[Geoserver-users] GeoServer 2.4.1 Installation is not running
Hello,
We have had an issue with the migration of 2.3.2 to a 2.4.0 series.
The version 2.4 did not correctly transform the context.xml in the security subdirectory.
We copied the context.xml from the default data directory of Geoserver, replace this in the 2.4 version
and restarted geoserver.
Now geoserver started, we redefined part of the security set-up and the version was running.
Best regards,
Eric
-----Oorspronkelijk bericht-----
Afzender: Toni Müller tonimueller.unihalle@anonymised.com
Verstuurd: Woensdag 23 Oktober 2013 19:14
Aan: geoserver-users@anonymised.comorge.net
Onderwerp: [Geoserver-users] GeoServer 2.4.1 Installation is not running
Hello GeoServer Contributors,
Today I made an update from a successfully running version 2.3.2 to the new one 2.4.1.
I installed GeoServer 2.4.1 with the Windows Installer.
OS Win7 x64
Oracle/Java SE 7u45 (Build 1.7.0_45-b18)
Now, GeoServer isn’t running.
The following error message shows during an attempt to open geoserver url…
“HTTP ERROR: 404 NOT_FOUND RequestURI=/geoserver”
Note: I have restared the Start/Stop several times & also restarted the PC.
HTTP ERROR: 404
NOT_FOUND
RequestURI=/geoserver/
The Java RE update from jre-7u25-windows-x64 to jre-7u45-windows-x64
There is no GeoServer entry in windows Control Panel → Administrative → Services.
There is no log file in the GeoServer installation folder.
You can find the report from GeoServer start in the attachment.
Can anybody help me?
Thank you for your support.
Best regards,
Toni
October Webinars: Code for Performance
Free Intel webinars can help you accelerate application performance.
Explore tips for MPI, OpenMP, advanced profiling, and more. Get the most from
the latest Intel processors and coprocessors. See abstracts and register >
http://pubads.g.doubleclick.net/gampad/clk?id=60135991&iu=/4140/ostg.clktrk
Geoserver-users mailing list
On Thu, Oct 24, 2013 at 8:23 AM, Eric Smets <eric.smets@anonymised.com> wrote:
Hello,
Did you still have your old security setup? If so, can you open a jira
ticket (jira.codehaus.org) and
attach it to it?
Upgrading should always be seamless, any hiccup is a bug
Our support, Your Success! Visit http://opensdi.geo-solutions.it for more
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
