[Geoserver-users] GeoServer 2.3.0 GDAL extension
Hello everyone,
I have tried to install the GDAL extension following the instructions at http://docs.geoserver.org/stable/en/user/data/raster/gdal.html.
I have followed each step carefully, but after restarting no new raster formats are available. Looking into the logs via webadmin I can’t see the error "it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL WARNING: Native library load failed.java.lang.UnsatisfiedLinkError: no gdaljni in java.library.path"
Or anything related to gdal.
The system is a Debian 6.0 2.6.32-5-amd64
java version “1.6.0_18”
OpenJDK Runtime Environment (IcedTea6 1.8.13) (6b18-1.8.13-0+squeeze2)
OpenJDK 64-Bit Server VM (build 14.0-b16, mixed mode)
and Tomcat 7.0.35
Am I missing something?
Thanks in advance
Ciao Santiago,
did you try to run the gdalinfo tool to check that the nativelibs
where properly installed?
It should be part of the native libs as well. Moreover, make sure
there is no other installation on the same server as
this might cause problems.
Simone Giannecchini
Our support, Your Success! Visit http://opensdi.geo-solutions.it for
more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
On Tue, Mar 19, 2013 at 11:58 AM, Santiago Timón <stimonmail@anonymised.com> wrote:
Hello everyone,
formats are available. Looking into the logs via webadmin I can't see the
java.library.path"
java version "1.6.0_18"
and Tomcat 7.0.35
Thanks in advance
Everyone hates slow websites. So do we.
Make your web apps faster with AppDynamics
Download AppDynamics Lite for free today:
http://p.sf.net/sfu/appdyn_d2d_mar
Geoserver-users mailing list
Does gdalinfo need to be globally available? if yes, what are the steps?
gdalinfo fails :frowning:
paisaje@anonymised.com:~/gdal$ ./gdalinfo
./gdalinfo: /usr/lib/libstdc++.so.6: version `GLIBCXX_3.4.14’ not found (required by libNCSEcw.so.0)
Do I need to install GLIBCXX_3.4.14? To make things more complicated, I do not have sudo privileges in the system I am deploying the server…
2013/3/19 Simone Giannecchini <simone.giannecchini@anonymised.com>
Ciao Santiago,
Simone Giannecchini
more information.
@simogeo
Founder/Director
Hello everyone,
error “it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL WARNING:
java.library.path”
and Tomcat 7.0.35
Thanks in advance
It looks like the combination of gcc and libstdc++ on your system does
not match the ones we built ourselves.
Let' see if Daniele has any suggestions.
Simone Giannecchini
more information.
@simogeo
Founder/Director
On Tue, Mar 19, 2013 at 2:00 PM, Santiago Timón <stimonmail@anonymised.com> wrote:
./gdalinfo: /usr/lib/libstdc++.so.6: version `GLIBCXX_3.4.14' not found
not have sudo privileges in the system I am deploying the server...
Ciao Santiago,
Simone Giannecchini
more information.
@simogeo
Founder/Director
wrote:
> Hello everyone,
> the
> WARNING:
> java.library.path"
> and Tomcat 7.0.35
> Thanks in advance
> Geoserver-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
Hi Santiago,
These GLIBCXX_ issues have been previously sometime encountered and reported by users which were attempting to use the linux libraries on some particular distro.
These are mainly due to the underlying base libs being not available/or differents on that specific distro with respect to the Centos/Ubuntu machines where they have been builts.
Which version did you download?
Anyway, after some attempts we have concluded that some specific systems requires it specific GDAL builds to make sure to solve this kind of issue with the internal libraries.
You could maybe check your GLIBCXX version and then check the ones requested by the available libs and if none fits your needs, I think the solution would be that you build GDAL on your machine.
Please, let us know.
Daniele
Ciao Santiago,
Simone Giannecchini
more information.
@simogeo
Founder/Director
Hello everyone,
java.library.path”
and Tomcat 7.0.35
Thanks in advance
Thank you very much for your help.
It seems I don’t have libstdc installed:
paisaje@anonymised.com:~$ /usr/lib/lib
libblas/ libnvidia-compiler.so.195.36.24
libcanberra-0.24/ libOpenCL.so.1.0
libfakeroot/ libOpenCL.so.1.0.0
libgconf2-4/ libproxy/
libgksu/ libtrash/
libglade/ libv4l/
libgnome-window-settings1/ libvdpau.so.1
libgphoto2/ libvdpau.so.195.36.24
libgphoto2_port/ libvisual-0.4/
libgtk2.0-0/ libvte9/
libnfsidmap/
Maybe I need to install it before and if still doesn’t work build GDAL from source.
Any tips I should follow?
2013/3/19 Daniele Romagnoli <daniele.romagnoli@anonymised.com07…>
Hi Santiago,
Daniele
Ing. Daniele Romagnoli
Senior Software Engineer
Ciao Santiago,
Simone Giannecchini
more information.
@simogeo
Founder/Director
Hello everyone,
java.library.path”
and Tomcat 7.0.35
Thanks in advance
Hi Santiago,
libgksu/ libtrash/
libglade/ libv4l/
libnfsidmap/
Did you also try a “locate libstdc++”?
Daniele
2013/3/19 Daniele Romagnoli <daniele.romagnoli@anonymised.com>
Hi Santiago,
Daniele
Ciao Santiago,
Simone Giannecchini
more information.
@simogeo
Founder/Director
Hello everyone,
java.library.path”
and Tomcat 7.0.35
Thanks in advance
I didn’t
paisaje@anonymised.com:~$ locate libstdc++
/usr/lib/libstdc++.so.6.0.13
/usr/lib/gcc/x86_64-linux-gnu/4.4/libstdc++.a
/usr/lib/gcc/x86_64-linux-gnu/4.4/libstdc++.so
/usr/share/doc/libstdc++6
/usr/share/doc/libstdc++6-4.4-dev
/usr/share/doc/gcc-4.4-base/C++/README.libstdc+±baseline
/usr/share/doc/gcc-4.4-base/C++/changelog.libstdc++.gz
/usr/share/doc/gcc-4.4-base/C++/libstdc++_symbols.txt
/usr/share/doc/gcc-4.4-base/test-summaries/libstdc++.sum.gz
/var/lib/dpkg/info/libstdc++6-4.4-dev.list
/var/lib/dpkg/info/libstdc++6-4.4-dev.md5sums
/var/lib/dpkg/info/libstdc++6.list
/var/lib/dpkg/info/libstdc++6.md5sums
/var/lib/dpkg/info/libstdc++6.postinst
/var/lib/dpkg/info/libstdc++6.postrm
/var/lib/dpkg/info/libstdc++6.shlibs
/var/lib/dpkg/info/libstdc++6.symbols
As you can see I am no linux master :smiley:
So the library actually exists in the system. Is it an env variable issue? Or I should start reading the documentation on how to build GDAL?
Thanks Daniele.
Hi Santiago,
On Tue, Mar 19, 2013 at 4:58 PM, Santiago Timón <stimonmail@anonymised.com> wrote:
libgksu/ libtrash/
libglade/ libv4l/
libnfsidmap/
Daniele
Hi Santiago,
Daniele
Ciao Santiago,
Simone Giannecchini
more information.
@simogeo
Founder/Director
Hello everyone,
java.library.path”
and Tomcat 7.0.35
Thanks in advance
You may try a final:
“strings /usr/lib/libstdc++.so.6 | grep LIBCXX”
To check which GLIBCXX is available on your system.
(You may also try the same against /usr/lib/gcc/x86_64-linux-gnu/4.4/libstdc++.so)
If they are old, you can consider start thinking about building GDAL on your machine :slight_smile:
Daniele
Hi Santiago,
On Tue, Mar 19, 2013 at 4:58 PM, Santiago Timón <stimonmail@anonymised.com.84…> wrote:
libgksu/ libtrash/
libglade/ libv4l/
libnfsidmap/
Daniele
Hi Santiago,
Daniele
Ciao Santiago,
Simone Giannecchini
more information.
@simogeo
Founder/Director
Hello everyone,
java.library.path”
and Tomcat 7.0.35
Thanks in advance
Done:
paisaje@anonymised.com:~$ strings /usr/lib/libstdc++.so.6 | grep LIBCXX
GLIBCXX_3.4
GLIBCXX_3.4.1
GLIBCXX_3.4.2
GLIBCXX_3.4.3
GLIBCXX_3.4.4
GLIBCXX_3.4.5
GLIBCXX_3.4.6
GLIBCXX_3.4.7
GLIBCXX_3.4.8
GLIBCXX_3.4.9
GLIBCXX_3.4.10
GLIBCXX_3.4.11
GLIBCXX_3.4.12
GLIBCXX_3.4.13
GLIBCXX_FORCE_NEW
GLIBCXX_DEBUG_MESSAGE_LENGTH
It seems GLIBCXX_3.4.14 is actually missing. Is there still a chance to fix this without building GDAL by myself?
cheers,
Daniele
On Tue, Mar 19, 2013 at 5:18 PM, Santiago Timón <stimonmail@anonymised.com> wrote:
I didn’t
Thanks Daniele.
Hi Santiago,
libgksu/ libtrash/
libglade/ libv4l/
libnfsidmap/
Daniele
Hi Santiago,
Daniele
Ciao Santiago,
Simone Giannecchini
more information.
@simogeo
Founder/Director
Hello everyone,
java.library.path”
and Tomcat 7.0.35
Thanks in advance
Done:
GLIBCXX_3.4
GLIBCXX_3.4.1
GLIBCXX_3.4.2
GLIBCXX_3.4.3
GLIBCXX_3.4.4
GLIBCXX_3.4.5
GLIBCXX_3.4.6
GLIBCXX_3.4.7
GLIBCXX_3.4.8
GLIBCXX_3.4.9
GLIBCXX_3.4.10
GLIBCXX_3.4.11
GLIBCXX_3.4.12
GLIBCXX_3.4.13
GLIBCXX_FORCE_NEW
Mmm. I have no idea on that. I think someone already tried similar tests on old libs with no success (However I have never tried by myself).
Daniele
Daniele
I didn’t
Thanks Daniele.
Hi Santiago,
libgksu/ libtrash/
libglade/ libv4l/
libnfsidmap/
Daniele
Hi Santiago,
Daniele
Ciao Santiago,
Simone Giannecchini
more information.
@simogeo
Founder/Director
Hello everyone,
java.library.path”
and Tomcat 7.0.35
Thanks in advance
Thanks Daniele, I will try to build GDAL and see if this does the trick
On Tue, Mar 19, 2013 at 6:01 PM, Santiago Timón <stimonmail@anonymised.com…84…> wrote:
Done:
GLIBCXX_3.4
GLIBCXX_3.4.1
GLIBCXX_3.4.2
GLIBCXX_3.4.3
GLIBCXX_3.4.4
GLIBCXX_3.4.5
GLIBCXX_3.4.6
GLIBCXX_3.4.7
GLIBCXX_3.4.8
GLIBCXX_3.4.9
GLIBCXX_3.4.10
GLIBCXX_3.4.11
GLIBCXX_3.4.12
GLIBCXX_3.4.13
GLIBCXX_FORCE_NEW
Daniele
cheers,
Daniele
I didn’t
Thanks Daniele.
Hi Santiago,
libgksu/ libtrash/
libglade/ libv4l/
libnfsidmap/
Daniele
Hi Santiago,
Daniele
Ciao Santiago,
Simone Giannecchini
more information.
@simogeo
Founder/Director
Hello everyone,
java.library.path”
and Tomcat 7.0.35
Thanks in advance
Hi again,
Finally I decided to try in another server, which has Ubuntu 12.10 instead of Debian 6, but still I can’t make it work.
Instead of installing GDAL as the documentation says, I have installed it via synaptic gdal 1.9.0-3. Maybe this is the problem… If I run gdalinfo it works fine, without any library error:
administrador@anonymised.com:~/apache-tomcat-7.0.35/bin$ gdalinfo
Usage: gdalinfo [–help-general] [-mm] [-stats] [-hist] [-nogcp] [-nomd]
[-norat] [-noct] [-nofl] [-checksum] [-proj4] [-mdd domain]*
[-sd subdataset] datasetname
I don’t know how to run the formats option though.
The libstdc++ libraries are in:
strings /usr/lib/x86_64-linux-gnu/libstdc++.so.6 | grep LIBCXX
GLIBCXX_3.4
GLIBCXX_3.4.1
GLIBCXX_3.4.2
GLIBCXX_3.4.3
GLIBCXX_3.4.4
GLIBCXX_3.4.5
GLIBCXX_3.4.6
GLIBCXX_3.4.7
GLIBCXX_3.4.8
GLIBCXX_3.4.9
GLIBCXX_3.4.10
GLIBCXX_3.4.11
GLIBCXX_3.4.12
GLIBCXX_3.4.13
GLIBCXX_3.4.14
GLIBCXX_3.4.15
GLIBCXX_3.4.16
GLIBCXX_3.4.17
The env variables are set to:
administrador@anonymised.com:~/apache-tomcat-7.0.35/bin$ echo $LD_LIBRARY_PATH
/usr/lib/
administrador@anonymised.com:~/apache-tomcat-7.0.35/bin$ echo $GDAL_DATA
/home/administrador/gdal-data
Geoserver says nothing about gdal in the log, but no clue about new raster formats…
I feel I’m getting close, hope you can help me with the final push :slight_smile:
Santi
2013/3/19 Santiago Timón <stimonmail@anonymised.com>
On Tue, Mar 19, 2013 at 6:01 PM, Santiago Timón <stimonmail@anonymised.com> wrote:
Done:
GLIBCXX_3.4
GLIBCXX_3.4.1
GLIBCXX_3.4.2
GLIBCXX_3.4.3
GLIBCXX_3.4.4
GLIBCXX_3.4.5
GLIBCXX_3.4.6
GLIBCXX_3.4.7
GLIBCXX_3.4.8
GLIBCXX_3.4.9
GLIBCXX_3.4.10
GLIBCXX_3.4.11
GLIBCXX_3.4.12
GLIBCXX_3.4.13
GLIBCXX_FORCE_NEW
Daniele
cheers,
Daniele
I didn’t
Thanks Daniele.
Hi Santiago,
libgksu/ libtrash/
libglade/ libv4l/
libnfsidmap/
Daniele
Hi Santiago,
Daniele
Ciao Santiago,
Simone Giannecchini
more information.
@simogeo
Founder/Director
Hello everyone,
java.library.path”
and Tomcat 7.0.35
Thanks in advance
Ciao Santiago,
quoting your email "Instead of installing GDAL as the documentation
problem...".
Well, for sure _not_ doing what the doc says will not help to make
things work :slight_smile:
Jocking aside, I am not sure you wouold get the JNI bindings this way.
Look around for an so like libgdaljni.so or similar.
Moreover, i would check the geoserver log to see if you can find a
message (at the top, after start up) saying something about gdal (it
should complain about
not finding the JNI bindings).
Btw, I am assuming you dropped the jars into the WEB-INF/lib dir and
you restarted GeoServer properly.
Simone Giannecchini
more information.
@simogeo
Founder/Director
Since I see from your output that you now have GLIBCXX_3.4.14 (on Ubuntu 12.10), I would try again with the available 1.9.2 downloads.
I’m not sure about the differences between 1.9.0-3 and 1.9.2 but I think the version you have doesn’t contain the JAVA JNI counterpart which is required to use the drivers on GeoServer.
Anyway, if you want to list the GDAL available formats, you can call “gdalinfo --formats”
Moreover, we have also recently added some selfcontained scripts to the available download.
They allow to do quick tests of the java bindings.
There is a javainfo folder containing a gdalinfo.sh script which invokes the java class (by using the available java bindings) to do the same things the standard gdalinfo app will do.
Hope this helps.
Daniele
On Wed, Apr 3, 2013 at 4:53 PM, Santiago Timón <stimonmail@anonymised.com> wrote:
Hi again,
GLIBCXX_3.4
GLIBCXX_3.4.1
GLIBCXX_3.4.2
GLIBCXX_3.4.3
GLIBCXX_3.4.4
GLIBCXX_3.4.5
GLIBCXX_3.4.6
GLIBCXX_3.4.7
GLIBCXX_3.4.8
GLIBCXX_3.4.9
GLIBCXX_3.4.10
GLIBCXX_3.4.11
GLIBCXX_3.4.12
GLIBCXX_3.4.13
GLIBCXX_3.4.14
GLIBCXX_3.4.15
GLIBCXX_3.4.16
GLIBCXX_3.4.17
/usr/lib/
Santi
Done:
GLIBCXX_3.4
GLIBCXX_3.4.1
GLIBCXX_3.4.2
GLIBCXX_3.4.3
GLIBCXX_3.4.4
GLIBCXX_3.4.5
GLIBCXX_3.4.6
GLIBCXX_3.4.7
GLIBCXX_3.4.8
GLIBCXX_3.4.9
GLIBCXX_3.4.10
GLIBCXX_3.4.11
GLIBCXX_3.4.12
GLIBCXX_3.4.13
GLIBCXX_FORCE_NEW
Daniele
cheers,
Daniele
I didn’t
Thanks Daniele.
Hi Santiago,
libgksu/ libtrash/
libglade/ libv4l/
libnfsidmap/
Daniele
Hi Santiago,
Daniele
Ciao Santiago,
Simone Giannecchini
more information.
@simogeo
Founder/Director
Hello everyone,
java.library.path”
and Tomcat 7.0.35
Thanks in advance
I have switchted to gdal192, set the LD_LIBRARY_PATH to the directory I extracted it and still doesn’t work :frowning:
03-abr-2013 18:34:19 it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
ADVERTENCIA: Failed to load the GDAL native libs. This is not a problem unless you need to use the GDAL plugins: they won’t be enabled.
Now I have followed all the steps I think…
2013/4/3 Daniele Romagnoli <daniele.romagnoli@anonymised.com>
Hope this helps.
Daniele
Hi again,
GLIBCXX_3.4
GLIBCXX_3.4.1
GLIBCXX_3.4.2
GLIBCXX_3.4.3
GLIBCXX_3.4.4
GLIBCXX_3.4.5
GLIBCXX_3.4.6
GLIBCXX_3.4.7
GLIBCXX_3.4.8
GLIBCXX_3.4.9
GLIBCXX_3.4.10
GLIBCXX_3.4.11
GLIBCXX_3.4.12
GLIBCXX_3.4.13
GLIBCXX_3.4.14
GLIBCXX_3.4.15
GLIBCXX_3.4.16
GLIBCXX_3.4.17
/usr/lib/
Santi
Done:
GLIBCXX_3.4
GLIBCXX_3.4.1
GLIBCXX_3.4.2
GLIBCXX_3.4.3
GLIBCXX_3.4.4
GLIBCXX_3.4.5
GLIBCXX_3.4.6
GLIBCXX_3.4.7
GLIBCXX_3.4.8
GLIBCXX_3.4.9
GLIBCXX_3.4.10
GLIBCXX_3.4.11
GLIBCXX_3.4.12
GLIBCXX_3.4.13
GLIBCXX_FORCE_NEW
Daniele
cheers,
Daniele
I didn’t
Thanks Daniele.
Hi Santiago,
libgksu/ libtrash/
libglade/ libv4l/
libnfsidmap/
Daniele
Hi Santiago,
Daniele
Ciao Santiago,
Simone Giannecchini
more information.
@simogeo
Founder/Director
Hello everyone,
java.library.path”
and Tomcat 7.0.35
Thanks in advance
Hi Santiago,
can you try to see if the java part is working standalone?
The folder where you have extracted the download should contain a javainfo subfolder.
Can you try this?
  • go in that javainfo folder
  • run “./gdalinfo.sh --version”
  • run “./gdalinfo.sh --formats”
And report me the output of those 2 commands?
If everything is working fine, the java part is working so you probably need to check the configuration used to startup geoserver.
Could you also please list the content of your geoserver webapp WEB-INF/lib folder?
Best Regards,
Daniele
On Wed, Apr 3, 2013 at 6:45 PM, Santiago Timón <stimonmail@anonymised.com> wrote:
Hope this helps.
Daniele
Hi again,
GLIBCXX_3.4
GLIBCXX_3.4.1
GLIBCXX_3.4.2
GLIBCXX_3.4.3
GLIBCXX_3.4.4
GLIBCXX_3.4.5
GLIBCXX_3.4.6
GLIBCXX_3.4.7
GLIBCXX_3.4.8
GLIBCXX_3.4.9
GLIBCXX_3.4.10
GLIBCXX_3.4.11
GLIBCXX_3.4.12
GLIBCXX_3.4.13
GLIBCXX_3.4.14
GLIBCXX_3.4.15
GLIBCXX_3.4.16
GLIBCXX_3.4.17
/usr/lib/
Santi
Done:
GLIBCXX_3.4
GLIBCXX_3.4.1
GLIBCXX_3.4.2
GLIBCXX_3.4.3
GLIBCXX_3.4.4
GLIBCXX_3.4.5
GLIBCXX_3.4.6
GLIBCXX_3.4.7
GLIBCXX_3.4.8
GLIBCXX_3.4.9
GLIBCXX_3.4.10
GLIBCXX_3.4.11
GLIBCXX_3.4.12
GLIBCXX_3.4.13
GLIBCXX_FORCE_NEW
Daniele
cheers,
Daniele
I didn’t
Thanks Daniele.
Hi Santiago,
libgksu/ libtrash/
libglade/ libv4l/
libnfsidmap/
Daniele
Hi Santiago,
Daniele
Ciao Santiago,
Simone Giannecchini
more information.
@simogeo
Founder/Director
Hello everyone,
java.library.path”
and Tomcat 7.0.35
Thanks in advance
Hi Daniele,
I am very happy to say that, at least, the plugin is working. I was about to write to tell you, and ask another question :slight_smile:
the command under javainfo works:
administrador@anonymised.com:~/gdal192/javainfo$ ./gdalinfo.sh --formats
Supported Formats:
VRT (rw+v): Virtual Raster
GTiff (rw+v): GeoTIFF
NITF (rw+v): National Imagery Transmission Format
RPFTOC (rov): Raster Product Format TOC format
ECRGTOC (rov): ECRG TOC format
HFA (rw+v): Erdas Imagine Images (.img)
SAR_CEOS (rov): CEOS SAR Image
CEOS (rov): CEOS Image
JAXAPALSAR (rov): JAXA PALSAR Product Reader (Level 1.1/1.5)
GFF (rov): Ground-based SAR Applications Testbed File Format (.gff)
ELAS (rw+v): ELAS
AIG (rov): Arc/Info Binary Grid
AAIGrid (rwv): Arc/Info ASCII Grid
GRASSASCIIGrid (rov): GRASS ASCII Grid
SDTS (rov): SDTS Raster
DTED (rwv): DTED Elevation Raster
PNG (rwv): Portable Network Graphics
JPEG (rwv): JPEG JFIF
MEM (rw+): In Memory Raster
JDEM (rov): Japanese DEM (.mem)
GIF (rwv): Graphics Interchange Format (.gif)
BIGGIF (rov): Graphics Interchange Format (.gif)
ESAT (ro): Envisat Image Format
BSB (rov): Maptech BSB Nautical Charts
XPM (rwv): X11 PixMap Format
BMP (rw+v): MS Windows Device Independent Bitmap
DIMAP (rov): SPOT DIMAP
AirSAR (ro): AirSAR Polarimetric Image
RS2 (ro): RadarSat 2 XML Product
PCIDSK (rw+v): PCIDSK Database File
PCRaster (rw): PCRaster Raster File
ILWIS (rw+v): ILWIS Raster Map
SGI (rw+): SGI Image File Format 1.0
SRTMHGT (rwv): SRTMHGT File Format
Leveller (rw+): Leveller heightfield
Terragen (rw+): Terragen heightfield
ISIS3 (rov): USGS Astrogeology ISIS cube (Version 3)
ISIS2 (rw+v): USGS Astrogeology ISIS cube (Version 2)
PDS (rov): NASA Planetary Data System
TIL (rov): EarthWatch .TIL
ERS (rw+v): ERMapper .ers Labelled
ECW (rw): ERDAS Compressed Wavelets (SDK 3.x)
JP2ECW (rw+v): ERDAS JPEG2000 (SDK 3.x)
L1B (rov): NOAA Polar Orbiter Level 1b Data Set
FIT (rwv): FIT Image
MrSID (rov): Multi-resolution Seamless Image Database (MrSID)
JP2MrSID (rov): MrSID JPEG2000
RMF (rw+v): Raster Matrix Format
MSGN (ro): EUMETSAT Archive native (.nat)
RST (rw+v): Idrisi Raster A.1
INGR (rw+v): Intergraph Raster
GSAG (rwv): Golden Software ASCII Grid (.grd)
GSBG (rw+v): Golden Software Binary Grid (.grd)
GS7BG (rov): Golden Software 7 Binary Grid (.grd)
COSAR (ro): COSAR Annotated Binary Matrix (TerraSAR-X)
TSX (rov): TerraSAR-X Product
COASP (ro): DRDC COASP SAR Processor Raster
R (rwv): R Object Data Store
PNM (rw+v): Portable Pixmap Format (netpbm)
DOQ1 (rov): USGS DOQ (Old Style)
DOQ2 (rov): USGS DOQ (New Style)
ENVI (rw+v): ENVI .hdr Labelled
EHdr (rw+v): ESRI .hdr Labelled
GenBin (rov): Generic Binary (.hdr Labelled)
PAux (rw+): PCI .aux Labelled
MFF (rw+): Vexcel MFF Raster
MFF2 (rw+): Vexcel MFF2 (HKV) Raster
FujiBAS (ro): Fuji BAS Scanner Image
GSC (rov): GSC Geogrid
FAST (rov): EOSAT FAST Format
BT (rw+v): VTP .bt (Binary Terrain) 1.3 Format
LAN (rw+v): Erdas .LAN/.GIS
CPG (ro): Convair PolGASP
IDA (rw+): Image Data and Analysis
NDF (rov): NLAPS Data Format
EIR (rov): Erdas Imagine Raw
DIPEx (rov): DIPEx
LCP (rov): FARSITE v.4 Landscape File (.lcp)
GTX (rw+v): NOAA Vertical Datum .GTX
LOSLAS (rov): NADCON .los/.las Datum Grid Shift
NTv2 (rw+v): NTv2 Datum Grid Shift
ACE2 (rov): ACE2
SNODAS (rov): Snow Data Assimilation System
RIK (ro): Swedish Grid RIK (.rik)
USGSDEM (rwv): USGS Optional ASCII DEM (and CDED)
GXF (ro): GeoSoft Grid Exchange Format
NWT_GRD (rov): Northwood Numeric Grid Format .grd/.tab
NWT_GRC (rov): Northwood Classified Grid Format .grc/.tab
ADRG (rw+v): ARC Digitized Raster Graphics
SRP (rov): Standard Raster Product (ASRP/USRP)
BLX (rw): Magellan topo (.blx)
SAGA (rw+v): SAGA GIS Binary Grid (.sdat)
KMLSUPEROVERLAY (rwv): Kml Super Overlay
XYZ (rwv): ASCII Gridded XYZ
HF2 (rwv): HF2/HFZ heightfield raster
OZI (rov): OziExplorer Image File
CTG (rov): USGS LULC Composite Theme Grid
E00GRID (rov): Arc/Info Export E00 GRID
ZMap (rwv): ZMap Plus Grid
NGSGEOID (rov): NOAA NGS Geoid Height Grids
[-norat] [-noct] [-mdd domain]* [-checksum] datasetname
No gdal jni error in the log, but I still can’t see any new raster format. The log now indicates that some (I assume the most if not everyone) formats are not available, for example:
2013-04-03 20:01:18,600 DEBUG [gdal.ecw] - ECWFormatFactory is not availaible.
2013-04-03 20:01:18,600 DEBUG [gce.arcgrid] - ArcGridFormatFactory is availaible.
2013-04-03 20:01:18,601 DEBUG [gdal.rpftoc] - RPFTOCFormatFactory is not availaible.
2013-04-03 20:01:18,601 DEBUG [gdal.mrsid] - MrSIDFormatFactory is not availaible.
2013-04-03 20:01:18,601 DEBUG [gdal.jp2mrisd] - JP2MrSIDFormatFactory is not availaible.
2013-04-03 20:01:18,601 DEBUG [gdal.jp2k] - JP2KFormatFactory is not availaible.
2013-04-03 20:01:18,601 DEBUG [gdal.jp2ecw] - JP2ECWFormatFactory is not availaible.
2013-04-03 20:01:18,601 DEBUG [gdal.ehdr] - EsriHdrFormatFactory is not availaible.
2013-04-03 20:01:18,601 DEBUG [gdal.dted] - DTEDFormatFactory is not availaible.
2013-04-03 20:01:18,601 DEBUG [gdal.nitf] - NITFFormatFactory is not availaible.
2013-04-03 20:01:18,601 DEBUG [gdal.envihdr] - EnviHdrFormatFactory is not availaible.
2013-04-03 20:01:18,601 DEBUG [gdal.erdasimg] - ErdasImgFormatFactory is not availaible.
My final aim is to be able to load ESRI .adf raster files. I hope all this work is not for nothing.
Many thanks
Santi
Hi Santiago,
Can you try this?
Best Regards,
Daniele
Hope this helps.
Daniele
Hi again,
GLIBCXX_3.4
GLIBCXX_3.4.1
GLIBCXX_3.4.2
GLIBCXX_3.4.3
GLIBCXX_3.4.4
GLIBCXX_3.4.5
GLIBCXX_3.4.6
GLIBCXX_3.4.7
GLIBCXX_3.4.8
GLIBCXX_3.4.9
GLIBCXX_3.4.10
GLIBCXX_3.4.11
GLIBCXX_3.4.12
GLIBCXX_3.4.13
GLIBCXX_3.4.14
GLIBCXX_3.4.15
GLIBCXX_3.4.16
GLIBCXX_3.4.17
/usr/lib/
Santi
Done:
GLIBCXX_3.4
GLIBCXX_3.4.1
GLIBCXX_3.4.2
GLIBCXX_3.4.3
GLIBCXX_3.4.4
GLIBCXX_3.4.5
GLIBCXX_3.4.6
GLIBCXX_3.4.7
GLIBCXX_3.4.8
GLIBCXX_3.4.9
GLIBCXX_3.4.10
GLIBCXX_3.4.11
GLIBCXX_3.4.12
GLIBCXX_3.4.13
GLIBCXX_FORCE_NEW
Daniele
cheers,
Daniele
I didn’t
Thanks Daniele.
Hi Santiago,
libgksu/ libtrash/
libglade/ libv4l/
libnfsidmap/
Daniele
Hi Santiago,
Daniele
Ciao Santiago,
Simone Giannecchini
more information.
@simogeo
Founder/Director
Hello everyone,
java.library.path”
and Tomcat 7.0.35
Thanks in advance
Hi again,
Could you please list the content of your geoserver webapp WEB-INF/lib folder?
If everything is on the proper place, I think there is some other GDAL libs around on your system (probably on /usr/lib or similar common locations of the LD_LIBRARY_PATH) which take priority at loading so that the 1.9.2 version isn’t properly loaded.
Could you also send me the full geoserver log?
Daniele
On Wed, Apr 3, 2013 at 8:12 PM, Santiago Timón <stimonmail@anonymised.com…> wrote:
Hi Daniele,
Supported Formats:
ELAS (rw+v): ELAS
DIPEx (rov): DIPEx
ACE2 (rov): ACE2
Many thanks
Santi
Hi Santiago,
Can you try this?
Best Regards,
Daniele
Hope this helps.
Daniele
Hi again,
GLIBCXX_3.4
GLIBCXX_3.4.1
GLIBCXX_3.4.2
GLIBCXX_3.4.3
GLIBCXX_3.4.4
GLIBCXX_3.4.5
GLIBCXX_3.4.6
GLIBCXX_3.4.7
GLIBCXX_3.4.8
GLIBCXX_3.4.9
GLIBCXX_3.4.10
GLIBCXX_3.4.11
GLIBCXX_3.4.12
GLIBCXX_3.4.13
GLIBCXX_3.4.14
GLIBCXX_3.4.15
GLIBCXX_3.4.16
GLIBCXX_3.4.17
/usr/lib/
Santi
Done:
GLIBCXX_3.4
GLIBCXX_3.4.1
GLIBCXX_3.4.2
GLIBCXX_3.4.3
GLIBCXX_3.4.4
GLIBCXX_3.4.5
GLIBCXX_3.4.6
GLIBCXX_3.4.7
GLIBCXX_3.4.8
GLIBCXX_3.4.9
GLIBCXX_3.4.10
GLIBCXX_3.4.11
GLIBCXX_3.4.12
GLIBCXX_3.4.13
GLIBCXX_FORCE_NEW
Daniele
cheers,
Daniele
I didn’t
Thanks Daniele.
Hi Santiago,
libgksu/ libtrash/
libglade/ libv4l/
libnfsidmap/
Daniele
Hi Santiago,
Daniele
Ciao Santiago,
Simone Giannecchini
more information.
@simogeo
Founder/Director
Hello everyone,
java.library.path”
and Tomcat 7.0.35
Thanks in advance
Finally I made it work!
Maybe I made some mistakes in previous steps, but I have done another reboot and seen in the log that there were any GDAL complains… and the new raster formats are now available.
Thanks a lot for your help.
Santi
2013/4/4 Daniele Romagnoli <daniele.romagnoli@anonymised.com>
Hi again,
Daniele
On Wed, Apr 3, 2013 at 8:12 PM, Santiago Timón <stimonmail@anonymised.com> wrote:
Hi Daniele,
Supported Formats:
ELAS (rw+v): ELAS
DIPEx (rov): DIPEx
ACE2 (rov): ACE2
Many thanks
Santi
Hi Santiago,
Can you try this?
Best Regards,
Daniele
Hope this helps.
Daniele
Hi again,
GLIBCXX_3.4
GLIBCXX_3.4.1
GLIBCXX_3.4.2
GLIBCXX_3.4.3
GLIBCXX_3.4.4
GLIBCXX_3.4.5
GLIBCXX_3.4.6
GLIBCXX_3.4.7
GLIBCXX_3.4.8
GLIBCXX_3.4.9
GLIBCXX_3.4.10
GLIBCXX_3.4.11
GLIBCXX_3.4.12
GLIBCXX_3.4.13
GLIBCXX_3.4.14
GLIBCXX_3.4.15
GLIBCXX_3.4.16
GLIBCXX_3.4.17
/usr/lib/
Santi
Done:
GLIBCXX_3.4
GLIBCXX_3.4.1
GLIBCXX_3.4.2
GLIBCXX_3.4.3
GLIBCXX_3.4.4
GLIBCXX_3.4.5
GLIBCXX_3.4.6
GLIBCXX_3.4.7
GLIBCXX_3.4.8
GLIBCXX_3.4.9
GLIBCXX_3.4.10
GLIBCXX_3.4.11
GLIBCXX_3.4.12
GLIBCXX_3.4.13
GLIBCXX_FORCE_NEW
Daniele
cheers,
Daniele
I didn’t
Thanks Daniele.
Hi Santiago,
libgksu/ libtrash/
libglade/ libv4l/
libnfsidmap/
Daniele
Hi Santiago,
Daniele
Ciao Santiago,
Simone Giannecchini
more information.
@simogeo
Founder/Director
Hello everyone,
java.library.path”
and Tomcat 7.0.35
Thanks in advance
