu I define „Declared SRS“ and try to „Compute from native bounds“ the error apears: „Error computing the geographic bounds:transform error“
In 2.3 beta – the same problem.
2.2 version was able to compute.
If in Postgis geometry_column SRID is defined – GeoServer calculates Lat/Lon Bounding Box.
I don‘t know if it is a bug or change of funcionality, but it is inconvenience.
Pagarbiai,
Paulius Litvinas
GIS konsultantas, UAB “InfoEra”
Mob.: +370 656 10089
Tel.: (370 5) 278 84 56
Faks.: (370 5) 278 47 23
paulius@anonymised.com
S. Žukausko g. 17, LT-08234, Vilnius
www.infoera.lt ; www.gps.lt
On Fri, Mar 22, 2013 at 8:19 AM, Paulius Litvinas <paulius@anonymised.com> wrote:
I don‘t know if it is a bug or change of functionality, but it is inconvenience.
Please open a bug report on jira.codehaus.org.
It’s infortunate to discover these once the final release is out, but unfortunately it seems few people check
to the betas or the RCs
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
