[Geoserver-users] geoserver 2.5 & viewparams
Today I upgraded our geoserver 2.4 instance to the latest stable version (2.5).
After this upgrade I noticed our wms-requests using viewparams (SQL-view based layers) just return empty tiles. Same happens when you preview the layer using e.g. openlayers. Executing exactly the same request to a geoserver 2.4 instance returns the expected tiles.
I checked the log, no errors are shown. Has something changed with regard to using sql-view based layers & viewparams?
When I looked at the request geoserver is receiving I see that the VIEWPARAMS parameter is interpreted correctly and contains the correct value, but the key itself is upper cased (the value is an integer). The parameter in my SQL view is lower case. Could that be a possible cause?
Kind regards,
Roel
Volg Aquafin op Facebook | Twitter | YouTube | LinkedIN
Disclaimer: zie www.aquafin.be P Denk aan het milieu. Druk deze mail niet onnodig af.
On Wed, Apr 2, 2014 at 7:20 PM, Roel De Nijs <roel.denijs@anonymised.com> wrote:
(2.5).
I'd suggest you to enable "geotools developer logging" and see how queries
are built.
It may be this issue http://jira.codehaus.org/browse/GEOT-4749, if that's
the case, you can
solve it by installing a nightly build (2.5.1 will be released in May)
http://ares.boundlessgeo.com/geoserver/2.5.x/
This is unfortunate, but apparently no one with sql views tested GeoServer
2.5 in the beta, RC1 and RC2
releases (or if they did, they did not care to report the issue).
Meet us at GEO Business 2014! in London! Visit http://goo.gl/fES3aK
for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Enabling “geotools developer logging” showed indeed a wrong srid in the query getting executed (2 instead of 31370). Updating the geoserver instance to the latest nightly build (01-Apr-2014 15:42) solved the issue. Thanks for the swift reply (and solution)!
When I look at the issue you mentioned it appears to be a bug against the jdbc-postgis plugin, but our layers are all created from sqlserver tables (and so we add the sqlserver plugin). So although we use sqlserver layers, the postgis plugin is also used (to perform common stuff) and the sqlserver plugin is used to do translations to/from the sql server dialect. Is this a correct assumption?
Kind regards,
Roel
Van: andrea.aime@anonymised.com [mailto:andrea.aime@anonymised.com] Namens Andrea Aime
Verzonden: woensdag 2 april 2014 20:05
Aan: Roel De Nijs
CC: geoserver-users@lists.sourceforge.net
Onderwerp: Re: [Geoserver-users] geoserver 2.5 & viewparams
On Wed, Apr 2, 2014 at 7:20 PM, Roel De Nijs <roel.denijs@anonymised.com3…> wrote:
I’d suggest you to enable “geotools developer logging” and see how queries are built.
It may be this issue http://jira.codehaus.org/browse/GEOT-4749, if that’s the case, you can
This is unfortunate, but apparently no one with sql views tested GeoServer 2.5 in the beta, RC1 and RC2
Ing. Andrea Aime
@geowolf
Technical Lead
On Thu, Apr 3, 2014 at 4:05 PM, Roel De Nijs <roel.denijs@anonymised.com> wrote:
Enabling "geotools developer logging" showed indeed a wrong srid in the
correct assumption?
Sort of, the common stuff is in the gt-jdbc module, and the issue was in
that module, which is shared among all database implementations.
The issue was opened against postgis because we discovered it against that
installation.
Ing. Andrea Aime
@geowolf
Technical Lead
