I have a problem while migrating from GeoServer 2.2.2 to 2.3.0. In my old version of GS, I had PostGis datasource : I could see these sources within the folder .../geoserver/data_dir/workspaces/myworkspaceName
each data source (ie each database) has its own folder, and in the folder : datastore.wml + folder for each published layer. That's ok.
Now, for migrating to 2.3.0 I copied my whole data_dir, minus security folder, to new server. All my layers are here, nice, EXCEPT the PostGis tables.... strange!
So I tried creating a new datasource from PostGis, as usual. Except this time, I don't have any folder for this datastore. It seems that the way PostGis tables and layers are stored has changed in 2.3.0.
Could you tell me how to deal with this problem, to have all my PostGis layers back on GS 2.3.0 : should I start from scratch with these layers publication? How are they configured in the GS folders?
Thank you !
Gabriel Vatin
On Wed, Mar 20, 2013 at 5:49 PM, Gabriel Vatin
<gabriel.vatin@anonymised.com> wrote:
tables.... strange!
Nope, it did not change in 2.3.0.
No idea what might not be working there though...
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Actually, when creating a new datastore from PostGis, all the folders are here, it's true. But still, the "old" folders coming from my GS 2.2.2 aren't recognized by 2.3.0. Even if it is the exact same structure, I compared both (new created datastore vs original datastore).
Maybe it can come from the encryption of password for DB connection ? I've seen that the authentification panel has changed in 2.3.0, and I can't see the digest method.
Gabriel
tables.... strange!
On Thu, Mar 21, 2013 at 9:30 AM, Gabriel Vatin
the digest method.
Let's ask Christian (cc'ed) about that
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Garbiel, can you send me the datastore.xml from the new created datastore and from the old one.
Second, which “password encryption” do you use (global Security Settings).
Christian
2013/3/21 Andrea Aime <andrea.aime@anonymised.com>
here, it’s true. But still, the “old” folders coming from my GS 2.2.2 aren’t
Maybe it can come from the encryption of password for DB connection ? I’ve
seen that the authentification panel has changed in 2.3.0, and I can’t see
the digest method.
Let’s ask Christian (cc’ed) about that
Ing. Andrea Aime
@geowolf
Technical Lead
Everyone hates slow websites. So do we.
Make your web apps faster with AppDynamics
Download AppDynamics Lite for free today:
http://p.sf.net/sfu/appdyn_d2d_mar
Geoserver-users mailing list
Thanks Aime. The digest method was added "at hand" in 2.2.2 version. Now, I guess the tutorial on GS webite should be updated, as authentification panel has changed :
http://docs.geoserver.org/latest/en/user/security/tutorials/digest/index.html
And about my PostGis problem, that was indeed a problem of encryption. I used the new encrypted password of my published PostGis datastore, copied it into the old published datastore, and now it works. So the password wasn't encrypted the same way.
Gabriel
the digest method.
And here is the problem. Geoserver 2.3.0 did not find its keystore “geoserver.jceks”, as a consequence a new one was created.
Within the keystore, there is a key labeled
config:password:key
This key is used for password encryption and is created on demand. (on a random basis).
Solutions:
- Copy your old security dir to the new installation, GeoServer 2.3.0 should migrate this directory properly.
or
- Use the java keytools to export/import the old key into the new keystore.
Hope this helps
2013/3/21 Gabriel Vatin <gabriel.vatin@anonymised.com>
Thanks Aime. The digest method was added “at hand” in 2.2.2 version.
password wasn’t encrypted the same way.
Gabriel
the digest method.
That's it, great ! I used solution 1, copying security dir from 2.2.2 to 2.3.0 without extra of modified files from 2.3.0. Now I have all my PostGis layers.
Thanks Christian !
Gabriel
"geoserver.jceks", as a consequence a new one was created.
config:password:key
random basis).
Solutions:
1) Copy your old security dir to the new installation, GeoServer 2.3.0
or
2) Use the java keytools to export/import the old key into the new keystore.
Hope this helps
<mailto:gabriel.vatin@anonymised.com>>
Gabriel
folders are
2.2.2 aren't
compared both
connection ? I've
can't see
>> the digest method.
> Cheers
> Andrea
<mailto:Geoserver-users@lists.sourceforge.net>
