[Geoserver-users] GeoServer 2.3.4 imagepyramid plugin and SSL and J2EE login
I have installed and configured GeoServer 2.3.4 on Oracle WebLogic server with SSL enabled. I have disabled all the authentication filters for all the filter chains except a newly create J2EE authentication filter.
We can successfully create a workspace via rest but when we attempt to create the image pyramid data store it fails. And the following is the log of this error.
2013-10-23 13:21:09,735 INFO [catalog.rest] - POST workspace CADRG
2013-10-23 13:21:09,811 INFO [org.geoserver] - Loaded store ‘JNC’, enabled
2013-10-23 13:21:09,817 INFO [catalog.rest] - POST coverage store JNC
2013-10-23 13:21:09,882 INFO [org.geoserver] - Loaded coverage ‘JNC’, disabled
2013-10-23 13:21:09,886 ERROR [geoserver.rest] - :This plugin accepts only File, URL and String pointing to a file
org.geoserver.rest.RestletException: java.lang.IllegalArgumentException: This plugin accepts only File, URL and String pointing to a file
at org.geoserver.rest.ReflectiveResource.handleException(ReflectiveResource.java:325)
at org.geoserver.rest.ReflectiveResource.handlePost(ReflectiveResource.java:123)
at org.restlet.Finder.handle(Finder.java:296)
at org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:37)
at org.restlet.Filter.doHandle(Filter.java:105)
at org.restlet.Filter.handle(Filter.java:134)
at org.restlet.Router.handle(Router.java:444)
at org.geoserver.rest.RESTDispatcher$1.handle(RESTDispatcher.java:204)
at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:86)
Melody
Melody Ballance, Senior Software Engineer
Northrop Grumman ISS/DSD
468 Viking Drive
Virginia Beach, VA 23452
(757)498-5508 - office
(757)498-5670 - fax
melody.ballance@anonymised.com - email
“There are two ways to be fooled. One is to believe in what isn’t true; the other is to refuse to believe what is true.” Soren Kierkegaard
Hi Melody,
could you please share the REST command you are using to create the image pyramid data store?
Mauro
2013/10/23 Ballance, Melody (IS) <melody.ballance@anonymised.com>
Melody
468 Viking Drive
(757)498-5670 - fax
October Webinars: Code for Performance
Free Intel webinars can help you accelerate application performance.
Explore tips for MPI, OpenMP, advanced profiling, and more. Get the most from
the latest Intel processors and coprocessors. See abstracts and register >
http://pubads.g.doubleclick.net/gampad/clk?id=60135991&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Mauro,
I am cc’ing David on this and he will provide the command that is being used. I GREATLY appreciate your support with this.
Melody
From: maurobartolomeoli@anonymised.com [mailto:maurobartolomeoli@anonymised.com] On Behalf Of Mauro Bartolomeoli
Sent: Wednesday, October 23, 2013 12:59 PM
To: Ballance, Melody (IS)
Subject: EXT :Re: [Geoserver-users] GeoServer 2.3.4 imagepyramid plugin and SSL and J2EE login
Hi Melody,
Mauro
Melody
468 Viking Drive
(757)498-5670 - fax
Dott. Mauro Bartolomeoli
@mauro_bart
Via Poggio alle Viti 1187
Originally I wrote the code in Perl, but I had to change it to Python.
def http_post(url, username, password, content):
user_agent = ‘Mozilla/5.0 (Windows NT 6.1; Win64; x64; rv:25.0) Gecko/20100101 Firefox/25.0’
base64string = base64.standard_b64encode(‘%s:%s’ % (username, password))
headers = { ‘User-Agent’ : user_agent , ‘Content-Type’ : ‘text/xml’, ‘Authorization’ : ‘Basic %s’ % base64string }
request = urllib2.Request(url, content, headers)
try:
result = urllib2.urlopen(request)
print result.read()
except urllib2.URLError as e:
if hasattr(e, ‘reason’):
print ‘We failed to reach a server.’
print 'Reason: ', e.reason
elif hasattr(e, ‘code’):
print ‘The server couldn't fulfill the request.’
print 'Error code: ', e.code
username = sys.argv[1];
password = sys.argv[2];
data = sys.argv[3];
fqhn = sys.argv[4];
url = ‘https://’ + fqhn + ‘:7502/GeoServer/rest/workspaces/’
content = ‘CADRG’
url = ‘https://’ + fqhn + ‘:7502/GeoServer/rest/workspaces/CADRG/coveragestores?configure=all’
content = ‘CADRGJNCtrueImagePyramid’ + data + ‘/CADRG/JNC’
url = ‘https://’ + fqhn + ‘:7502/GeoServer/rest/workspaces/CADRG/coveragestores/JNC/coverages’
content = ‘JNCJNCGEOGCS["WGS 84",DATUM["World Geodetic System 1984",SPHEROID["WGS 84",6378137.0, 298.257223563, AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],UNIT["degree", 0.017453292519943295],AXIS["Geodetic longitude", EAST],AXIS["Geodetic latitude", NORTH],AUTHORITY["EPSG","4326"]]EPSG:4326 -180198.95057449425533-83.0769231538484183.076923EPSG:4326’
Sent: Wednesday, October 23, 2013 1:03 PM
To: Mauro Bartolomeoli
Cc: geoserver-users@lists.sourceforge.net; Laratta, David (IS)
Subject: RE: EXT :Re: [Geoserver-users] GeoServer 2.3.4 imagepyramid plugin and SSL and J2EE login
Mauro,
Melody
From: maurobartolomeoli@anonymised.com [mailto:maurobartolomeoli@anonymised.com…84…] On Behalf Of Mauro Bartolomeoli
Hi Melody,
Mauro
Melody
468 Viking Drive
(757)498-5670 - fax
@mauro_bart
Hi David,
see my answers below:
2013/10/23 Laratta, David (IS) <David.Laratta@anonymised.com>
Originally I wrote the code in Perl, but I had to change it to Python. **
def http_post(url, username, password, content):****
                user_agent = 'Mozilla/5.0 (Windows NT 6.1; Win64; x64;
rv:25.0) Gecko/20100101 Firefox/25.0'****
                base64string = base64.standard_b64encode('%s:%s' %
(username, password))****
                headers = { 'User-Agent' : user_agent , 'Content-Type' :
'text/xml', 'Authorization' : 'Basic %s' % base64string }****
                request = urllib2.Request(url, content, headers)****
                try:****
                                result = urllib2.urlopen(request)****
                                print result.read()****
                except urllib2.URLError as e:****
                                if hasattr(e, 'reason'):****
                                                print 'We failed to reach
a server.'****
                                elif hasattr(e, 'code'):****
                                                print 'The server
couldn\'t fulfill the request.'****
e.code****
username = sys.argv[1];****
password = sys.argv[2];****
data = sys.argv[3];
What are you using as the 3rd argument to the script, or better, what is
the content of the data variable after this line of code?
fqhn = sys.argv[4];****
url = 'https://' + fqhn + ':7502/GeoServer/rest/workspaces/'****
content = '<workspace><name>CADRG</name>'****
http_post(url, username, password, content)****
':7502/GeoServer/rest/workspaces/CADRG/coveragestores?configure=all'****
content =
'<coverageStore><workspace>CADRG</workspace><name>JNC</name><enabled>true</enabled><type>ImagePyramid</type><url>'
+ data + '/CADRG/JNC</url></coverageStore>'****
So, what is the value of the content variable at this point?
What I'm thinking of is that in the url section maybe you are missing the
url protocol (file:). Is this the case?
Mauro
information.
@mauro_bart
It depends on where the data is located. I want to pull all the geospatial data off a hard drive, but that is after Melody and I figure out a solution for this problem.
Right now I’m putting in file:data/CADRG/JNC, because I moved the data into the data directory of the GEOServer.
Sent: Wednesday, October 23, 2013 1:46 PM
To: Laratta, David (IS)
Cc: Ballance, Melody (IS); Mauro Bartolomeoli; geoserver-users@anonymised.com.sourceforge.net
Subject: Re: EXT :Re: [Geoserver-users] GeoServer 2.3.4 imagepyramid plugin and SSL and J2EE login
Hi David,
try:
print result.read()
data = sys.argv[3];
What are you using as the 3rd argument to the script, or better, what is the content of the data variable after this line of code?
fqhn = sys.argv[4];
content = ‘CADRG’
What I’m thinking of is that in the url section maybe you are missing the url protocol (file:). Is this the case?
Mauro
@mauro_bart
Mauro,
Good Morning, I’m not sure if you were able to take a look at our issue yet. Can you please let me know what you think and provide us with some guidance, so then we can look further into it, cause as of right now we are out of ideas as to what is wrong. Right now we believe it is related to a permission problem and the J2EE authentication.
Currently the data is located in the GEOSERVER data directory and for the 3rd argument I’m putting in file:data. When I try updating the file path I receive: “This plugin accepts only File, URL and String pointing to a file”.
Our ultimate goal is to be able to transfer the data from an external drive.
Thanks
David
Hi David,
try:
print result.read()
data = sys.argv[3];
fqhn = sys.argv[4];
content = ‘CADRG’
Mauro
@mauro_bart
Hi David, I think I need some more info to try giving an help.
2013/10/24 Laratta, David (IS) <David.Laratta@anonymised.com>
Mauro,
Ok, it’s the folder data/CADRG/JNC existing and containing the pyramid? Have you looked at this tutorial (http://docs.geoserver.org/stable/en/user/tutorials/imagepyramid/imagepyramid.html) on how to create a pyramid?
Can you also send a complete log file with the exception you get?
Mauro
@mauro_bart
Mauro,
I have create image pyramids before. It works locally on my custom GeoServer(So it isn’t the data), but we are having issues on another GEOSERVER that Melody and I are working on.
Putty:
Installation of was successful.
bash-3.2# /h/GEODATA/data/postinstall
Enter the username used for GEOSRV
user
Enter the password user for GEOSRV
Enter the password used for GEOSRV again:
Enter the location for the data
file:data
Enter the GEOSRV fully qualified hostname
10.241.134.144
user – Username
****** - Password
file:data – Data location
10.241.134.144 – fully qualified hostname
https://10.241.134.144:7502/GeoServer/rest/workspaces/
https://10.241.134.144:7502/GeoServer/rest/workspaces/CADRG/coveragestores?configure=all
CADRGJNCtrueImagePyramidfile:data/CADRG/JNC
https://10.241.134.144:7502/GeoServer/rest/workspaces/CADRG/coveragestores/JNC/coverages
The server couldn’t fulfill the request.
Error code: 500
Setup complete. Starting services…
Log
Sent: Friday, October 25, 2013 5:24 AM
Subject: Re: [Geoserver-users] EXT :Re: GeoServer 2.3.4 imagepyramid plugin and SSL and J2EE login
Mauro,
Mauro
@mauro_bart
Hi David,
the exception you get tells me that for some reason the folder is not recognized as valid (existing, readable, etc.) or not containing a valid ImagePyramid. I cannot tell you more. Can you try to increase logging level and send me all the relevant log file generated after the error?
Mauro
2013/10/28 Laratta, David (IS) <David.Laratta@anonymised.com>
Mauro,
Putty:
user
file:data
10.241.134.144
user – Username
****** - Password
Error code: 500
Log
2013-10-28 13:41:49,921 INFO [storage.DefaultStorageFinder] - *** Found Servlet context parameter GEOSERVER_DATA_DIR set to /h/data/global/GEOSRV/data, using it as the default prefix. ***
2013-10-28 13:41:49,921 INFO [storage.DefaultStorageFinder] - *****************************************************************************************************************************
2013-10-28 13:41:49,921 INFO [config.XMLConfiguration] - Will look for geowebcache.xml in ‘/h/data/global/GEOSRV/data/gwc’
2013-10-28 13:41:50,134 INFO [gwc.config] - Initializing GeoServer specific GWC configuration from gwc-gs.xml
2013-10-28 13:41:50,922 INFO [gwc.layer] - Initializing GWC configuration based on GeoServer’s Catalog
2013-10-28 13:41:50,922 INFO [gwc.layer] - GeoServer TileLayer store base directory is: /h/data/global/GEOSRV/data/gwc-layers
2013-10-28 13:41:50,925 INFO [gwc.layer] - Loading tile layers from /h/data/global/GEOSRV/data/gwc-layers
2013-10-28 13:41:51,154 INFO [gwc.layer] - GWC configuration based on GeoServer’s Catalog loaded successfuly
2013-10-28 13:41:51,155 INFO [config.XMLConfiguration] - Found configuration file in /h/data/global/GEOSRV/data/gwc
2013-10-28 13:41:51,916 INFO [config.XMLConfiguration] - Configuration file validated fine.
2013-10-28 13:41:51,932 INFO [config.XMLConfiguration] - Initializing GridSets from /h/data/global/GEOSRV/data/gwc
2013-10-28 13:41:51,933 INFO [config.XMLConfiguration] - Initializing layers from /h/data/global/GEOSRV/data/gwc
2013-10-28 13:41:51,933 INFO [layer.TileLayerDispatcher] - Configuration /h/data/global/GEOSRV/data/gwc contained no layers.
2013-10-28 13:41:51,982 INFO [storage.MetastoreRemover] - Cleaning up the old disk quota database
2013-10-28 13:41:52,006 INFO [diskquota.ConfigLoader] - DiskQuota configuration not found: /h/data/global/GEOSRV/data/gwc/geowebcache-diskquota.xml
2013-10-28 13:41:52,030 INFO [diskquota.ConfigLoader] - DiskQuota configuration not found: /h/data/global/GEOSRV/data/gwc/geowebcache-diskquota.xml
2013-10-28 13:41:52,037 INFO [diskquota.DiskQuotaMonitor] - Setting up disk quota periodic enforcement task
2013-10-28 13:41:52,040 INFO [diskquota.DiskQuotaMonitor] - 0 layers configured with their own quotas.
2013-10-28 13:41:52,041 INFO [diskquota.DiskQuotaMonitor] - 22 layers attached to global quota 500.0 MB
2013-10-28 13:41:52,077 INFO [diskquota.DiskQuotaMonitor] - Disk quota periodic enforcement task set up every 10 SECONDS
2013-10-28 13:41:52,543 INFO [org.geoserver] - GeoServer configuration lock is enabled
2013-10-28 13:41:52,962 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wfs/*] onto handler ‘dispatcher’
2013-10-28 13:41:52,962 INFO [ows.OWSHandlerMapping] - Mapped URL path [/TestWfsPost] onto handler ‘wfsTestServlet’
2013-10-28 13:41:52,962 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wfs] onto handler ‘dispatcher’
2013-10-28 13:41:59,783 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wms/*] onto handler ‘dispatcher’
2013-10-28 13:41:59,783 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wms] onto handler ‘dispatcher’
2013-10-28 13:41:59,965 INFO [ows.OWSHandlerMapping] - Mapped URL path [/kml] onto handler ‘dispatcher’
2013-10-28 13:41:59,965 INFO [ows.OWSHandlerMapping] - Mapped URL path [/kml/*] onto handler ‘dispatcher’
2013-10-28 13:41:59,970 INFO [ows.OWSHandlerMapping] - Mapped URL path [/animate] onto handler ‘dispatcher’
2013-10-28 13:41:59,970 INFO [ows.OWSHandlerMapping] - Mapped URL path [/animate/*] onto handler ‘dispatcher’
2013-10-28 13:42:00,213 INFO [ows.OWSHandlerMapping] - Mapped URL path [/ows/**] onto handler ‘dispatcher’
2013-10-28 13:42:00,213 INFO [ows.OWSHandlerMapping] - Mapped URL path [/ows] onto handler ‘dispatcher’
2013-10-28 13:42:00,816 INFO [ows.OWSHandlerMapping] - Mapped URL path [/gwc/service/**] onto handler ‘dispatcher’
2013-10-28 13:42:00,878 INFO [geowebcache.GeoWebCacheDispatcher] - Invoked setServletPrefix(gwc)
2013-10-28 13:42:00,898 INFO [georss.GeoRSSPoller] - Initializing GeoRSS poller in a background job…
2013-10-28 13:42:00,904 INFO [georss.GeoRSSPoller] - No enabled GeoRSS feeds found, poller will not run.
2013-10-28 13:42:01,089 INFO [rest.RESTDispatcher] - Created RESTDispatcher with 13 paths
2013-10-28 13:42:01,123 INFO [wms.WMSService] - Will NOT recombine tiles for non-tiling clients.
2013-10-28 13:42:01,123 INFO [wms.WMSService] - Will proxy requests to backend that are not getmap or getcapabilities.
2013-10-28 13:42:01,189 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wcs] onto handler ‘dispatcher’
2013-10-28 13:42:01,189 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wcs/**] onto handler ‘dispatcher’
2013-10-28 13:52:49,752 INFO [geoserver.security] - Strong cryptograhpy is available
2013-10-28 14:28:06,634 INFO [catalog.rest] - POST workspace CADRG
2013-10-28 14:28:06,753 INFO [org.geoserver] - Loaded store ‘JNC’, enabled
2013-10-28 14:28:06,763 INFO [catalog.rest] - POST coverage store JNC
2013-10-28 14:28:06,845 INFO [org.geoserver] - Loaded coverage ‘JNC’, disabled
2013-10-28 14:28:06,865 ERROR [geoserver.rest] - :This plugin accepts only File, URL and String pointing to a file
2013-10-28 14:28:06,868 ERROR [geoserver.rest] -
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:789)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at weblogic.servlet.internal.StubSecurityHelper$ServletServiceAction.run(StubSecurityHelper.java:227)
at weblogic.servlet.internal.StubSecurityHelper.invokeServlet(StubSecurityHelper.java:125)
at weblogic.servlet.internal.ServletStubImpl.execute(ServletStubImpl.java:301)
at weblogic.servlet.internal.TailFilter.doFilter(TailFilter.java:26)
at weblogic.servlet.internal.FilterChainImpl.doFilter(FilterChainImpl.java:60)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:27)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerPreAuthenticationFilter.doFilter(GeoServerPreAuthenticationFilter.java:74)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:134)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:75)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:48)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:47)
at weblogic.servlet.internal.WebAppServletContext$ServletInvocationAction.wrapRun(WebAppServletContext.java:3739)
at weblogic.servlet.internal.WebAppServletContext$ServletInvocationAction.run(WebAppServletContext.java:3705)
at weblogic.security.acl.internal.AuthenticatedSubject.doAs(AuthenticatedSubject.java:321)
at weblogic.security.service.SecurityManager.runAs(SecurityManager.java:120)
at weblogic.servlet.internal.WebAppServletContext.securedExecute(WebAppServletContext.java:2282)
at weblogic.servlet.internal.WebAppServletContext.execute(WebAppServletContext.java:2181)
at weblogic.servlet.internal.ServletRequestImpl.run(ServletRequestImpl.java:1491)
at weblogic.work.ExecuteThread.execute(ExecuteThread.java:256)
at weblogic.work.ExecuteThread.run(ExecuteThread.java:221)
Caused by: java.lang.IllegalArgumentException: This plugin accepts only File, URL and String pointing to a file
at org.geotools.gce.imagepyramid.ImagePyramidReader.(ImagePyramidReader.java:182)
at org.geotools.gce.imagepyramid.ImagePyramidFormat.getReader(ImagePyramidFormat.java:262)
at org.geotools.gce.imagepyramid.ImagePyramidFormat.getReader(ImagePyramidFormat.java:53)
at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:1213)
at org.geoserver.catalog.CatalogBuilder.initCoverage(CatalogBuilder.java:763)
at org.geoserver.catalog.rest.CoverageResource.handleObjectPost(CoverageResource.java:80)
at org.geoserver.rest.ReflectiveResource.handlePost(ReflectiveResource.java:120)
… 70 more
From: maurobartolomeoli@…84… [mailto:maurobartolomeoli@anonymised.com] On Behalf Of Mauro Bartolomeoli
Mauro,
Mauro
@mauro_bart
@mauro_bart
Hi David,
this exception is really weird. Seems something is wrong with the commons-io library.
Do you have an old commons-io (maybe a 1.x version) anywhere in your installation (geoserver itself or the main container)?
Mauro
2013/10/29 Laratta, David (IS) <David.Laratta@anonymised.com>
Mauro,
So what I did was for JNC I added a properties file and prj file from another GEOSERVER that I created. The GNC did not have these files. The JNC worked with created the layers via REST, but they aren’t being displayed and the log is showing it was an error. The GNC is showing the same errors as before.
Caused by: org.geoserver.platform.ServiceException: java.lang.NoSuchMethodError: org.apache.commons.io.filefilter.FileFilterUtils.and([Lorg/apache/commons/io/filefilter/IOFileFilter;)Lorg/apache/commons/io/filefilter/IOFileFilter;
at org.geoserver.wms.map.RenderedImageMapOutputFormat.directRasterRender(RenderedImageMapOutputFormat.java:898)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:333)
… 89 more
Caused by: java.lang.NoSuchMethodError: org.apache.commons.io.filefilter.FileFilterUtils.and([Lorg/apache/commons/io/filefilter/IOFileFilter;)Lorg/apache/commons/io/filefilter/IOFileFilter;
at org.geotools.gce.imagemosaic.Utils.checkSource(Utils.java:958)
at org.geotools.gce.imagemosaic.ImageMosaicReader.initReaderFromURL(ImageMosaicReader.java:645)
at org.geotools.gce.imagemosaic.ImageMosaicReader.(ImageMosaicReader.java:579)
at org.geotools.gce.imagepyramid.ImagePyramidReader.loadRequestedTiles(ImagePyramidReader.java:498)
at org.geotools.gce.imagepyramid.ImagePyramidReader.loadTiles(ImagePyramidReader.java:431)
at org.geotools.gce.imagepyramid.ImagePyramidReader.read(ImagePyramidReader.java:370)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.readBestCoverage(RenderedImageMapOutputFormat.java:1296)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.directRasterRender(RenderedImageMapOutputFormat.java:861)
… 90 more
No, we have commons-io-2.1.jar.
Melody
From: Mauro Bartolomeoli [mailto:mauro.bartolomeoli@anonymised.com]
Sent: Wednesday, October 30, 2013 9:01 AM
To: GeoServer Mailing List List
Subject: [Geoserver-users] Fwd: EXT :Re: GeoServer 2.3.4 imagepyramid plugin and SSL and J2EE login
Hi David,
Mauro
Mauro,
… 89 more
… 90 more
@mauro_bart
Mauro,
Is the issue because we are running two different GEOSERVERS? Melody is using a 2.3.4 GEOSERVER and I’m testing with a 2.3.3 GEOSERVER (Which works). Also the 2.3.3 is a Windows machine and the 2.3.4 is a Solaris(Unix) machine. Our main goal is to have it working on the 2.3.4 Solaris machine.
David
Sent: Wednesday, October 30, 2013 8:51 AM
Cc: geoserver-users@lists.sourceforge.net; Ballance, Melody (IS)
Hi David,
Mauro
Mauro,
Hopefully this helps:
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
… 89 more
… 90 more
2013-10-29 13:48:42,523 DEBUG [geoserver.filters] - Compressing output for mimetype: application/vnd.ogc.se_xml; charset=UTF-8
2013-10-29 13:48:42,524 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-29 13:48:42,585 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/CADRG/wms]
2013-10-29 13:48:42,585 DEBUG [ows.OWSHandlerMapping] - Mapping [/CADRG/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher@anonymised.com] and 1 interceptor
2013-10-29 13:48:42,587 INFO [geoserver.wms] -
Request: getServiceInfo
2013-10-29 13:48:42,588 DEBUG [geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2013-10-29 13:48:42,589 DEBUG [geoserver.ows] - establishing raster style for CADRG:JNC
2013-10-29 13:48:42,591 DEBUG [geoserver.wms] - setting up map
2013-10-29 13:48:42,592 DEBUG [wms.map] - setting up 752x330 image
2013-10-29 13:48:42,594 DEBUG [gce.imagemosaic] - Using ThreadPoolExecutor with the following settings: core pool size = 5
max pool size = 10
keep alive time 30000
2013-10-29 13:48:42,594 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Error rendering coverage on the fast path
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:335)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:255)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:127)
at org.geoserver.wms.GetMap.executeInternal(GetMap.java:466)
at org.geoserver.wms.GetMap.run(GetMap.java:201)
at org.geoserver.wms.GetMap.run(GetMap.java:111)
at org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:356)
at sun.reflect.GeneratedMethodAccessor258.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:318)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:61)
at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:35)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:73)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:54)
at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:54)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
at com.sun.proxy.$Proxy79.getMap(Unknown Source)
at sun.reflect.GeneratedMethodAccessor227.invoke(Unknown Source)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:774)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:272)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
… 89 more
… 90 more
2013-10-29 13:48:42,599 DEBUG [geoserver.filters] - Compressing output for mimetype: application/vnd.ogc.se_xml; charset=UTF-8
2013-10-29 13:48:42,599 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-29 13:48:42,720 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/CADRG/wms]
2013-10-29 13:48:42,720 DEBUG [ows.OWSHandlerMapping] - Mapping [/CADRG/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher@anonymised.com] and 1 interceptor
2013-10-29 13:48:42,722 INFO [geoserver.wms] -
2013-10-29 13:48:42,724 DEBUG [geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2013-10-29 13:48:42,724 DEBUG [geoserver.ows] - establishing raster style for CADRG:JNC
2013-10-29 13:48:42,727 DEBUG [geoserver.wms] - setting up map
2013-10-29 13:48:42,727 DEBUG [wms.map] - setting up 752x330 image
2013-10-29 13:48:42,729 DEBUG [gce.imagemosaic] - Using ThreadPoolExecutor with the following settings: core pool size = 5
max pool size = 10
2013-10-29 13:48:42,729 ERROR [geoserver.ows] -
… 89 more
… 90 more
2013-10-29 13:48:42,734 DEBUG [geoserver.filters] - Compressing output for mimetype: application/vnd.ogc.se_xml; charset=UTF-8
2013-10-29 13:48:42,734 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-29 13:49:09,203 DEBUG [org.geoserver] - Thread 19 locking in mode WRITE
2013-10-29 13:49:09,204 DEBUG [org.geoserver] - Thread 19 got the lock in mode WRITE
2013-10-29 13:49:09,235 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI scheme is not “file”), falling back to the inputstream for polling
2013-10-29 13:49:09,238 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI scheme is not “file”), falling back to the inputstream for polling
2013-10-29 13:49:09,241 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/geoserver.css to file (URI scheme is not “file”), falling back to the inputstream for polling
2013-10-29 13:49:09,244 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI scheme is not “file”), falling back to the inputstream for polling
2013-10-29 13:49:09,246 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI scheme is not “file”), falling back to the inputstream for polling
2013-10-29 13:49:09,249 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI scheme is not “file”), falling back to the inputstream for polling
2013-10-29 13:49:09,306 DEBUG [org.geoserver] - Thread 19 releasing the lock in mode WRITE
2013-10-29 13:49:09,306 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html; charset=UTF-8
2013-10-29 13:49:09,308 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-29 13:49:09,312 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/CADRG/wms]
2013-10-29 13:49:09,313 DEBUG [ows.OWSHandlerMapping] - Mapping [/CADRG/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher@anonymised.com] and 1 interceptor
2013-10-29 13:49:09,315 INFO [geoserver.wms] -
2013-10-29 13:49:09,318 DEBUG [geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2013-10-29 13:49:09,318 DEBUG [geoserver.ows] - establishing raster style for CADRG:JNC
2013-10-29 13:49:09,320 DEBUG [geotools.styling] - number of fts set 1
2013-10-29 13:49:09,323 DEBUG [gce.imagemosaic] - Using ThreadPoolExecutor with the following settings: core pool size = 5
max pool size = 10
2013-10-29 13:49:09,323 ERROR [geoserver.ows] -
at org.geoserver.wms.GetFeatureInfo.identifyRasterLayer(GetFeatureInfo.java:383)
at org.geoserver.wms.GetFeatureInfo.execute(GetFeatureInfo.java:283)
at org.geoserver.wms.GetFeatureInfo.execute(GetFeatureInfo.java:172)
at org.geoserver.wms.GetFeatureInfo.run(GetFeatureInfo.java:121)
at org.geoserver.wms.DefaultWebMapService.getFeatureInfo(DefaultWebMapService.java:374)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at com.sun.proxy.$Proxy79.getFeatureInfo(Unknown Source)
2013-10-29 13:49:09,327 DEBUG [geoserver.filters] - Compressing output for mimetype: application/vnd.ogc.se_xml; charset=UTF-8
2013-10-29 13:49:09,327 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-29 13:49:12,387 DEBUG [org.geoserver] - Thread 12 locking in mode WRITE
2013-10-29 13:49:12,387 DEBUG [org.geoserver] - Thread 12 got the lock in mode WRITE
2013-10-29 13:49:12,394 DEBUG [gce.arcgrid] - ArcGridFormatFactory is availaible.
2013-10-29 13:49:12,395 DEBUG [gce.arcgrid] - Creating a new ArcGriFormat.
2013-10-29 13:49:12,427 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/data/store/NewDataPage.html to file (URI scheme is not “file”), falling back to the inputstream for polling
2013-10-29 13:49:12,437 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI scheme is not “file”), falling back to the inputstream for polling
2013-10-29 13:49:12,440 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI scheme is not “file”), falling back to the inputstream for polling
2013-10-29 13:49:12,443 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/geoserver.css to file (URI scheme is not “file”), falling back to the inputstream for polling
2013-10-29 13:49:12,445 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI scheme is not “file”), falling back to the inputstream for polling
2013-10-29 13:49:12,448 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI scheme is not “file”), falling back to the inputstream for polling
2013-10-29 13:49:12,450 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI scheme is not “file”), falling back to the inputstream for polling
2013-10-29 13:49:12,547 DEBUG [org.geoserver] - Thread 12 releasing the lock in mode WRITE
2013-10-29 13:49:12,548 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html; charset=UTF-8
2013-10-29 13:49:12,549 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-29 13:49:12,710 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/geosilk/database_vector.png to file (URI scheme is not “file”), falling back to the inputstream for polling
2013-10-29 13:49:12,710 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/geosilk/server_map.png to file (URI scheme is not “file”), falling back to the inputstream for polling
2013-10-29 13:49:12,711 DEBUG [org.geoserver] - Thread 19 locking in mode READ
2013-10-29 13:49:12,711 DEBUG [org.geoserver] - Thread 12 locking in mode READ
2013-10-29 13:49:12,712 DEBUG [org.geoserver] - Thread 19 got the lock in mode READ
2013-10-29 13:49:12,712 DEBUG [org.geoserver] - Thread 12 got the lock in mode READ
2013-10-29 13:49:12,713 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/geosilk/database_vector.png to file (URI scheme is not “file”), falling back to the inputstream for polling
2013-10-29 13:49:12,713 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/geosilk/server_map.png to file (URI scheme is not “file”), falling back to the inputstream for polling
2013-10-29 13:49:12,714 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2013-10-29 13:49:12,715 DEBUG [org.geoserver] - Thread 12 releasing the lock in mode READ
2013-10-29 13:49:12,715 DEBUG [org.geoserver] - Thread 19 releasing the lock in mode READ
2013-10-29 13:49:12,715 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-29 13:49:12,719 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/geosilk/server_vector.png to file (URI scheme is not “file”), falling back to the inputstream for polling
2013-10-29 13:49:12,720 DEBUG [org.geoserver] - Thread 12 locking in mode READ
2013-10-29 13:49:12,720 DEBUG [org.geoserver] - Thread 12 got the lock in mode READ
2013-10-29 13:49:12,721 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/geosilk/server_vector.png to file (URI scheme is not “file”), falling back to the inputstream for polling
2013-10-29 13:49:12,722 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2013-10-29 13:49:12,723 DEBUG [org.geoserver] - Thread 12 releasing the lock in mode READ
2013-10-29 13:49:12,723 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-29 13:49:15,346 DEBUG [org.geoserver] - Thread 12 locking in mode WRITE
2013-10-29 13:49:15,347 DEBUG [org.geoserver] - Thread 12 got the lock in mode WRITE
2013-10-29 13:49:15,401 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/data/store/CoverageStoreNewPage.html to file (URI scheme is not “file”), falling back to the inputstream for polling
2013-10-29 13:49:15,405 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/data/store/AbstractCoverageStorePage.html to file (URI scheme is not “file”), falling back to the inputstream for polling
2013-10-29 13:49:15,415 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI scheme is not “file”), falling back to the inputstream for polling
2013-10-29 13:49:15,418 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI scheme is not “file”), falling back to the inputstream for polling
2013-10-29 13:49:15,420 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/geoserver.css to file (URI scheme is not “file”), falling back to the inputstream for polling
2013-10-29 13:49:15,424 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI scheme is not “file”), falling back to the inputstream for polling
2013-10-29 13:49:15,426 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI scheme is not “file”), falling back to the inputstream for polling
2013-10-29 13:49:15,429 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI scheme is not “file”), falling back to the inputstream for polling
2013-10-29 13:49:15,432 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/data/store/panel/TextParamPanel.html to file (URI scheme is not “file”), falling back to the inputstream for polling
2013-10-29 13:49:15,436 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/wicket-1.4.12.jar!/org/apache/wicket/markup/html/form/validation/FormComponentFeedbackBorder.html to file (URI scheme is not “file”), falling back to the inputstream for polling
2013-10-29 13:49:15,441 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/data/store/panel/CheckBoxParamPanel.html to file (URI scheme is not “file”), falling back to the inputstream for polling
2013-10-29 13:49:15,445 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/data/store/panel/WorkspacePanel.html to file (URI scheme is not “file”), falling back to the inputstream for polling
2013-10-29 13:49:15,449 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/data/store/DefaultCoverageStoreEditPanel.html to file (URI scheme is not “file”), falling back to the inputstream for polling
2013-10-29 13:49:15,561 DEBUG [org.geoserver] - Thread 12 releasing the lock in mode WRITE
2013-10-29 13:49:15,562 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-29 13:49:15,645 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html; charset=UTF-8
2013-10-29 13:49:15,648 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-29 13:49:32,111 DEBUG [geoserver.security] - Start searching for expired authentication tokens
2013-10-29 13:49:32,112 DEBUG [geoserver.security] - Number of expired authentication tokens found: 0
2013-10-29 13:49:32,112 DEBUG [geoserver.security] - End searching for expired authentication tokens
2013-10-29 13:49:48,979 DEBUG [org.geoserver] - Thread 19 locking in mode WRITE
2013-10-29 13:49:48,979 DEBUG [org.geoserver] - Thread 19 got the lock in mode WRITE
2013-10-29 13:49:48,986 DEBUG [geoserver.config] - Persisting coverage store GNC
2013-10-29 13:49:48,990 DEBUG [geoserver.config] - Persisted com.sun.proxy.$Proxy61 to /h/data/global/GEOSRV/data/workspaces/CADRG/GNC/coveragestore.xml
2013-10-29 13:49:48,994 DEBUG [geoserver.config] - Persisted com.sun.proxy.$Proxy72 to /h/data/global/GEOSRV/data/global.xml
2013-10-29 13:49:49,018 INFO [gce.imagepyramid] - Checking file:/h/data/global/GEOSRV/data/data/CADRG/
existstrue
isFilefalse
canRead:true
canWritetrue
canExecutetrue
isHidden:false
lastModified1382374664000
2013-10-29 13:49:49,020 INFO [gce.imagepyramid] - Checking file:/h/data/global/GEOSRV/data/data/CADRG/GNC/
existsfalse
isFilefalse
canRead:false
canWritefalse
canExecutefalse
isHidden:false
lastModified0
2013-10-29 13:49:49,025 INFO [gce.imagepyramid] - Unable to build mosaic for the directory:/h/data/global/GEOSRV/data/data/CADRG/GNC/3
2013-10-29 13:49:49,026 INFO [gce.imagepyramid] - Unable to build mosaic for the directory:/h/data/global/GEOSRV/data/data/CADRG/GNC/4
2013-10-29 13:49:49,026 INFO [gce.imagepyramid] - Unable to build mosaic for the directory:/h/data/global/GEOSRV/data/data/CADRG/GNC/0
2013-10-29 13:49:49,026 INFO [gce.imagepyramid] - Unable to build mosaic for the directory:/h/data/global/GEOSRV/data/data/CADRG/GNC/7
2013-10-29 13:49:49,027 INFO [gce.imagepyramid] - Unable to build mosaic for the directory:/h/data/global/GEOSRV/data/data/CADRG/GNC/5
2013-10-29 13:49:49,027 INFO [gce.imagepyramid] - Unable to build mosaic for the directory:/h/data/global/GEOSRV/data/data/CADRG/GNC/2
2013-10-29 13:49:49,027 INFO [gce.imagepyramid] - Unable to build mosaic for the directory:/h/data/global/GEOSRV/data/data/CADRG/GNC/8
2013-10-29 13:49:49,027 INFO [gce.imagepyramid] - Unable to build mosaic for the directory:/h/data/global/GEOSRV/data/data/CADRG/GNC/6
2013-10-29 13:49:49,028 INFO [gce.imagepyramid] - Unable to build mosaic for the directory:/h/data/global/GEOSRV/data/data/CADRG/GNC/1
2013-10-29 13:49:49,028 INFO [geoserver.web] - Getting list of coverages for saved store file:data/CADRG/GNC
java.lang.RuntimeException: Could not list layers for this store, an error occurred retrieving them: This plugin accepts only File, URL and String pointing to a file
at org.geoserver.web.data.layer.NewLayerPageProvider.getItemsInternal(NewLayerPageProvider.java:123)
at org.geoserver.web.data.layer.NewLayerPageProvider.getItems(NewLayerPageProvider.java:56)
at org.geoserver.web.wicket.GeoServerDataProvider.fullSize(GeoServerDataProvider.java:236)
at org.geoserver.web.wicket.GeoServerTablePanel$PagerDelegate.updateMatched(GeoServerTablePanel.java:550)
at org.geoserver.web.wicket.GeoServerTablePanel$PagerDelegate.(GeoServerTablePanel.java:543)
at org.geoserver.web.wicket.GeoServerTablePanel.(GeoServerTablePanel.java:217)
at org.geoserver.web.wicket.GeoServerTablePanel.(GeoServerTablePanel.java:96)
at org.geoserver.web.data.layer.NewLayerPage$1.(NewLayerPage.java:100)
at org.geoserver.web.data.layer.NewLayerPage.(NewLayerPage.java:100)
at org.geoserver.web.data.store.CoverageStoreNewPage.onSave(CoverageStoreNewPage.java:71)
at org.geoserver.web.data.store.AbstractCoverageStorePage$1.onSubmit(AbstractCoverageStorePage.java:115)
at org.apache.wicket.ajax.markup.html.form.AjaxSubmitLink$1.onSubmit(AjaxSubmitLink.java:68)
at org.apache.wicket.ajax.form.AjaxFormSubmitBehavior.onEvent(AjaxFormSubmitBehavior.java:143)
at org.apache.wicket.ajax.AjaxEventBehavior.respond(AjaxEventBehavior.java:177)
at org.apache.wicket.ajax.AbstractDefaultAjaxBehavior.onRequest(AbstractDefaultAjaxBehavior.java:300)
at org.apache.wicket.request.target.component.listener.BehaviorRequestTarget.processEvents(BehaviorRequestTarget.java:119)
at org.apache.wicket.request.AbstractRequestCycleProcessor.processEvents(AbstractRequestCycleProcessor.java:92)
at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1250)
at org.apache.wicket.RequestCycle.step(RequestCycle.java:1329)
at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1436)
at org.apache.wicket.RequestCycle.request(RequestCycle.java:545)
at org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:484)
at org.apache.wicket.protocol.http.WicketServlet.doPost(WicketServlet.java:160)
at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:159)
at org.geoserver.catalog.CatalogBuilder.buildCoverage(CatalogBuilder.java:822)
at org.geoserver.web.data.layer.NewLayerPageProvider.getItemsInternal(NewLayerPageProvider.java:90)
… 87 more
2013-10-29 13:49:49,032 DEBUG [geoserver.config] - Removing coverage store GNC
2013-10-29 13:49:49,036 DEBUG [geoserver.config] - Persisted com.sun.proxy.$Proxy72 to /h/data/global/GEOSRV/data/global.xml
2013-10-29 13:49:49,054 DEBUG [org.geoserver] - Thread 19 releasing the lock in mode WRITE
2013-10-29 13:49:49,054 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-29 13:49:49,055 DEBUG [geoserver.filters] - Compressing output for mimetype: text/xml; charset=UTF-8
2013-10-29 13:50:32,114 DEBUG [geoserver.security] - Start searching for expired authentication tokens
2013-10-29 13:50:32,115 DEBUG [geoserver.security] - Number of expired authentication tokens found: 0
2013-10-29 13:50:32,115 DEBUG [geoserver.security] - End searching for expired authentication tokens
2013-10-29 13:51:32,021 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/CADRG/wms]
2013-10-29 13:51:32,022 DEBUG [ows.OWSHandlerMapping] - Mapping [/CADRG/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher@anonymised.com] and 1 interceptor
2013-10-29 13:51:32,024 INFO [geoserver.wms] -
2013-10-29 13:51:32,026 DEBUG [geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2013-10-29 13:51:32,026 DEBUG [geoserver.ows] - establishing raster style for CADRG:JNC
2013-10-29 13:51:32,028 DEBUG [geotools.styling] - number of fts set 1
2013-10-29 13:51:32,029 INFO [geoserver.wms] -
Request: getFeatureInfo
Exceptions = application/vnd.ogc.se_xml
PropertyNames = null
XPixel = 321
YPixel = 196
QueryLayers = [org.geoserver.wms.MapLayerInfo@anonymised.com]
GetMapRequest =
GetMap Request
version: 1.1.1
output format: image/jpeg
width height: 752,330
bbox: ReferencedEnvelope[-7.917952 : 26.868527, -7.632672 : 7.632671]
layers: CADRG:JNC
styles: raster
FeatureCount = 50
InfoFormat = text/html
Version = 1.1.1
Request = GetFeatureInfo
Get = false
RequestCharset = null
BaseUrl = https://10.241.134.144:7502/GeoServer/
RawKvp = {INFO_FORMAT=text/html, BBOX=-7.917952,-7.632672,26.868527,7.632671, QUERY_LAYERS=CADRG:JNC, SERVICE=WMS, HEIGHT=330, REQUEST=GetFeatureInfo, STYLES=, WIDTH=752, EXCEPTIONS=application/vnd.ogc.se_xml, FEATURE_COUNT=50, VERSION=1.1.1, FORMAT=image/jpeg, LAYERS=CADRG:JNC, Y=196, X=321, SRS=EPSG:4326}
2013-10-29 13:51:32,042 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html
2013-10-29 13:51:32,043 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-29 13:51:32,046 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/CADRG/wms]
2013-10-29 13:51:32,047 DEBUG [ows.OWSHandlerMapping] - Mapping [/CADRG/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher@anonymised.com] and 1 interceptor
2013-10-29 13:51:32,049 INFO [geoserver.wms] -
2013-10-29 13:51:32,051 DEBUG [geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2013-10-29 13:51:32,051 DEBUG [geoserver.ows] - establishing raster style for CADRG:JNC
2013-10-29 13:51:32,053 DEBUG [geotools.styling] - number of fts set 1
2013-10-29 13:51:32,053 INFO [geoserver.wms] -
XPixel = 316
YPixel = 196
GetMapRequest =
GetMap Request
version: 1.1.1
bbox: ReferencedEnvelope[-1.765556 : 15.627683, -5.253902 : 2.378769]
layers: CADRG:JNC
styles: raster
FeatureCount = 50
Version = 1.1.1
Get = false
RawKvp = {INFO_FORMAT=text/html, BBOX=-1.765556,-5.253902,15.627683,2.378769, QUERY_LAYERS=CADRG:JNC, SERVICE=WMS, HEIGHT=330, REQUEST=GetFeatureInfo, STYLES=, WIDTH=752, EXCEPTIONS=application/vnd.ogc.se_xml, FEATURE_COUNT=50, VERSION=1.1.1, FORMAT=image/jpeg, LAYERS=CADRG:JNC, Y=196, X=316, SRS=EPSG:4326}
2013-10-29 13:51:32,063 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html
2013-10-29 13:51:32,064 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-29 13:51:32,118 DEBUG [geoserver.security] - Start searching for expired authentication tokens
2013-10-29 13:51:32,119 DEBUG [geoserver.security] - Number of expired authentication tokens found: 0
2013-10-29 13:51:32,119 DEBUG [geoserver.security] - End searching for expired authentication tokens
2013-10-29 13:51:32,141 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/CADRG/wms]
2013-10-29 13:51:32,141 DEBUG [ows.OWSHandlerMapping] - Mapping [/CADRG/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher@anonymised.com] and 1 interceptor
2013-10-29 13:51:32,144 INFO [geoserver.wms] -
2013-10-29 13:51:32,146 DEBUG [geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2013-10-29 13:51:32,146 DEBUG [geoserver.ows] - establishing raster style for CADRG:JNC
2013-10-29 13:51:32,148 DEBUG [geotools.styling] - number of fts set 1
2013-10-29 13:51:32,149 INFO [geoserver.wms] -
XPixel = 321
YPixel = 196
GetMapRequest =
GetMap Request
version: 1.1.1
layers: CADRG:JNC
styles: raster
FeatureCount = 50
Version = 1.1.1
Get = false
2013-10-29 13:51:32,160 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html
2013-10-29 13:51:32,161 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-29 13:51:34,198 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/CADRG/wms]
2013-10-29 13:51:34,199 DEBUG [ows.OWSHandlerMapping] - Mapping [/CADRG/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher@anonymised.com] and 1 interceptor
2013-10-29 13:51:34,201 INFO [geoserver.wms] -
2013-10-29 13:51:34,203 DEBUG [geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2013-10-29 13:51:34,203 DEBUG [geoserver.ows] - establishing raster style for CADRG:JNC
2013-10-29 13:51:34,205 DEBUG [geotools.styling] - number of fts set 1
2013-10-29 13:51:34,206 INFO [geoserver.wms] -
XPixel = 381
YPixel = 261
GetMapRequest =
GetMap Request
version: 1.1.1
bbox: ReferencedEnvelope[4.756909 : 9.105218, -2.391651 : -0.483483]
layers: CADRG:JNC
styles: raster
FeatureCount = 50
Version = 1.1.1
Get = false
RawKvp = {INFO_FORMAT=text/html, BBOX=4.756909,-2.391651,9.105218,-0.483483, QUERY_LAYERS=CADRG:JNC, SERVICE=WMS, HEIGHT=330, REQUEST=GetFeatureInfo, STYLES=, WIDTH=752, EXCEPTIONS=application/vnd.ogc.se_xml, FEATURE_COUNT=50, VERSION=1.1.1, FORMAT=image/jpeg, LAYERS=CADRG:JNC, Y=261, X=381, SRS=EPSG:4326}
2013-10-29 13:51:34,217 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html
2013-10-29 13:51:34,217 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-29 13:51:38,424 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/CADRG/wms]
2013-10-29 13:51:38,425 DEBUG [ows.OWSHandlerMapping] - Mapping [/CADRG/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher@anonymised.com] and 1 interceptor
2013-10-29 13:51:38,427 INFO [geoserver.wms] -
2013-10-29 13:51:38,428 DEBUG [geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2013-10-29 13:51:38,428 DEBUG [geoserver.ows] - establishing raster style for CADRG:JNC
2013-10-29 13:51:38,431 DEBUG [geoserver.wms] - setting up map
2013-10-29 13:51:38,432 DEBUG [wms.map] - setting up 752x330 image
2013-10-29 13:51:38,433 DEBUG [gce.imagemosaic] - Using ThreadPoolExecutor with the following settings: core pool size = 5
max pool size = 10
2013-10-29 13:51:38,433 ERROR [geoserver.ows] -
… 89 more
… 90 more
2013-10-29 13:51:38,436 DEBUG [geoserver.filters] - Compressing output for mimetype: application/vnd.ogc.se_xml; charset=UTF-8
2013-10-29 13:51:38,437 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-29 13:51:45,022 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/CADRG/wms]
2013-10-29 13:51:45,022 DEBUG [ows.OWSHandlerMapping] - Mapping [/CADRG/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher@anonymised.com] and 1 interceptor
2013-10-29 13:51:45,024 INFO [geoserver.wms] -
2013-10-29 13:51:45,026 DEBUG [geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2013-10-29 13:51:45,026 DEBUG [geoserver.ows] - establishing raster style for CADRG:JNC
2013-10-29 13:51:45,029 DEBUG [geoserver.wms] - setting up map
2013-10-29 13:51:45,030 DEBUG [wms.map] - setting up 752x330 image
2013-10-29 13:51:45,032 DEBUG [gce.imagemosaic] - Using ThreadPoolExecutor with the following settings: core pool size = 5
max pool size = 10
2013-10-29 13:51:45,032 ERROR [geoserver.ows] -
… 89 more
… 90 more
2013-10-29 13:51:45,035 DEBUG [geoserver.filters] - Compressing output for mimetype: application/vnd.ogc.se_xml; charset=UTF-8
2013-10-29 13:51:45,036 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-29 13:52:32,131 DEBUG [geoserver.security] - Start searching for expired authentication tokens
2013-10-29 13:52:32,131 DEBUG [geoserver.security] - Number of expired authentication tokens found: 0
2013-10-29 13:52:32,131 DEBUG [geoserver.security] - End searching for expired authentication tokens
2013-10-29 13:53:32,144 DEBUG [geoserver.security] - Start searching for expired authentication tokens
2013-10-29 13:53:32,144 DEBUG [geoserver.security] - Number of expired authentication tokens found: 0
2013-10-29 13:53:32,145 DEBUG [geoserver.security] - End searching for expired authentication tokens
2013-10-29 13:54:25,939 DEBUG [org.geoserver] - Thread 49 locking in mode WRITE
2013-10-29 13:54:25,939 DEBUG [org.geoserver] - Thread 49 got the lock in mode WRITE
2013-10-29 13:54:25,962 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/admin/LogPage.html to file (URI scheme is not “file”), falling back to the inputstream for polling
2013-10-29 13:54:25,970 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI scheme is not “file”), falling back to the inputstream for polling
2013-10-29 13:54:25,973 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI scheme is not “file”), falling back to the inputstream for polling
2013-10-29 13:54:25,975 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/geoserver.css to file (URI scheme is not “file”), falling back to the inputstream for polling
2013-10-29 13:54:25,978 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI scheme is not “file”), falling back to the inputstream for polling
2013-10-29 13:54:25,982 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI scheme is not “file”), falling back to the inputstream for polling
2013-10-29 13:54:25,985 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI scheme is not “file”), falling back to the inputstream for polling
2013-10-29 13:54:26,088 DEBUG [org.geoserver] - Thread 49 releasing the lock in mode WRITE
2013-10-29 13:54:26,088 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html; charset=UTF-8
2013-10-29 13:54:26,093 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-29 13:54:32,147 DEBUG [geoserver.security] - Start searching for expired authentication tokens
2013-10-29 13:54:32,148 DEBUG [geoserver.security] - Number of expired authentication tokens found: 0
2013-10-29 13:54:32,148 DEBUG [geoserver.security] - End searching for expired authentication tokens
2013-10-29 13:55:32,150 DEBUG [geoserver.security] - Start searching for expired authentication tokens
2013-10-29 13:55:32,151 DEBUG [geoserver.security] - Number of expired authentication tokens found: 0
2013-10-29 13:55:32,151 DEBUG [geoserver.security] - End searching for expired authentication tokens
2013-10-29 13:56:21,238 DEBUG [org.geoserver] - Thread 12 locking in mode WRITE
2013-10-29 13:56:21,238 DEBUG [org.geoserver] - Thread 12 got the lock in mode WRITE
2013-10-29 13:56:21,242 DEBUG [org.geoserver] - Thread 12 releasing the lock in mode WRITE
2013-10-29 13:56:21,244 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-29 13:56:21,287 DEBUG [org.geoserver] - Thread 49 locking in mode WRITE
2013-10-29 13:56:21,287 DEBUG [org.geoserver] - Thread 49 got the lock in mode WRITE
2013-10-29 13:56:21,299 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI scheme is not “file”), falling back to the inputstream for polling
2013-10-29 13:56:21,302 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI scheme is not “file”), falling back to the inputstream for polling
2013-10-29 13:56:21,306 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/geoserver.css to file (URI scheme is not “file”), falling back to the inputstream for polling
2013-10-29 13:56:21,309 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI scheme is not “file”), falling back to the inputstream for polling
2013-10-29 13:56:21,313 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI scheme is not “file”), falling back to the inputstream for polling
2013-10-29 13:56:21,317 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI scheme is not “file”), falling back to the inputstream for polling
Thanks
David
From: maurobartolomeoli@anonymised.com [mailto:maurobartolomeoli@anonymised.com] On Behalf Of Mauro Bartolomeoli
Sent: Monday, October 28, 2013 1:41 PM
Hi David,
Mauro
Mauro,
Putty:
user
file:data
10.241.134.144
user – Username
****** - Password
Error code: 500
Log
org.geoserver.rest.RestletException: java.lang.IllegalArgumentException: This plugin accepts only File, URL and String pointing to a file
at org.geoserver.rest.ReflectiveResource.handleException(ReflectiveResource.java:325)
at org.geoserver.rest.ReflectiveResource.handlePost(ReflectiveResource.java:123)
at org.restlet.Finder.handle(Finder.java:296)
at org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:37)
at org.restlet.Filter.doHandle(Filter.java:105)
at org.restlet.Filter.handle(Filter.java:134)
at org.restlet.Router.handle(Router.java:444)
at org.geoserver.rest.RESTDispatcher$1.handle(RESTDispatcher.java:204)
at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:86)
… 70 more
To: Laratta, David (IS)
Mauro,
Mauro
Dott. Mauro Bartolomeoli
@mauro_bart
Senior Software Engineer
Via Poggio alle Viti 1187
@mauro_bart
@mauro_bart
On Wed, Oct 30, 2013 at 2:06 PM, Ballance, Melody (IS) <
Mauro is right, that error can only happen if you have a commons-io that's
older than 2.0
in the classpath, and it's getting picked up (the missing method in been
added in commons-io 2.0 according
to the javadocs,
http://commons.apache.org/proper/commons-io/apidocs/org/apache/commons/io/filefilter/FileFilterUtils.html#and(org.apache.commons.io.filefilter.IOFileFilter...)
It may be in the web container shared libs (which one are you using?), or
in the jre/lib/ext of your JRE,
or maybe some old GeoServer plugin got installed that carries the lib.
information.
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
All,
Currently I'm receiving an error when creating a datastore <url></url> The error is saying "Could not list layers for this store, an error occurred retrieving them: This plugin accepts only File, URL and String pointing to a file"
Attached is a pic of the error and below is the log.
Right now I have it working on a Is the issue a 2.3.3 GeoServer Windows machine but, I want to get it working on a 2.3.4 GeoServer is a Solaris(Unix) machine.
Thanks
David
2013-10-31 11:16:23,628 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2013-10-31 11:16:23,628 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.apache.wicket.markup.html.WicketEventReference/wicket-event.js]
2013-10-31 11:16:23,629 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2013-10-31 11:16:23,629 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.apache.wicket.markup.html.WicketEventReference/wicket-event.js]
2013-10-31 11:16:23,632 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/wicket-1.4.12.jar!/org/apache/wicket/markup/html/wicket-event.js to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,632 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/geoserver.css to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,633 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:16:23,633 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/print.css]
2013-10-31 11:16:23,633 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2013-10-31 11:16:23,634 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/print.css]
2013-10-31 11:16:23,634 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2013-10-31 11:16:23,635 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2013-10-31 11:16:23,635 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/print.css]
2013-10-31 11:16:23,635 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2013-10-31 11:16:23,635 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2013-10-31 11:16:23,636 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2013-10-31 11:16:23,636 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2013-10-31 11:16:23,637 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,637 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,637 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:16:23,638 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-demo-2.3.4.jar!/org/geoserver/web/demo/mappreview_keyshortcut.js to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,638 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,639 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:16:23,653 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.apache.wicket.extensions.ajax.markup.html.modal.ModalWindow/res/modal.js]
2013-10-31 11:16:23,653 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.apache.wicket.ajax.WicketAjaxReference/wicket-ajax.js]
2013-10-31 11:16:23,654 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.apache.wicket.ajax.WicketAjaxReference/wicket-ajax.js]
2013-10-31 11:16:23,654 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.apache.wicket.extensions.ajax.markup.html.modal.ModalWindow/res/modal.js]
2013-10-31 11:16:23,656 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/wicket-1.4.12.jar!/org/apache/wicket/ajax/wicket-ajax.js to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,656 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/wicket-extensions-1.4.12.jar!/org/apache/wicket/extensions/ajax/markup/html/modal/res/modal.js to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,657 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:16:23,657 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/favicon.ico]
2013-10-31 11:16:23,657 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.apache.wicket.extensions.ajax.markup.html.modal.ModalWindow/res/modal.css]
2013-10-31 11:16:23,658 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.apache.wicket.extensions.ajax.markup.html.modal.ModalWindow/res/modal.css]
2013-10-31 11:16:23,658 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/favicon.ico]
2013-10-31 11:16:23,660 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/favicon.ico to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,660 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/wicket-extensions-1.4.12.jar!/org/apache/wicket/extensions/ajax/markup/html/modal/res/modal.css to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,661 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:16:23,680 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/tick.png]
2013-10-31 11:16:23,681 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/tick.png]
2013-10-31 11:16:23,682 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/tick.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,683 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:16:23,852 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2013-10-31 11:16:23,852 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2013-10-31 11:16:23,852 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2013-10-31 11:16:23,852 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2013-10-31 11:16:23,853 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2013-10-31 11:16:23,853 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2013-10-31 11:16:23,853 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2013-10-31 11:16:23,853 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2013-10-31 11:16:23,854 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2013-10-31 11:16:23,854 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2013-10-31 11:16:23,855 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/help.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,855 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/page_white_text.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,855 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/server_error.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,855 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/vcard.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,856 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:16:23,858 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.workspace.WorkspacePage/null/null/img/icons/silk/folder.png]
2013-10-31 11:16:23,858 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/null/img/icons/geosilk/map.png]
2013-10-31 11:16:23,859 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.workspace.WorkspacePage/null/null/img/icons/silk/folder.png]
2013-10-31 11:16:23,859 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/null/img/icons/geosilk/map.png]
2013-10-31 11:16:23,861 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/geosilk/map.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,861 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/folder.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,862 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:16:23,874 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/delete.png]
2013-10-31 11:16:23,874 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2013-10-31 11:16:23,874 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/add.png]
2013-10-31 11:16:23,874 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/magnifier.png]
2013-10-31 11:16:23,875 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/add.png]
2013-10-31 11:16:23,875 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2013-10-31 11:16:23,875 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/delete.png]
2013-10-31 11:16:23,875 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/magnifier.png]
2013-10-31 11:16:23,876 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2013-10-31 11:16:23,876 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/add.png]
2013-10-31 11:16:23,876 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/magnifier.png]
2013-10-31 11:16:23,876 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/delete.png]
2013-10-31 11:16:23,877 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/delete.png]
2013-10-31 11:16:23,877 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/magnifier.png]
2013-10-31 11:16:23,878 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/delete.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,878 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/add.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,878 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/magnifier.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,878 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/database.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,879 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:16:23,882 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layer.LayerPage/null/null/img/icons/silk/picture_empty.png]
2013-10-31 11:16:23,882 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layergroup.LayerGroupPage/null/null/img/icons/silk/layers.png]
2013-10-31 11:16:23,883 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layergroup.LayerGroupPage/null/null/img/icons/silk/layers.png]
2013-10-31 11:16:23,883 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layer.LayerPage/null/null/img/icons/silk/picture_empty.png]
2013-10-31 11:16:23,885 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/layers.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,885 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/picture_empty.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,886 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:16:23,898 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wcs.web.WCSAdminPage/server_raster.png]
2013-10-31 11:16:23,898 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.data.StylePage/palette.png]
2013-10-31 11:16:23,898 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wfs.web.WFSAdminPage/server_vector.png]
2013-10-31 11:16:23,898 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.WMSAdminPage/server_map.png]
2013-10-31 11:16:23,899 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wfs.web.WFSAdminPage/server_vector.png]
2013-10-31 11:16:23,899 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.data.StylePage/palette.png]
2013-10-31 11:16:23,899 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wcs.web.WCSAdminPage/server_raster.png]
2013-10-31 11:16:23,899 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.WMSAdminPage/server_map.png]
2013-10-31 11:16:23,900 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wfs.web.WFSAdminPage/server_vector.png]
2013-10-31 11:16:23,900 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.data.StylePage/palette.png]
2013-10-31 11:16:23,900 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.WMSAdminPage/server_map.png]
2013-10-31 11:16:23,900 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wcs.web.WCSAdminPage/server_raster.png]
2013-10-31 11:16:23,901 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wcs.web.WCSAdminPage/server_raster.png]
2013-10-31 11:16:23,901 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.WMSAdminPage/server_map.png]
2013-10-31 11:16:23,902 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-wms-2.3.4.jar!/org/geoserver/wms/web/data/palette.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,902 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-wms-2.3.4.jar!/org/geoserver/wms/web/server_map.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,902 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-wfs-2.3.4.jar!/org/geoserver/wfs/web/server_vector.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,903 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-wcs-2.3.4.jar!/org/geoserver/wcs/web/server_raster.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,903 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:16:23,905 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.GlobalSettingsPage/null/img/icons/silk/server.png]
2013-10-31 11:16:23,905 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.JAIPage/null/img/icons/silk/cog_photo.png]
2013-10-31 11:16:23,906 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.GlobalSettingsPage/null/img/icons/silk/server.png]
2013-10-31 11:16:23,906 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.JAIPage/null/img/icons/silk/cog_photo.png]
2013-10-31 11:16:23,909 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/server.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,909 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,910 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:16:23,922 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.GWCSettingsPage/geowebcache-16.png]
2013-10-31 11:16:23,922 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.layer.CachedLayersPage/null/tilelayer.png]
2013-10-31 11:16:23,922 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.CoverageAccessPage/null/img/icons/silk/cog_photo.png]
2013-10-31 11:16:23,923 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.layer.CachedLayersPage/null/tilelayer.png]
2013-10-31 11:16:23,923 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.GWCSettingsPage/geowebcache-16.png]
2013-10-31 11:16:23,923 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.CoverageAccessPage/null/img/icons/silk/cog_photo.png]
2013-10-31 11:16:23,924 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.CoverageAccessPage/null/img/icons/silk/cog_photo.png]
2013-10-31 11:16:23,925 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,925 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-gwc-2.3.4.jar!/org/geoserver/gwc/web/tilelayer.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,925 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-gwc-2.3.4.jar!/org/geoserver/gwc/web/geowebcache-16.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,926 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:16:23,928 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/wrench.png]
2013-10-31 11:16:23,929 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.diskquota.DiskQuotaSettingsPage/null/diskquota.png]
2013-10-31 11:16:23,928 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.gridset.GridSetsPage/null/gridset.png]
2013-10-31 11:16:23,929 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/wrench.png]
2013-10-31 11:16:23,929 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.gridset.GridSetsPage/null/gridset.png]
2013-10-31 11:16:23,930 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.gridset.GridSetsPage/null/gridset.png]
2013-10-31 11:16:23,930 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/wrench.png]
2013-10-31 11:16:23,931 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-gwc-2.3.4.jar!/org/geoserver/gwc/web/diskquota.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,931 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/wrench.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,931 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-gwc-2.3.4.jar!/org/geoserver/gwc/web/gridset.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,932 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:16:23,944 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.auth.AuthenticationPage/null/img/icons/silk/shield.png]
2013-10-31 11:16:23,944 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.passwd.PasswordPage/null/img/icons/silk/lock.png]
2013-10-31 11:16:23,944 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.UserGroupRoleServicesPage/img/icons/silk/group.png]
2013-10-31 11:16:23,945 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.passwd.PasswordPage/null/img/icons/silk/lock.png]
2013-10-31 11:16:23,945 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.auth.AuthenticationPage/null/img/icons/silk/shield.png]
2013-10-31 11:16:23,945 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.UserGroupRoleServicesPage/img/icons/silk/group.png]
2013-10-31 11:16:23,946 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.passwd.PasswordPage/null/img/icons/silk/lock.png]
2013-10-31 11:16:23,946 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.UserGroupRoleServicesPage/img/icons/silk/group.png]
2013-10-31 11:16:23,946 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.auth.AuthenticationPage/null/img/icons/silk/shield.png]
2013-10-31 11:16:23,947 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-security-2.3.4.jar!/org/geoserver/security/web/img/icons/silk/lock.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,947 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-security-2.3.4.jar!/org/geoserver/security/web/img/icons/silk/group.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,947 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-security-2.3.4.jar!/org/geoserver/security/web/img/icons/silk/shield.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,948 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:16:23,950 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.data.DataSecurityPage/null/img/icons/silk/database_key.png]
2013-10-31 11:16:23,950 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.service.ServiceAccessRulePage/null/img/icons/silk/shape_square_key.png]
2013-10-31 11:16:23,950 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/logo.png]
2013-10-31 11:16:23,951 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/logo.png]
2013-10-31 11:16:23,951 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.service.ServiceAccessRulePage/null/img/icons/silk/shape_square_key.png]
2013-10-31 11:16:23,951 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.data.DataSecurityPage/null/img/icons/silk/database_key.png]
2013-10-31 11:16:23,952 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.service.ServiceAccessRulePage/null/img/icons/silk/shape_square_key.png]
2013-10-31 11:16:23,953 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/logo.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,953 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-security-2.3.4.jar!/org/geoserver/security/web/img/icons/silk/shape_square_key.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,953 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-security-2.3.4.jar!/org/geoserver/security/web/img/icons/silk/database_key.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,954 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:16:23,966 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/button-gradient.png]
2013-10-31 11:16:23,966 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/door_out.png]
2013-10-31 11:16:23,966 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/main-bg.png]
2013-10-31 11:16:23,967 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/main-bg.png]
2013-10-31 11:16:23,967 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/door_out.png]
2013-10-31 11:16:23,968 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/button-gradient.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,968 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/main-bg.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,968 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/door_out.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,969 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:16:23,972 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/main-wrap-bg.png]
2013-10-31 11:16:23,972 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/page-bg.png]
2013-10-31 11:16:23,972 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/page-header-bg.png]
2013-10-31 11:16:23,973 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/page-bg.png]
2013-10-31 11:16:23,973 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/page-header-bg.png]
2013-10-31 11:16:23,973 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/main-wrap-bg.png]
2013-10-31 11:16:23,974 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/main-wrap-bg.png]
2013-10-31 11:16:23,974 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/page-header-bg.png]
2013-10-31 11:16:23,975 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/page-bg.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,975 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/main-wrap-bg.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,975 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/page-header-bg.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,976 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:16:23,987 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/ajax-loader.gif]
2013-10-31 11:16:23,989 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/ajax-loader.gif to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,989 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:17:05,800 DEBUG [geoserver.security] - Start searching for expired authentication tokens
2013-10-31 11:17:05,800 DEBUG [geoserver.security] - Number of expired authentication tokens found: 0
2013-10-31 11:17:05,800 DEBUG [geoserver.security] - End searching for expired authentication tokens
2013-10-31 11:18:05,810 DEBUG [geoserver.security] - Start searching for expired authentication tokens
2013-10-31 11:18:05,810 DEBUG [geoserver.security] - Number of expired authentication tokens found: 0
2013-10-31 11:18:05,810 DEBUG [geoserver.security] - End searching for expired authentication tokens
2013-10-31 11:19:05,820 DEBUG [geoserver.security] - Start searching for expired authentication tokens
2013-10-31 11:19:05,820 DEBUG [geoserver.security] - Number of expired authentication tokens found: 0
2013-10-31 11:19:05,820 DEBUG [geoserver.security] - End searching for expired authentication tokens
2013-10-31 11:20:05,830 DEBUG [geoserver.security] - Start searching for expired authentication tokens
2013-10-31 11:20:05,830 DEBUG [geoserver.security] - Number of expired authentication tokens found: 0
2013-10-31 11:20:05,830 DEBUG [geoserver.security] - End searching for expired authentication tokens
2013-10-31 11:20:52,188 DEBUG [geoserver.security] - preAuthenticatedPrincipal = c2cs.svc@anonymised.com, trying to authenticate
2013-10-31 11:20:52,188 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - Converted URL to lowercase, from: '/rest/workspaces'; to: '/rest/workspaces' and httpMethod= POST
2013-10-31 11:20:52,189 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /** methodList= [GET]
2013-10-31 11:20:52,189 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/workspaces'; antPath is /**; matchedPath=true; matchedMethods=false
2013-10-31 11:20:52,189 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /** methodList= [POST, DELETE, PUT]
2013-10-31 11:20:52,189 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/workspaces'; antPath is /**; matchedPath=true; matchedMethods=true
2013-10-31 11:20:52,189 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - returning ADMIN
2013-10-31 11:20:52,190 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/rest/workspaces/]
2013-10-31 11:20:52,196 DEBUG [org.geoserver] - Thread 12 locking in mode WRITE
2013-10-31 11:20:52,197 DEBUG [org.geoserver] - Thread 12 got the lock in mode WRITE
2013-10-31 11:20:52,213 DEBUG [org.geoserver] - Thread 12 releasing the lock in mode WRITE
2013-10-31 11:20:52,213 ERROR [geoserver.rest] - :Workspace named 'CADRG' already exists.
org.geoserver.rest.RestletException: java.lang.IllegalArgumentException: Workspace named 'CADRG' already exists.
                at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
                at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
                at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
                at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:789)
                at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
                at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
                at weblogic.servlet.internal.StubSecurityHelper$ServletServiceAction.run(StubSecurityHelper.java:227)
                at weblogic.servlet.internal.StubSecurityHelper.invokeServlet(StubSecurityHelper.java:125)
                at weblogic.servlet.internal.ServletStubImpl.execute(ServletStubImpl.java:301)
                at weblogic.servlet.internal.TailFilter.doFilter(TailFilter.java:26)
                at weblogic.servlet.internal.FilterChainImpl.doFilter(FilterChainImpl.java:60)
                at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:27)
                at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
                at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
                at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
                at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
                at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
                at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
                at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
                at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
                at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
                at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
                at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
                at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
                at org.geoserver.security.filter.GeoServerPreAuthenticationFilter.doFilter(GeoServerPreAuthenticationFilter.java:74)
                at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
                at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
                at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
                at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:134)
                at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
                at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
                at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:75)
                at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:48)
                at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:47)
                at weblogic.servlet.internal.WebAppServletContext$ServletInvocationAction.wrapRun(WebAppServletContext.java:3739)
                at weblogic.servlet.internal.WebAppServletContext$ServletInvocationAction.run(WebAppServletContext.java:3705)
                at weblogic.security.acl.internal.AuthenticatedSubject.doAs(AuthenticatedSubject.java:321)
                at weblogic.security.service.SecurityManager.runAs(SecurityManager.java:120)
                at weblogic.servlet.internal.WebAppServletContext.securedExecute(WebAppServletContext.java:2282)
                at weblogic.servlet.internal.WebAppServletContext.execute(WebAppServletContext.java:2181)
                at weblogic.servlet.internal.ServletRequestImpl.run(ServletRequestImpl.java:1491)
                at weblogic.work.ExecuteThread.execute(ExecuteThread.java:256)
                at weblogic.work.ExecuteThread.run(ExecuteThread.java:221)
Caused by: java.lang.IllegalArgumentException: Workspace named 'CADRG' already exists.
                at org.geoserver.catalog.impl.CatalogImpl.validate(CatalogImpl.java:1144)
                at org.geoserver.catalog.impl.CatalogImpl.add(CatalogImpl.java:1115)
                at org.geoserver.security.SecureCatalogImpl.add(SecureCatalogImpl.java:1176)
                at org.geoserver.catalog.impl.AbstractFilteredCatalog.add(AbstractFilteredCatalog.java:619)
                at org.geoserver.catalog.impl.AbstractCatalogDecorator.add(AbstractCatalogDecorator.java:585)
                at org.geoserver.catalog.rest.WorkspaceResource.handleObjectPost(WorkspaceResource.java:93)
                at org.geoserver.rest.ReflectiveResource.handlePost(ReflectiveResource.java:120)
                ... 70 more
2013-10-31 11:20:52,216 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:20:52,260 DEBUG [geoserver.security] - preAuthenticatedPrincipal = c2cs.svc@anonymised.com, trying to authenticate
2013-10-31 11:20:52,260 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - Converted URL to lowercase, from: '/rest/workspaces/cadrg/coveragestores'; to: '/rest/workspaces/cadrg/coveragestores' and httpMethod= POST
2013-10-31 11:20:52,260 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /** methodList= [GET]
2013-10-31 11:20:52,261 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/workspaces/cadrg/coveragestores'; antPath is /**; matchedPath=true; matchedMethods=false
2013-10-31 11:20:52,261 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /** methodList= [POST, DELETE, PUT]
2013-10-31 11:20:52,261 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/workspaces/cadrg/coveragestores'; antPath is /**; matchedPath=true; matchedMethods=true
2013-10-31 11:20:52,261 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - returning ADMIN
2013-10-31 11:20:52,261 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/rest/workspaces/CADRG/coveragestores]
2013-10-31 11:20:52,262 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/rest/workspaces/CADRG/coveragestores]
2013-10-31 11:20:52,270 DEBUG [org.geoserver] - Thread 48 locking in mode WRITE
2013-10-31 11:20:52,270 DEBUG [org.geoserver] - Thread 48 got the lock in mode WRITE
2013-10-31 11:20:52,301 INFO [org.geoserver] - Loaded store 'JNC', enabled
2013-10-31 11:20:52,306 DEBUG [org.geoserver] - Thread 48 releasing the lock in mode WRITE
2013-10-31 11:20:52,306 ERROR [geoserver.rest] - :Store 'JNC' already exists in workspace 'CADRG'
2013-10-31 11:20:52,307 ERROR [geoserver.rest] -
org.geoserver.rest.RestletException: java.lang.IllegalArgumentException: Store 'JNC' already exists in workspace 'CADRG'
Caused by: java.lang.IllegalArgumentException: Store 'JNC' already exists in workspace 'CADRG'
                at org.geoserver.catalog.impl.CatalogImpl.validate(CatalogImpl.java:176)
                at org.geoserver.catalog.impl.CatalogImpl.add(CatalogImpl.java:149)
                at org.geoserver.security.SecureCatalogImpl.add(SecureCatalogImpl.java:1151)
                at org.geoserver.catalog.impl.AbstractFilteredCatalog.add(AbstractFilteredCatalog.java:595)
                at org.geoserver.catalog.impl.AbstractCatalogDecorator.add(AbstractCatalogDecorator.java:79)
                at org.geoserver.catalog.rest.CoverageStoreResource.handleObjectPost(CoverageStoreResource.java:66)
                ... 70 more
2013-10-31 11:20:52,309 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:20:52,356 DEBUG [geoserver.security] - preAuthenticatedPrincipal = c2cs.svc@anonymised.com, trying to authenticate
2013-10-31 11:20:52,356 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - Converted URL to lowercase, from: '/rest/workspaces/cadrg/coveragestores/jnc/coverages'; to: '/rest/workspaces/cadrg/coveragestores/jnc/coverages' and httpMethod= POST
2013-10-31 11:20:52,356 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /** methodList= [GET]
2013-10-31 11:20:52,357 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/workspaces/cadrg/coveragestores/jnc/coverages'; antPath is /**; matchedPath=true; matchedMethods=false
2013-10-31 11:20:52,357 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /** methodList= [POST, DELETE, PUT]
2013-10-31 11:20:52,357 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/workspaces/cadrg/coveragestores/jnc/coverages'; antPath is /**; matchedPath=true; matchedMethods=true
2013-10-31 11:20:52,357 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - returning ADMIN
2013-10-31 11:20:52,357 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/rest/workspaces/CADRG/coveragestores/JNC/coverages]
2013-10-31 11:20:52,358 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/rest/workspaces/CADRG/coveragestores/JNC/coverages]
2013-10-31 11:20:52,361 DEBUG [org.geoserver] - Thread 12 locking in mode WRITE
2013-10-31 11:20:52,362 DEBUG [org.geoserver] - Thread 12 got the lock in mode WRITE
2013-10-31 11:20:52,379 INFO [org.geoserver] - Loaded coverage 'JNC', disabled
2013-10-31 11:20:52,394 DEBUG [geoserver.config] - Persisting coverage JNC
2013-10-31 11:20:52,407 DEBUG [geoserver.config] - Persisted $Proxy117 to /h/data/global/GEOSRV/data/workspaces/CADRG/JNC/JNC/coverage.xml
2013-10-31 11:20:52,415 DEBUG [geoserver.config] - Persisted $Proxy125 to /h/data/global/GEOSRV/data/global.xml
2013-10-31 11:20:52,415 DEBUG [catalog.impl] - Warning, some code is setting the LayerInfo name, but that will be ignored
2013-10-31 11:20:52,423 DEBUG [geoserver.config] - Persisting layer JNC
2013-10-31 11:20:52,426 DEBUG [geoserver.config] - Persisted $Proxy119 to /h/data/global/GEOSRV/data/workspaces/CADRG/JNC/JNC/layer.xml
2013-10-31 11:20:52,427 DEBUG [gwc.layer] - Handling add event: LayerInfoImpl[JNC, resource:CoverageInfoImpl[JNC]]
2013-10-31 11:20:52,447 DEBUG [gwc.layer] - Depersisting GeoServerTileLayerInfo from /h/data/global/GEOSRV/data/gwc-layers/LayerInfoImpl--2fcd5d73_142099d6317_-7fee.xml.tmp
2013-10-31 11:20:52,454 DEBUG [geoserver.config] - Persisted $Proxy125 to /h/data/global/GEOSRV/data/global.xml
2013-10-31 11:20:52,454 INFO [catalog.rest] - POST coverage JNC,JNC
2013-10-31 11:20:52,455 DEBUG [org.geoserver] - Thread 12 releasing the lock in mode WRITE
2013-10-31 11:20:52,456 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:21:05,840 DEBUG [geoserver.security] - Start searching for expired authentication tokens
2013-10-31 11:21:05,840 DEBUG [geoserver.security] - Number of expired authentication tokens found: 0
2013-10-31 11:21:05,840 DEBUG [geoserver.security] - End searching for expired authentication tokens
2013-10-31 11:21:38,916 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2013-10-31 11:21:38,917 DEBUG [org.geoserver] - Thread 45 locking in mode WRITE
2013-10-31 11:21:38,917 DEBUG [org.geoserver] - Thread 45 got the lock in mode WRITE
2013-10-31 11:21:38,934 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/admin/LogPage.html to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:38,941 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:38,943 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:38,946 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/geoserver.css to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:38,948 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:38,951 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:38,953 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:39,114 DEBUG [org.geoserver] - Thread 45 releasing the lock in mode WRITE
2013-10-31 11:21:39,114 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html; charset=UTF-8
2013-10-31 11:21:39,122 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:21:48,509 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/screen.css]
2013-10-31 11:21:48,510 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/screen.css]
2013-10-31 11:21:48,512 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,512 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:21:48,608 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/favicon.ico]
2013-10-31 11:21:48,609 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/favicon.ico]
2013-10-31 11:21:48,612 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/favicon.ico to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,612 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2013-10-31 11:21:48,612 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/print.css]
2013-10-31 11:21:48,612 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2013-10-31 11:21:48,613 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/print.css]
2013-10-31 11:21:48,613 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2013-10-31 11:21:48,613 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:21:48,613 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2013-10-31 11:21:48,614 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/print.css]
2013-10-31 11:21:48,614 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2013-10-31 11:21:48,614 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2013-10-31 11:21:48,615 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2013-10-31 11:21:48,615 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2013-10-31 11:21:48,616 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,616 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,616 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/geoserver.css to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,616 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2013-10-31 11:21:48,617 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2013-10-31 11:21:48,617 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:21:48,619 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,619 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2013-10-31 11:21:48,620 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2013-10-31 11:21:48,620 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:21:48,623 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-demo-2.3.4.jar!/org/geoserver/web/demo/mappreview_keyshortcut.js to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,623 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:21:48,694 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2013-10-31 11:21:48,694 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2013-10-31 11:21:48,694 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2013-10-31 11:21:48,694 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2013-10-31 11:21:48,695 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2013-10-31 11:21:48,695 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2013-10-31 11:21:48,695 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2013-10-31 11:21:48,695 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2013-10-31 11:21:48,696 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2013-10-31 11:21:48,696 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2013-10-31 11:21:48,696 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2013-10-31 11:21:48,696 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2013-10-31 11:21:48,697 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/help.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,698 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/page_white_text.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,697 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/vcard.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,697 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/server_error.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,698 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:21:48,702 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/null/img/icons/geosilk/map.png]
2013-10-31 11:21:48,702 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.workspace.WorkspacePage/null/null/img/icons/silk/folder.png]
2013-10-31 11:21:48,703 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.workspace.WorkspacePage/null/null/img/icons/silk/folder.png]
2013-10-31 11:21:48,703 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/null/img/icons/geosilk/map.png]
2013-10-31 11:21:48,704 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/folder.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,704 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/geosilk/map.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,705 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:21:48,720 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.data.StylePage/palette.png]
2013-10-31 11:21:48,720 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layergroup.LayerGroupPage/null/null/img/icons/silk/layers.png]
2013-10-31 11:21:48,720 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layer.LayerPage/null/null/img/icons/silk/picture_empty.png]
2013-10-31 11:21:48,720 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2013-10-31 11:21:48,721 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layer.LayerPage/null/null/img/icons/silk/picture_empty.png]
2013-10-31 11:21:48,721 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layergroup.LayerGroupPage/null/null/img/icons/silk/layers.png]
2013-10-31 11:21:48,721 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2013-10-31 11:21:48,721 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.data.StylePage/palette.png]
2013-10-31 11:21:48,722 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layergroup.LayerGroupPage/null/null/img/icons/silk/layers.png]
2013-10-31 11:21:48,722 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layer.LayerPage/null/null/img/icons/silk/picture_empty.png]
2013-10-31 11:21:48,722 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2013-10-31 11:21:48,723 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.data.StylePage/palette.png]
2013-10-31 11:21:48,723 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2013-10-31 11:21:48,724 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-wms-2.3.4.jar!/org/geoserver/wms/web/data/palette.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,724 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/picture_empty.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,724 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/layers.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,724 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/database.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,725 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:21:48,727 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.WMSAdminPage/server_map.png]
2013-10-31 11:21:48,727 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wfs.web.WFSAdminPage/server_vector.png]
2013-10-31 11:21:48,728 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wfs.web.WFSAdminPage/server_vector.png]
2013-10-31 11:21:48,728 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.WMSAdminPage/server_map.png]
2013-10-31 11:21:48,729 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-wms-2.3.4.jar!/org/geoserver/wms/web/server_map.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,729 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-wfs-2.3.4.jar!/org/geoserver/wfs/web/server_vector.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,730 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:21:48,744 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.GlobalSettingsPage/null/img/icons/silk/server.png]
2013-10-31 11:21:48,744 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.CoverageAccessPage/null/img/icons/silk/cog_photo.png]
2013-10-31 11:21:48,744 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.JAIPage/null/img/icons/silk/cog_photo.png]
2013-10-31 11:21:48,744 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wcs.web.WCSAdminPage/server_raster.png]
2013-10-31 11:21:48,745 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.JAIPage/null/img/icons/silk/cog_photo.png]
2013-10-31 11:21:48,745 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.CoverageAccessPage/null/img/icons/silk/cog_photo.png]
2013-10-31 11:21:48,745 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.GlobalSettingsPage/null/img/icons/silk/server.png]
2013-10-31 11:21:48,745 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wcs.web.WCSAdminPage/server_raster.png]
2013-10-31 11:21:48,746 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.GlobalSettingsPage/null/img/icons/silk/server.png]
2013-10-31 11:21:48,746 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wcs.web.WCSAdminPage/server_raster.png]
2013-10-31 11:21:48,747 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/server.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,747 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-wcs-2.3.4.jar!/org/geoserver/wcs/web/server_raster.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,747 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,748 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:21:48,750 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.GWCSettingsPage/geowebcache-16.png]
2013-10-31 11:21:48,750 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.layer.CachedLayersPage/null/tilelayer.png]
2013-10-31 11:21:48,751 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.GWCSettingsPage/geowebcache-16.png]
2013-10-31 11:21:48,751 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.layer.CachedLayersPage/null/tilelayer.png]
2013-10-31 11:21:48,752 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-gwc-2.3.4.jar!/org/geoserver/gwc/web/tilelayer.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,752 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-gwc-2.3.4.jar!/org/geoserver/gwc/web/geowebcache-16.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,753 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:21:48,766 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/wrench.png]
2013-10-31 11:21:48,766 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.gridset.GridSetsPage/null/gridset.png]
2013-10-31 11:21:48,767 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.auth.AuthenticationPage/null/img/icons/silk/shield.png]
2013-10-31 11:21:48,766 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.diskquota.DiskQuotaSettingsPage/null/diskquota.png]
2013-10-31 11:21:48,767 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.gridset.GridSetsPage/null/gridset.png]
2013-10-31 11:21:48,767 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/wrench.png]
2013-10-31 11:21:48,767 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.diskquota.DiskQuotaSettingsPage/null/diskquota.png]
2013-10-31 11:21:48,768 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.diskquota.DiskQuotaSettingsPage/null/diskquota.png]
2013-10-31 11:21:48,768 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/wrench.png]
2013-10-31 11:21:48,768 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.auth.AuthenticationPage/null/img/icons/silk/shield.png]
2013-10-31 11:21:48,768 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.gridset.GridSetsPage/null/gridset.png]
2013-10-31 11:21:48,770 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-security-2.3.4.jar!/org/geoserver/security/web/img/icons/silk/shield.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,770 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/wrench.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,770 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-gwc-2.3.4.jar!/org/geoserver/gwc/web/diskquota.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,770 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-gwc-2.3.4.jar!/org/geoserver/gwc/web/gridset.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,771 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:21:48,773 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.UserGroupRoleServicesPage/img/icons/silk/group.png]
2013-10-31 11:21:48,773 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.passwd.PasswordPage/null/img/icons/silk/lock.png]
2013-10-31 11:21:48,774 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.passwd.PasswordPage/null/img/icons/silk/lock.png]
2013-10-31 11:21:48,774 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.UserGroupRoleServicesPage/img/icons/silk/group.png]
2013-10-31 11:21:48,776 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-security-2.3.4.jar!/org/geoserver/security/web/img/icons/silk/lock.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,776 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-security-2.3.4.jar!/org/geoserver/security/web/img/icons/silk/group.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,776 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:21:48,789 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.data.DataSecurityPage/null/img/icons/silk/database_key.png]
2013-10-31 11:21:48,789 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.service.ServiceAccessRulePage/null/img/icons/silk/shape_square_key.png]
2013-10-31 11:21:48,789 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/ajax-loader.gif]
2013-10-31 11:21:48,790 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.service.ServiceAccessRulePage/null/img/icons/silk/shape_square_key.png]
2013-10-31 11:21:48,790 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.data.DataSecurityPage/null/img/icons/silk/database_key.png]
2013-10-31 11:21:48,790 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/ajax-loader.gif]
2013-10-31 11:21:48,791 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.service.ServiceAccessRulePage/null/img/icons/silk/shape_square_key.png]
2013-10-31 11:21:48,791 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/ajax-loader.gif]
2013-10-31 11:21:48,791 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.data.DataSecurityPage/null/img/icons/silk/database_key.png]
2013-10-31 11:21:48,792 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-security-2.3.4.jar!/org/geoserver/security/web/img/icons/silk/shape_square_key.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,792 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/ajax-loader.gif to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,792 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-security-2.3.4.jar!/org/geoserver/security/web/img/icons/silk/database_key.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,793 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:21:49,669 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/main-bg.png]
2013-10-31 11:21:49,669 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/button-gradient.png]
2013-10-31 11:21:49,669 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/main-wrap-bg.png]
2013-10-31 11:21:49,669 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/logo.png]
2013-10-31 11:21:49,670 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/main-wrap-bg.png]
2013-10-31 11:21:49,670 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/button-gradient.png]
2013-10-31 11:21:49,670 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/main-bg.png]
2013-10-31 11:21:49,670 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/logo.png]
2013-10-31 11:21:49,671 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/logo.png]
2013-10-31 11:21:49,671 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/button-gradient.png]
2013-10-31 11:21:49,671 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/main-wrap-bg.png]
2013-10-31 11:21:49,671 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/main-bg.png]
2013-10-31 11:21:49,672 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/main-bg.png]
2013-10-31 11:21:49,673 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/main-bg.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:49,673 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/logo.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:49,673 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/button-gradient.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:49,673 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/main-wrap-bg.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:49,674 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:21:49,676 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/door_out.png]
2013-10-31 11:21:49,676 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/page-bg.png]
2013-10-31 11:21:49,677 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/door_out.png]
2013-10-31 11:21:49,677 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/page-bg.png]
2013-10-31 11:21:49,678 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/page-bg.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:49,678 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/door_out.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:49,679 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:21:49,692 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/page-header-bg.png]
2013-10-31 11:21:49,693 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/page-header-bg.png]
2013-10-31 11:21:49,695 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/page-header-bg.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:49,695 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:22:05,850 DEBUG [geoserver.security] - Start searching for expired authentication tokens
2013-10-31 11:22:05,850 DEBUG [geoserver.security] - Number of expired authentication tokens found: 0
2013-10-31 11:22:05,850 DEBUG [geoserver.security] - End searching for expired authentication tokens
2013-10-31 11:22:13,524 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2013-10-31 11:22:13,525 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2013-10-31 11:22:13,528 DEBUG [org.geoserver] - Thread 12 locking in mode WRITE
2013-10-31 11:22:13,528 DEBUG [org.geoserver] - Thread 12 got the lock in mode WRITE
2013-10-31 11:22:13,551 DEBUG [org.geoserver] - Thread 12 releasing the lock in mode WRITE
2013-10-31 11:22:13,552 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:22:13,614 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2013-10-31 11:22:13,615 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2013-10-31 11:22:13,615 DEBUG [org.geoserver] - Thread 19 locking in mode WRITE
2013-10-31 11:22:13,615 DEBUG [org.geoserver] - Thread 19 got the lock in mode WRITE
2013-10-31 11:22:13,624 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:22:13,627 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:22:13,630 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/geoserver.css to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:22:13,633 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:22:13,636 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:22:13,639 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI scheme is not "file"), falling back to the inputstream for polling
All,
Currently I'm receiving an error when creating a datastore <url></url> The error is saying "Could not list layers for this store, an error occurred retrieving them: This plugin accepts only File, URL and String pointing to a file"
Attached is a pic of the error and below is the log.
Right now I have it working on a Is the issue a 2.3.3 GeoServer Windows machine but, I want to get it working on a 2.3.4 GeoServer is a Solaris(Unix) machine.
Thanks
David
2013-10-31 11:16:23,628 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2013-10-31 11:16:23,628 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.apache.wicket.markup.html.WicketEventReference/wicket-event.js]
2013-10-31 11:16:23,629 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2013-10-31 11:16:23,629 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.apache.wicket.markup.html.WicketEventReference/wicket-event.js]
2013-10-31 11:16:23,632 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/wicket-1.4.12.jar!/org/apache/wicket/markup/html/wicket-event.js to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,632 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/geoserver.css to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,633 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:16:23,633 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/print.css]
2013-10-31 11:16:23,633 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2013-10-31 11:16:23,634 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/print.css]
2013-10-31 11:16:23,634 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2013-10-31 11:16:23,635 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2013-10-31 11:16:23,635 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/print.css]
2013-10-31 11:16:23,635 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2013-10-31 11:16:23,635 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2013-10-31 11:16:23,636 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2013-10-31 11:16:23,636 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2013-10-31 11:16:23,637 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,637 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,637 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:16:23,638 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-demo-2.3.4.jar!/org/geoserver/web/demo/mappreview_keyshortcut.js to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,638 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,639 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:16:23,653 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.apache.wicket.extensions.ajax.markup.html.modal.ModalWindow/res/modal.js]
2013-10-31 11:16:23,653 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.apache.wicket.ajax.WicketAjaxReference/wicket-ajax.js]
2013-10-31 11:16:23,654 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.apache.wicket.ajax.WicketAjaxReference/wicket-ajax.js]
2013-10-31 11:16:23,654 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.apache.wicket.extensions.ajax.markup.html.modal.ModalWindow/res/modal.js]
2013-10-31 11:16:23,656 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/wicket-1.4.12.jar!/org/apache/wicket/ajax/wicket-ajax.js to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,656 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/wicket-extensions-1.4.12.jar!/org/apache/wicket/extensions/ajax/markup/html/modal/res/modal.js to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,657 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:16:23,657 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/favicon.ico]
2013-10-31 11:16:23,657 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.apache.wicket.extensions.ajax.markup.html.modal.ModalWindow/res/modal.css]
2013-10-31 11:16:23,658 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.apache.wicket.extensions.ajax.markup.html.modal.ModalWindow/res/modal.css]
2013-10-31 11:16:23,658 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/favicon.ico]
2013-10-31 11:16:23,660 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/favicon.ico to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,660 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/wicket-extensions-1.4.12.jar!/org/apache/wicket/extensions/ajax/markup/html/modal/res/modal.css to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,661 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:16:23,680 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/tick.png]
2013-10-31 11:16:23,681 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/tick.png]
2013-10-31 11:16:23,682 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/tick.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,683 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:16:23,852 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2013-10-31 11:16:23,852 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2013-10-31 11:16:23,852 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2013-10-31 11:16:23,852 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2013-10-31 11:16:23,853 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2013-10-31 11:16:23,853 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2013-10-31 11:16:23,853 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2013-10-31 11:16:23,853 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2013-10-31 11:16:23,854 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2013-10-31 11:16:23,854 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2013-10-31 11:16:23,855 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/help.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,855 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/page_white_text.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,855 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/server_error.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,855 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/vcard.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,856 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:16:23,858 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.workspace.WorkspacePage/null/null/img/icons/silk/folder.png]
2013-10-31 11:16:23,858 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/null/img/icons/geosilk/map.png]
2013-10-31 11:16:23,859 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.workspace.WorkspacePage/null/null/img/icons/silk/folder.png]
2013-10-31 11:16:23,859 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/null/img/icons/geosilk/map.png]
2013-10-31 11:16:23,861 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/geosilk/map.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,861 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/folder.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,862 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:16:23,874 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/delete.png]
2013-10-31 11:16:23,874 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2013-10-31 11:16:23,874 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/add.png]
2013-10-31 11:16:23,874 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/magnifier.png]
2013-10-31 11:16:23,875 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/add.png]
2013-10-31 11:16:23,875 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2013-10-31 11:16:23,875 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/delete.png]
2013-10-31 11:16:23,875 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/magnifier.png]
2013-10-31 11:16:23,876 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2013-10-31 11:16:23,876 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/add.png]
2013-10-31 11:16:23,876 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/magnifier.png]
2013-10-31 11:16:23,876 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/delete.png]
2013-10-31 11:16:23,877 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/delete.png]
2013-10-31 11:16:23,877 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/magnifier.png]
2013-10-31 11:16:23,878 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/delete.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,878 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/add.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,878 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/magnifier.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,878 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/database.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,879 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:16:23,882 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layer.LayerPage/null/null/img/icons/silk/picture_empty.png]
2013-10-31 11:16:23,882 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layergroup.LayerGroupPage/null/null/img/icons/silk/layers.png]
2013-10-31 11:16:23,883 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layergroup.LayerGroupPage/null/null/img/icons/silk/layers.png]
2013-10-31 11:16:23,883 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layer.LayerPage/null/null/img/icons/silk/picture_empty.png]
2013-10-31 11:16:23,885 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/layers.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,885 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/picture_empty.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,886 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:16:23,898 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wcs.web.WCSAdminPage/server_raster.png]
2013-10-31 11:16:23,898 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.data.StylePage/palette.png]
2013-10-31 11:16:23,898 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wfs.web.WFSAdminPage/server_vector.png]
2013-10-31 11:16:23,898 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.WMSAdminPage/server_map.png]
2013-10-31 11:16:23,899 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wfs.web.WFSAdminPage/server_vector.png]
2013-10-31 11:16:23,899 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.data.StylePage/palette.png]
2013-10-31 11:16:23,899 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wcs.web.WCSAdminPage/server_raster.png]
2013-10-31 11:16:23,899 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.WMSAdminPage/server_map.png]
2013-10-31 11:16:23,900 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wfs.web.WFSAdminPage/server_vector.png]
2013-10-31 11:16:23,900 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.data.StylePage/palette.png]
2013-10-31 11:16:23,900 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.WMSAdminPage/server_map.png]
2013-10-31 11:16:23,900 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wcs.web.WCSAdminPage/server_raster.png]
2013-10-31 11:16:23,901 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wcs.web.WCSAdminPage/server_raster.png]
2013-10-31 11:16:23,901 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.WMSAdminPage/server_map.png]
2013-10-31 11:16:23,902 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-wms-2.3.4.jar!/org/geoserver/wms/web/data/palette.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,902 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-wms-2.3.4.jar!/org/geoserver/wms/web/server_map.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,902 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-wfs-2.3.4.jar!/org/geoserver/wfs/web/server_vector.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,903 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-wcs-2.3.4.jar!/org/geoserver/wcs/web/server_raster.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,903 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:16:23,905 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.GlobalSettingsPage/null/img/icons/silk/server.png]
2013-10-31 11:16:23,905 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.JAIPage/null/img/icons/silk/cog_photo.png]
2013-10-31 11:16:23,906 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.GlobalSettingsPage/null/img/icons/silk/server.png]
2013-10-31 11:16:23,906 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.JAIPage/null/img/icons/silk/cog_photo.png]
2013-10-31 11:16:23,909 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/server.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,909 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,910 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:16:23,922 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.GWCSettingsPage/geowebcache-16.png]
2013-10-31 11:16:23,922 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.layer.CachedLayersPage/null/tilelayer.png]
2013-10-31 11:16:23,922 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.CoverageAccessPage/null/img/icons/silk/cog_photo.png]
2013-10-31 11:16:23,923 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.layer.CachedLayersPage/null/tilelayer.png]
2013-10-31 11:16:23,923 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.GWCSettingsPage/geowebcache-16.png]
2013-10-31 11:16:23,923 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.CoverageAccessPage/null/img/icons/silk/cog_photo.png]
2013-10-31 11:16:23,924 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.CoverageAccessPage/null/img/icons/silk/cog_photo.png]
2013-10-31 11:16:23,925 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,925 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-gwc-2.3.4.jar!/org/geoserver/gwc/web/tilelayer.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,925 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-gwc-2.3.4.jar!/org/geoserver/gwc/web/geowebcache-16.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,926 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:16:23,928 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/wrench.png]
2013-10-31 11:16:23,929 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.diskquota.DiskQuotaSettingsPage/null/diskquota.png]
2013-10-31 11:16:23,928 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.gridset.GridSetsPage/null/gridset.png]
2013-10-31 11:16:23,929 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/wrench.png]
2013-10-31 11:16:23,929 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.gridset.GridSetsPage/null/gridset.png]
2013-10-31 11:16:23,930 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.gridset.GridSetsPage/null/gridset.png]
2013-10-31 11:16:23,930 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/wrench.png]
2013-10-31 11:16:23,931 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-gwc-2.3.4.jar!/org/geoserver/gwc/web/diskquota.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,931 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/wrench.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,931 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-gwc-2.3.4.jar!/org/geoserver/gwc/web/gridset.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,932 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:16:23,944 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.auth.AuthenticationPage/null/img/icons/silk/shield.png]
2013-10-31 11:16:23,944 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.passwd.PasswordPage/null/img/icons/silk/lock.png]
2013-10-31 11:16:23,944 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.UserGroupRoleServicesPage/img/icons/silk/group.png]
2013-10-31 11:16:23,945 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.passwd.PasswordPage/null/img/icons/silk/lock.png]
2013-10-31 11:16:23,945 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.auth.AuthenticationPage/null/img/icons/silk/shield.png]
2013-10-31 11:16:23,945 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.UserGroupRoleServicesPage/img/icons/silk/group.png]
2013-10-31 11:16:23,946 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.passwd.PasswordPage/null/img/icons/silk/lock.png]
2013-10-31 11:16:23,946 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.UserGroupRoleServicesPage/img/icons/silk/group.png]
2013-10-31 11:16:23,946 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.auth.AuthenticationPage/null/img/icons/silk/shield.png]
2013-10-31 11:16:23,947 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-security-2.3.4.jar!/org/geoserver/security/web/img/icons/silk/lock.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,947 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-security-2.3.4.jar!/org/geoserver/security/web/img/icons/silk/group.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,947 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-security-2.3.4.jar!/org/geoserver/security/web/img/icons/silk/shield.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,948 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:16:23,950 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.data.DataSecurityPage/null/img/icons/silk/database_key.png]
2013-10-31 11:16:23,950 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.service.ServiceAccessRulePage/null/img/icons/silk/shape_square_key.png]
2013-10-31 11:16:23,950 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/logo.png]
2013-10-31 11:16:23,951 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/logo.png]
2013-10-31 11:16:23,951 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.service.ServiceAccessRulePage/null/img/icons/silk/shape_square_key.png]
2013-10-31 11:16:23,951 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.data.DataSecurityPage/null/img/icons/silk/database_key.png]
2013-10-31 11:16:23,952 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.service.ServiceAccessRulePage/null/img/icons/silk/shape_square_key.png]
2013-10-31 11:16:23,953 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/logo.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,953 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-security-2.3.4.jar!/org/geoserver/security/web/img/icons/silk/shape_square_key.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,953 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-security-2.3.4.jar!/org/geoserver/security/web/img/icons/silk/database_key.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,954 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:16:23,966 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/button-gradient.png]
2013-10-31 11:16:23,966 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/door_out.png]
2013-10-31 11:16:23,966 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/main-bg.png]
2013-10-31 11:16:23,967 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/main-bg.png]
2013-10-31 11:16:23,967 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/door_out.png]
2013-10-31 11:16:23,968 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/button-gradient.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,968 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/main-bg.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,968 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/door_out.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,969 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:16:23,972 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/main-wrap-bg.png]
2013-10-31 11:16:23,972 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/page-bg.png]
2013-10-31 11:16:23,972 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/page-header-bg.png]
2013-10-31 11:16:23,973 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/page-bg.png]
2013-10-31 11:16:23,973 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/page-header-bg.png]
2013-10-31 11:16:23,973 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/main-wrap-bg.png]
2013-10-31 11:16:23,974 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/main-wrap-bg.png]
2013-10-31 11:16:23,974 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/page-header-bg.png]
2013-10-31 11:16:23,975 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/page-bg.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,975 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/main-wrap-bg.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,975 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/page-header-bg.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,976 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:16:23,987 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/ajax-loader.gif]
2013-10-31 11:16:23,989 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/ajax-loader.gif to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:16:23,989 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:17:05,800 DEBUG [geoserver.security] - Start searching for expired authentication tokens
2013-10-31 11:17:05,800 DEBUG [geoserver.security] - Number of expired authentication tokens found: 0
2013-10-31 11:17:05,800 DEBUG [geoserver.security] - End searching for expired authentication tokens
2013-10-31 11:18:05,810 DEBUG [geoserver.security] - Start searching for expired authentication tokens
2013-10-31 11:18:05,810 DEBUG [geoserver.security] - Number of expired authentication tokens found: 0
2013-10-31 11:18:05,810 DEBUG [geoserver.security] - End searching for expired authentication tokens
2013-10-31 11:19:05,820 DEBUG [geoserver.security] - Start searching for expired authentication tokens
2013-10-31 11:19:05,820 DEBUG [geoserver.security] - Number of expired authentication tokens found: 0
2013-10-31 11:19:05,820 DEBUG [geoserver.security] - End searching for expired authentication tokens
2013-10-31 11:20:05,830 DEBUG [geoserver.security] - Start searching for expired authentication tokens
2013-10-31 11:20:05,830 DEBUG [geoserver.security] - Number of expired authentication tokens found: 0
2013-10-31 11:20:05,830 DEBUG [geoserver.security] - End searching for expired authentication tokens
2013-10-31 11:20:52,188 DEBUG [geoserver.security] - preAuthenticatedPrincipal = c2cs.svc@anonymised.com, trying to authenticate
2013-10-31 11:20:52,188 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - Converted URL to lowercase, from: '/rest/workspaces'; to: '/rest/workspaces' and httpMethod= POST
2013-10-31 11:20:52,189 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /** methodList= [GET]
2013-10-31 11:20:52,189 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/workspaces'; antPath is /**; matchedPath=true; matchedMethods=false
2013-10-31 11:20:52,189 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /** methodList= [POST, DELETE, PUT]
2013-10-31 11:20:52,189 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/workspaces'; antPath is /**; matchedPath=true; matchedMethods=true
2013-10-31 11:20:52,189 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - returning ADMIN
2013-10-31 11:20:52,190 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/rest/workspaces/]
2013-10-31 11:20:52,196 DEBUG [org.geoserver] - Thread 12 locking in mode WRITE
2013-10-31 11:20:52,197 DEBUG [org.geoserver] - Thread 12 got the lock in mode WRITE
2013-10-31 11:20:52,213 DEBUG [org.geoserver] - Thread 12 releasing the lock in mode WRITE
2013-10-31 11:20:52,213 ERROR [geoserver.rest] - :Workspace named 'CADRG' already exists.
org.geoserver.rest.RestletException: java.lang.IllegalArgumentException: Workspace named 'CADRG' already exists.
                at org.geoserver.rest.ReflectiveResource.handleException(ReflectiveResource.java:325)
                at org.geoserver.rest.ReflectiveResource.handlePost(ReflectiveResource.java:123)
                at org.restlet.Finder.handle(Finder.java:296)
                at org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:37)
                at org.restlet.Filter.doHandle(Filter.java:105)
                at org.restlet.Filter.handle(Filter.java:134)
                at org.restlet.Router.handle(Router.java:444)
                at org.geoserver.rest.RESTDispatcher$1.handle(RESTDispatcher.java:204)
                at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
                at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:86)
                at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
                at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
                at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
                at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:789)
                at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
                at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
                at weblogic.servlet.internal.StubSecurityHelper$ServletServiceAction.run(StubSecurityHelper.java:227)
                at weblogic.servlet.internal.StubSecurityHelper.invokeServlet(StubSecurityHelper.java:125)
                at weblogic.servlet.internal.ServletStubImpl.execute(ServletStubImpl.java:301)
                at weblogic.servlet.internal.TailFilter.doFilter(TailFilter.java:26)
                at weblogic.servlet.internal.FilterChainImpl.doFilter(FilterChainImpl.java:60)
                at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:27)
                at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
                at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
                at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
                at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
                at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
                at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
                at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
                at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
                at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
                at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
                at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
                at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
                at org.geoserver.security.filter.GeoServerPreAuthenticationFilter.doFilter(GeoServerPreAuthenticationFilter.java:74)
                at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
                at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
                at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
                at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:134)
                at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
                at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
                at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:75)
                at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:48)
                at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:47)
                at weblogic.servlet.internal.WebAppServletContext$ServletInvocationAction.wrapRun(WebAppServletContext.java:3739)
                at weblogic.servlet.internal.WebAppServletContext$ServletInvocationAction.run(WebAppServletContext.java:3705)
                at weblogic.security.acl.internal.AuthenticatedSubject.doAs(AuthenticatedSubject.java:321)
                at weblogic.security.service.SecurityManager.runAs(SecurityManager.java:120)
                at weblogic.servlet.internal.WebAppServletContext.securedExecute(WebAppServletContext.java:2282)
                at weblogic.servlet.internal.WebAppServletContext.execute(WebAppServletContext.java:2181)
                at weblogic.servlet.internal.ServletRequestImpl.run(ServletRequestImpl.java:1491)
                at weblogic.work.ExecuteThread.execute(ExecuteThread.java:256)
                at weblogic.work.ExecuteThread.run(ExecuteThread.java:221)
Caused by: java.lang.IllegalArgumentException: Workspace named 'CADRG' already exists.
                at org.geoserver.catalog.impl.CatalogImpl.validate(CatalogImpl.java:1144)
                at org.geoserver.catalog.impl.CatalogImpl.add(CatalogImpl.java:1115)
                at org.geoserver.security.SecureCatalogImpl.add(SecureCatalogImpl.java:1176)
                at org.geoserver.catalog.impl.AbstractFilteredCatalog.add(AbstractFilteredCatalog.java:619)
                at org.geoserver.catalog.impl.AbstractCatalogDecorator.add(AbstractCatalogDecorator.java:585)
                at org.geoserver.catalog.rest.WorkspaceResource.handleObjectPost(WorkspaceResource.java:93)
                at org.geoserver.rest.ReflectiveResource.handlePost(ReflectiveResource.java:120)
                ... 70 more
2013-10-31 11:20:52,216 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:20:52,260 DEBUG [geoserver.security] - preAuthenticatedPrincipal = c2cs.svc@anonymised.com, trying to authenticate
2013-10-31 11:20:52,260 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - Converted URL to lowercase, from: '/rest/workspaces/cadrg/coveragestores'; to: '/rest/workspaces/cadrg/coveragestores' and httpMethod= POST
2013-10-31 11:20:52,260 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /** methodList= [GET]
2013-10-31 11:20:52,261 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/workspaces/cadrg/coveragestores'; antPath is /**; matchedPath=true; matchedMethods=false
2013-10-31 11:20:52,261 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /** methodList= [POST, DELETE, PUT]
2013-10-31 11:20:52,261 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/workspaces/cadrg/coveragestores'; antPath is /**; matchedPath=true; matchedMethods=true
2013-10-31 11:20:52,261 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - returning ADMIN
2013-10-31 11:20:52,261 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/rest/workspaces/CADRG/coveragestores]
2013-10-31 11:20:52,262 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/rest/workspaces/CADRG/coveragestores]
2013-10-31 11:20:52,270 DEBUG [org.geoserver] - Thread 48 locking in mode WRITE
2013-10-31 11:20:52,270 DEBUG [org.geoserver] - Thread 48 got the lock in mode WRITE
2013-10-31 11:20:52,301 INFO [org.geoserver] - Loaded store 'JNC', enabled
2013-10-31 11:20:52,306 DEBUG [org.geoserver] - Thread 48 releasing the lock in mode WRITE
2013-10-31 11:20:52,306 ERROR [geoserver.rest] - :Store 'JNC' already exists in workspace 'CADRG'
2013-10-31 11:20:52,307 ERROR [geoserver.rest] -
org.geoserver.rest.RestletException: java.lang.IllegalArgumentException: Store 'JNC' already exists in workspace 'CADRG'
Caused by: java.lang.IllegalArgumentException: Store 'JNC' already exists in workspace 'CADRG'
                at org.geoserver.catalog.impl.CatalogImpl.validate(CatalogImpl.java:176)
                at org.geoserver.catalog.impl.CatalogImpl.add(CatalogImpl.java:149)
                at org.geoserver.security.SecureCatalogImpl.add(SecureCatalogImpl.java:1151)
                at org.geoserver.catalog.impl.AbstractFilteredCatalog.add(AbstractFilteredCatalog.java:595)
                at org.geoserver.catalog.impl.AbstractCatalogDecorator.add(AbstractCatalogDecorator.java:79)
                at org.geoserver.catalog.rest.CoverageStoreResource.handleObjectPost(CoverageStoreResource.java:66)
                ... 70 more
2013-10-31 11:20:52,309 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:20:52,356 DEBUG [geoserver.security] - preAuthenticatedPrincipal = c2cs.svc@anonymised.com, trying to authenticate
2013-10-31 11:20:52,356 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - Converted URL to lowercase, from: '/rest/workspaces/cadrg/coveragestores/jnc/coverages'; to: '/rest/workspaces/cadrg/coveragestores/jnc/coverages' and httpMethod= POST
2013-10-31 11:20:52,356 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /** methodList= [GET]
2013-10-31 11:20:52,357 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/workspaces/cadrg/coveragestores/jnc/coverages'; antPath is /**; matchedPath=true; matchedMethods=false
2013-10-31 11:20:52,357 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /** methodList= [POST, DELETE, PUT]
2013-10-31 11:20:52,357 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/workspaces/cadrg/coveragestores/jnc/coverages'; antPath is /**; matchedPath=true; matchedMethods=true
2013-10-31 11:20:52,357 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - returning ADMIN
2013-10-31 11:20:52,357 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/rest/workspaces/CADRG/coveragestores/JNC/coverages]
2013-10-31 11:20:52,358 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/rest/workspaces/CADRG/coveragestores/JNC/coverages]
2013-10-31 11:20:52,361 DEBUG [org.geoserver] - Thread 12 locking in mode WRITE
2013-10-31 11:20:52,362 DEBUG [org.geoserver] - Thread 12 got the lock in mode WRITE
2013-10-31 11:20:52,379 INFO [org.geoserver] - Loaded coverage 'JNC', disabled
2013-10-31 11:20:52,394 DEBUG [geoserver.config] - Persisting coverage JNC
2013-10-31 11:20:52,407 DEBUG [geoserver.config] - Persisted $Proxy117 to /h/data/global/GEOSRV/data/workspaces/CADRG/JNC/JNC/coverage.xml
2013-10-31 11:20:52,415 DEBUG [geoserver.config] - Persisted $Proxy125 to /h/data/global/GEOSRV/data/global.xml
2013-10-31 11:20:52,415 DEBUG [catalog.impl] - Warning, some code is setting the LayerInfo name, but that will be ignored
2013-10-31 11:20:52,423 DEBUG [geoserver.config] - Persisting layer JNC
2013-10-31 11:20:52,426 DEBUG [geoserver.config] - Persisted $Proxy119 to /h/data/global/GEOSRV/data/workspaces/CADRG/JNC/JNC/layer.xml
2013-10-31 11:20:52,427 DEBUG [gwc.layer] - Handling add event: LayerInfoImpl[JNC, resource:CoverageInfoImpl[JNC]]
2013-10-31 11:20:52,447 DEBUG [gwc.layer] - Depersisting GeoServerTileLayerInfo from /h/data/global/GEOSRV/data/gwc-layers/LayerInfoImpl--2fcd5d73_142099d6317_-7fee.xml.tmp
2013-10-31 11:20:52,454 DEBUG [geoserver.config] - Persisted $Proxy125 to /h/data/global/GEOSRV/data/global.xml
2013-10-31 11:20:52,454 INFO [catalog.rest] - POST coverage JNC,JNC
2013-10-31 11:20:52,455 DEBUG [org.geoserver] - Thread 12 releasing the lock in mode WRITE
2013-10-31 11:20:52,456 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:21:05,840 DEBUG [geoserver.security] - Start searching for expired authentication tokens
2013-10-31 11:21:05,840 DEBUG [geoserver.security] - Number of expired authentication tokens found: 0
2013-10-31 11:21:05,840 DEBUG [geoserver.security] - End searching for expired authentication tokens
2013-10-31 11:21:38,916 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2013-10-31 11:21:38,917 DEBUG [org.geoserver] - Thread 45 locking in mode WRITE
2013-10-31 11:21:38,917 DEBUG [org.geoserver] - Thread 45 got the lock in mode WRITE
2013-10-31 11:21:38,934 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/admin/LogPage.html to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:38,941 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:38,943 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:38,946 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/geoserver.css to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:38,948 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:38,951 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:38,953 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:39,114 DEBUG [org.geoserver] - Thread 45 releasing the lock in mode WRITE
2013-10-31 11:21:39,114 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html; charset=UTF-8
2013-10-31 11:21:39,122 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:21:48,509 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/screen.css]
2013-10-31 11:21:48,510 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/screen.css]
2013-10-31 11:21:48,512 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,512 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:21:48,608 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/favicon.ico]
2013-10-31 11:21:48,609 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/favicon.ico]
2013-10-31 11:21:48,612 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/favicon.ico to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,612 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2013-10-31 11:21:48,612 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/print.css]
2013-10-31 11:21:48,612 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2013-10-31 11:21:48,613 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/print.css]
2013-10-31 11:21:48,613 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2013-10-31 11:21:48,613 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:21:48,613 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2013-10-31 11:21:48,614 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/print.css]
2013-10-31 11:21:48,614 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2013-10-31 11:21:48,614 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2013-10-31 11:21:48,615 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2013-10-31 11:21:48,615 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2013-10-31 11:21:48,616 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,616 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,616 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/geoserver.css to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,616 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2013-10-31 11:21:48,617 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2013-10-31 11:21:48,617 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:21:48,619 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,619 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2013-10-31 11:21:48,620 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2013-10-31 11:21:48,620 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:21:48,623 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-demo-2.3.4.jar!/org/geoserver/web/demo/mappreview_keyshortcut.js to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,623 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:21:48,694 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2013-10-31 11:21:48,694 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2013-10-31 11:21:48,694 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2013-10-31 11:21:48,694 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2013-10-31 11:21:48,695 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2013-10-31 11:21:48,695 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2013-10-31 11:21:48,695 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2013-10-31 11:21:48,695 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2013-10-31 11:21:48,696 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2013-10-31 11:21:48,696 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2013-10-31 11:21:48,696 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2013-10-31 11:21:48,696 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2013-10-31 11:21:48,697 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/help.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,698 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/page_white_text.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,697 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/vcard.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,697 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/server_error.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,698 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:21:48,702 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/null/img/icons/geosilk/map.png]
2013-10-31 11:21:48,702 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.workspace.WorkspacePage/null/null/img/icons/silk/folder.png]
2013-10-31 11:21:48,703 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.workspace.WorkspacePage/null/null/img/icons/silk/folder.png]
2013-10-31 11:21:48,703 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/null/img/icons/geosilk/map.png]
2013-10-31 11:21:48,704 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/folder.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,704 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/geosilk/map.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,705 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:21:48,720 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.data.StylePage/palette.png]
2013-10-31 11:21:48,720 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layergroup.LayerGroupPage/null/null/img/icons/silk/layers.png]
2013-10-31 11:21:48,720 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layer.LayerPage/null/null/img/icons/silk/picture_empty.png]
2013-10-31 11:21:48,720 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2013-10-31 11:21:48,721 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layer.LayerPage/null/null/img/icons/silk/picture_empty.png]
2013-10-31 11:21:48,721 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layergroup.LayerGroupPage/null/null/img/icons/silk/layers.png]
2013-10-31 11:21:48,721 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2013-10-31 11:21:48,721 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.data.StylePage/palette.png]
2013-10-31 11:21:48,722 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layergroup.LayerGroupPage/null/null/img/icons/silk/layers.png]
2013-10-31 11:21:48,722 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layer.LayerPage/null/null/img/icons/silk/picture_empty.png]
2013-10-31 11:21:48,722 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2013-10-31 11:21:48,723 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.data.StylePage/palette.png]
2013-10-31 11:21:48,723 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2013-10-31 11:21:48,724 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-wms-2.3.4.jar!/org/geoserver/wms/web/data/palette.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,724 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/picture_empty.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,724 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/layers.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,724 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/database.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,725 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:21:48,727 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.WMSAdminPage/server_map.png]
2013-10-31 11:21:48,727 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wfs.web.WFSAdminPage/server_vector.png]
2013-10-31 11:21:48,728 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wfs.web.WFSAdminPage/server_vector.png]
2013-10-31 11:21:48,728 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.WMSAdminPage/server_map.png]
2013-10-31 11:21:48,729 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-wms-2.3.4.jar!/org/geoserver/wms/web/server_map.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,729 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-wfs-2.3.4.jar!/org/geoserver/wfs/web/server_vector.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,730 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:21:48,744 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.GlobalSettingsPage/null/img/icons/silk/server.png]
2013-10-31 11:21:48,744 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.CoverageAccessPage/null/img/icons/silk/cog_photo.png]
2013-10-31 11:21:48,744 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.JAIPage/null/img/icons/silk/cog_photo.png]
2013-10-31 11:21:48,744 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wcs.web.WCSAdminPage/server_raster.png]
2013-10-31 11:21:48,745 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.JAIPage/null/img/icons/silk/cog_photo.png]
2013-10-31 11:21:48,745 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.CoverageAccessPage/null/img/icons/silk/cog_photo.png]
2013-10-31 11:21:48,745 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.GlobalSettingsPage/null/img/icons/silk/server.png]
2013-10-31 11:21:48,745 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wcs.web.WCSAdminPage/server_raster.png]
2013-10-31 11:21:48,746 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.GlobalSettingsPage/null/img/icons/silk/server.png]
2013-10-31 11:21:48,746 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wcs.web.WCSAdminPage/server_raster.png]
2013-10-31 11:21:48,747 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/server.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,747 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-wcs-2.3.4.jar!/org/geoserver/wcs/web/server_raster.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,747 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,748 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:21:48,750 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.GWCSettingsPage/geowebcache-16.png]
2013-10-31 11:21:48,750 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.layer.CachedLayersPage/null/tilelayer.png]
2013-10-31 11:21:48,751 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.GWCSettingsPage/geowebcache-16.png]
2013-10-31 11:21:48,751 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.layer.CachedLayersPage/null/tilelayer.png]
2013-10-31 11:21:48,752 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-gwc-2.3.4.jar!/org/geoserver/gwc/web/tilelayer.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,752 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-gwc-2.3.4.jar!/org/geoserver/gwc/web/geowebcache-16.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,753 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:21:48,766 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/wrench.png]
2013-10-31 11:21:48,766 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.gridset.GridSetsPage/null/gridset.png]
2013-10-31 11:21:48,767 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.auth.AuthenticationPage/null/img/icons/silk/shield.png]
2013-10-31 11:21:48,766 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.diskquota.DiskQuotaSettingsPage/null/diskquota.png]
2013-10-31 11:21:48,767 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.gridset.GridSetsPage/null/gridset.png]
2013-10-31 11:21:48,767 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/wrench.png]
2013-10-31 11:21:48,767 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.diskquota.DiskQuotaSettingsPage/null/diskquota.png]
2013-10-31 11:21:48,768 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.diskquota.DiskQuotaSettingsPage/null/diskquota.png]
2013-10-31 11:21:48,768 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/wrench.png]
2013-10-31 11:21:48,768 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.auth.AuthenticationPage/null/img/icons/silk/shield.png]
2013-10-31 11:21:48,768 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.gridset.GridSetsPage/null/gridset.png]
2013-10-31 11:21:48,770 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-security-2.3.4.jar!/org/geoserver/security/web/img/icons/silk/shield.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,770 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/wrench.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,770 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-gwc-2.3.4.jar!/org/geoserver/gwc/web/diskquota.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,770 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-gwc-2.3.4.jar!/org/geoserver/gwc/web/gridset.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,771 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:21:48,773 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.UserGroupRoleServicesPage/img/icons/silk/group.png]
2013-10-31 11:21:48,773 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.passwd.PasswordPage/null/img/icons/silk/lock.png]
2013-10-31 11:21:48,774 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.passwd.PasswordPage/null/img/icons/silk/lock.png]
2013-10-31 11:21:48,774 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.UserGroupRoleServicesPage/img/icons/silk/group.png]
2013-10-31 11:21:48,776 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-security-2.3.4.jar!/org/geoserver/security/web/img/icons/silk/lock.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,776 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-security-2.3.4.jar!/org/geoserver/security/web/img/icons/silk/group.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,776 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:21:48,789 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.data.DataSecurityPage/null/img/icons/silk/database_key.png]
2013-10-31 11:21:48,789 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.service.ServiceAccessRulePage/null/img/icons/silk/shape_square_key.png]
2013-10-31 11:21:48,789 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/ajax-loader.gif]
2013-10-31 11:21:48,790 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.service.ServiceAccessRulePage/null/img/icons/silk/shape_square_key.png]
2013-10-31 11:21:48,790 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.data.DataSecurityPage/null/img/icons/silk/database_key.png]
2013-10-31 11:21:48,790 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/ajax-loader.gif]
2013-10-31 11:21:48,791 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.service.ServiceAccessRulePage/null/img/icons/silk/shape_square_key.png]
2013-10-31 11:21:48,791 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/ajax-loader.gif]
2013-10-31 11:21:48,791 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.data.DataSecurityPage/null/img/icons/silk/database_key.png]
2013-10-31 11:21:48,792 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-security-2.3.4.jar!/org/geoserver/security/web/img/icons/silk/shape_square_key.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,792 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/ajax-loader.gif to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,792 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-security-2.3.4.jar!/org/geoserver/security/web/img/icons/silk/database_key.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:48,793 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:21:49,669 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/main-bg.png]
2013-10-31 11:21:49,669 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/button-gradient.png]
2013-10-31 11:21:49,669 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/main-wrap-bg.png]
2013-10-31 11:21:49,669 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/logo.png]
2013-10-31 11:21:49,670 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/main-wrap-bg.png]
2013-10-31 11:21:49,670 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/button-gradient.png]
2013-10-31 11:21:49,670 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/main-bg.png]
2013-10-31 11:21:49,670 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/logo.png]
2013-10-31 11:21:49,671 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/logo.png]
2013-10-31 11:21:49,671 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/button-gradient.png]
2013-10-31 11:21:49,671 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/main-wrap-bg.png]
2013-10-31 11:21:49,671 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/main-bg.png]
2013-10-31 11:21:49,672 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/main-bg.png]
2013-10-31 11:21:49,673 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/main-bg.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:49,673 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/logo.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:49,673 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/button-gradient.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:49,673 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/main-wrap-bg.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:49,674 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:21:49,676 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/door_out.png]
2013-10-31 11:21:49,676 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/page-bg.png]
2013-10-31 11:21:49,677 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/door_out.png]
2013-10-31 11:21:49,677 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/page-bg.png]
2013-10-31 11:21:49,678 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/page-bg.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:49,678 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/icons/silk/door_out.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:49,679 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:21:49,692 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/page-header-bg.png]
2013-10-31 11:21:49,693 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/page-header-bg.png]
2013-10-31 11:21:49,695 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/img/page-header-bg.png to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:21:49,695 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:22:05,850 DEBUG [geoserver.security] - Start searching for expired authentication tokens
2013-10-31 11:22:05,850 DEBUG [geoserver.security] - Number of expired authentication tokens found: 0
2013-10-31 11:22:05,850 DEBUG [geoserver.security] - End searching for expired authentication tokens
2013-10-31 11:22:13,524 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2013-10-31 11:22:13,525 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2013-10-31 11:22:13,528 DEBUG [org.geoserver] - Thread 12 locking in mode WRITE
2013-10-31 11:22:13,528 DEBUG [org.geoserver] - Thread 12 got the lock in mode WRITE
2013-10-31 11:22:13,551 DEBUG [org.geoserver] - Thread 12 releasing the lock in mode WRITE
2013-10-31 11:22:13,552 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2013-10-31 11:22:13,614 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2013-10-31 11:22:13,615 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2013-10-31 11:22:13,615 DEBUG [org.geoserver] - Thread 19 locking in mode WRITE
2013-10-31 11:22:13,615 DEBUG [org.geoserver] - Thread 19 got the lock in mode WRITE
2013-10-31 11:22:13,624 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:22:13,627 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:22:13,630 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/geoserver.css to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:22:13,633 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:22:13,636 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI scheme is not "file"), falling back to the inputstream for polling
2013-10-31 11:22:13,639 DEBUG [geoserver.web] - cannot convert url: zip:/h/data/local/BEAWLS/data/nodemanager/enclaveDefaultDomain/servers/enclaveDefDom_GEOSRVClusManSvr1/tmp/_WL_user/GeoServer/hriivl/war/WEB-INF/lib/web-core-2.3.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI scheme is not "file"), falling back to the inputstream for polling
