The GeoServer team is pleased to announce the release of GeoServer 2.3.4:
Downloads (zip, war, dmg and exe) are listed on the GeoServer 2.3.4 page along with documentation and extensions.
- This release includes and is made in conjunction with GeoTools 9.4.
Thanks to Envitia for allowing Ian the time to make the release.
Migrated CSS module to extensions section (GEOS-5845)
Several improvements and bug-fixes in WMS and Security sub-systems.
Thanks to Frank Gasdorf managing Transifex GeoServer Translation Teams
More details can be found in the GeoServer 2.3.4 Release Notes.
Ian Turton
Is this release tested against Java 7?
Or are already the previous ones Java7 compliant?
- mika -
28.7.2013 16:23, Ian Turton kirjoitti:
The GeoServer team is pleased to announce the release of GeoServer 2.3.4 <http://geoserver.org/display/GEOS/GeoServer+2.3.4>:
* Downloads (zip
<http://downloads.sourceforge.net/geoserver/geoserver-2.3.4-bin.zip>,
war
<http://downloads.sourceforge.net/geoserver/geoserver-2.3.4-war.zip>,
dmg
<http://downloads.sourceforge.net/geoserver/geoserver-2.3.4.dmg> and
exe
<http://downloads.sourceforge.net/geoserver/geoserver-2.3.4.exe>\)
<http://geoserver.org/display/GEOS/GeoServer+2.3.4> page along
o This release includes and is made in conjunction with GeoTools
9.4.
* Thanks to Envitia <http://www.envitia.com/> for allowing Ian the
* Migrated CSS module to extensions section (GEOS-5845
<http://jira.codehaus.org/browse/GEOS-5845>\)
<https://www.transifex.com/projects/p/geoserver_23x/>
* Several improvements and bug-fixes in WMS and Security sub-systems.
* Thanks to Frank Gasdorf managing Transifex GeoServer Translation
Teams <https://www.transifex.com/projects/p/geoserver_23x>
o contributed initial language support (almost) complete for
Dutch
<https://www.transifex.com/projects/p/geoserver_23x/language/nl/members/> and
Chinese
<https://www.transifex.com/projects/p/geoserver_23x/language/zh/members/> (GEOS-5926
<http://jira.codehaus.org/browse/GEOS-5926> + GEOS-5924
<http://jira.codehaus.org/browse/GEOS-5924>\)
o updated translations for Korean
<https://www.transifex.com/projects/p/geoserver_23x/language/ko/members/> and
German
<https://www.transifex.com/projects/p/geoserver_23x/language/de/members/> (GEOS-5925
<https://jira.codehaus.org/browse/GEOS-5925> + GEOS-5927
<https://jira.codehaus.org/browse/GEOS-5927>\).
More details can be found in the GeoServer 2.3.4 Release Notes <http://jira.codehaus.org/secure/ReleaseNote.jspa?projectId=10311&version=19346>\.
Ian Turton
See everything from the browser to the database with AppDynamics
Get end-to-end visibility with application monitoring from AppDynamics
Isolate bottlenecks and diagnose root cause in seconds.
Start your free trial of AppDynamics Pro today!
http://pubads.g.doubleclick.net/gampad/clk?id=48808831&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Nope, none of them are, at least officially, our whole build and test
infrastructure uses
Java 6.
That said, I do run GeoServer on Java 7 when I start it for tests during
development,
so while not as well tested, nothing major seems to break.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Our security consultant takes Java 6 as a security risk and recommends using latest Java 7 if possible. Having certification proofed can cause minor problems if using Java 6. On the other hand, if using Java7 breaks Geoserver or causes any problems, the total outcome could be plus-minus-zero..
- mika -
28.7.2013 19:27, Andrea Aime kirjoitti:
On Sun, Jul 28, 2013 at 3:43 PM, Mika M Lehtonen <mika@anonymised.com <mailto:mika@anonymised.com>> wrote:
Nope, none of them are, at least officially, our whole build and test infrastructure uses
Java 6.
That said, I do run GeoServer on Java 7 when I start it for tests during development,
Ing. Andrea Aime
@geowolf
Technical Lead
In our group and in a few others I know, Java7 is the only option, due to security. Either use Java7 or don’t use GeoServer. We’ve been using 7 and Tomcat7 for a year now with no problems.
John
On Sunday, July 28, 2013, Mika M Lehtonen <mika@anonymised.com> wrote:
Our security consultant takes Java 6 as a security risk and recommends using latest Java 7 if possible. Having certification proofed can cause minor problems if using Java 6. On the other hand, if using Java7 breaks Geoserver or causes any problems, the total outcome could be plus-minus-zero…
On Sun, Jul 28, 2013 at 3:43 PM, Mika M Lehtonen <mika@anonymised.com> wrote:
Java 6.
Ing. Andrea Aime
@geowolf
Technical Lead
John Callahan
Research Scientist
Delaware Geological Survey
University of Delaware
http://www.dgs.udel.edu
john.callahan@anonymised.com
On Sun, Jul 28, 2013 at 7:14 PM, John Callahan <john.callahan@anonymised.com>wrote:
security. Either use Java7 or don't use GeoServer. We've been using 7 and
We would love to officially support GeoServer on Java 7 as well... it's
really just a matter of resources,
right now we don't have enough of them to support a Java 7 specific build
server, but more importantly,
not enough developer time to look into Java 7 specific issues with any
timeliness.
So, who is going to step up and help? Many things can be done, but we need
to find the people that
help making them reality.
Otherwise we are going to have to wait for Java 7 to become the one and
only supported version,
at which point GeoServer will not run on Java 6 anymore. Honestly, I
haven't seen any enterprise
related software (e..g, Spring, Hibernate) make that move yet.
Andra
Ing. Andrea Aime
@geowolf
Technical Lead
Yeah,
I understand and my question wasn't ment to be any sort of critisism though I don't even belive it was taken that way. I would love to help you but as an ordinary software developer I do not have much power in our company to make this urge to realize.
Maybe we could collect a list of things not working with Java 7?
If I recall right, the xstream-jar isn't working with 7. Am I right? Some more?
- mika -
28.7.2013 20:25, Andrea Aime kirjoitti:
On Sun, Jul 28, 2013 at 7:14 PM, John Callahan <john.callahan@anonymised.com <mailto:john.callahan@anonymised.com>> wrote:
due to security. Either use Java7 or don't use GeoServer. We've
We would love to officially support GeoServer on Java 7 as well... it's really just a matter of resources,
right now we don't have enough of them to support a Java 7 specific build server, but more importantly,
not enough developer time to look into Java 7 specific issues with any timeliness.
So, who is going to step up and help? Many things can be done, but we need to find the people that
Otherwise we are going to have to wait for Java 7 to become the one and only supported version,
at which point GeoServer will not run on Java 6 anymore. Honestly, I haven't seen any enterprise
Andra
Ing. Andrea Aime
@geowolf
Technical Lead
On Sun, Jul 28, 2013 at 8:15 PM, Mika M Lehtonen <mika@anonymised.com>wrote:
Yeah,
more?
As far as I know GeoServer 2.3.x has an up to date xstream that works fine
with java 7.
At the moment I can't remember java 7 specific issues, but it's hard to
know what works and
what does not without a build server infrastructure on Java 7 (see my
gs-devel thread
about using Travis CI, which would offer a basic Java 7 build server for
free)
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Ian,
None of the extensions linked to from http://geoserver.org/display/GEOS/Stable work. In all instances sourceforge is giving something like:
The “/GeoServer/2.3.4/geo…trol-flow-plugin.zip” file could not be found or is not available. Please select another file.
The files themselves do exist though:
http://sourceforge.net/projects/geoserver/files/GeoServer%20Extensions/2.3.4/
Jonathan
Ian Turton
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
