[Geoserver-users] GeoServer 2.6-beta released
We are pleased to announce the release of GeoServer 2.6-beta. The download page for 2.6-beta has links to the zip, war, dmg and exe bundles on SourceForge, with source links provided by the 2.6-beta tag on GitHub.
As a development release, 2.6-beta is considered experimental and is provided for testing purposes. This release is not recommended for production (even if you are excited by the new features).
The GeoServer team have identified a few areas where we would like to ask for help. This is your best chance to identify issues early while we still have time to do something about it.
  • Java 7 Testing
  • WFS Cascade
  • Curves support for GML and WMS
  • Advanced projection handling for raster
  • Coverage Views
  • Startup Testing
  • Pluggable Styles
  • Wind barbs and WKT Graphics
  • New Formats and Functionality
For details on testing the above features check out the blog post. A change log is also available from the issue tracker.
GeoServer Team
Re: Blog link referenced for GeoServer 2.6-beta release
Couldn’t see how to create a jira account to comment on the ticket, but in the blog post https://jira.codehaus.org/browse/GEOS-6588 is referenced for this release (specifically Geoserver.app running under JDK 7 on OS X).
I ran into this issue - it’s actually a problem with the plist entry from Oracle -
look at the Info.plist that comes from oracle:
/Library/Java/JavaVirtualMachines/jdk1.7{version}.jdk/Contents/Info.plist
find the JVMCapabilities key - it should look like this:
JVMCapabilities
CommandLine
change it to this:
JVMCapabilities
JNI
BundledApp
WebStart
Applets
CommandLine
alternatively is you start it with a bash script (i.e. java -jar …) it works fine.
On Thu, Jul 24, 2014 at 7:31 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
  • Java 7 Testing
  • WFS Cascade
  • Coverage Views
  • Startup Testing
  • Pluggable Styles
GeoServer Team
Want fast and easy access to all the code in your enterprise? Index and
search up to 200,000 lines of code with a free copy of Black Duck
Code Sight - the same software that powers the world’s largest code
search on Ohloh, the Black Duck Open Hub! Try it now.
http://p.sf.net/sfu/bds
Geoserver-users mailing list
On Fri, Jul 25, 2014 at 2:53 AM, Chris Bennight <chris@anonymised.com> wrote:
Couldn't see how to create a jira account to comment on the ticket, but in
I ran into this issue - it's actually a problem with the plist entry from
Oracle -
<key>JVMCapabilities</key>
                        <array>
                              <string>CommandLine</string>
                        </array>
change it to this:
                        <array>
                              <string>JNI</string>
                              <string>BundledApp</string>
                              <string>WebStart</string>
                              <string>Applets</string>
                        </array>
alternatively is you start it with a bash script (i.e. java -jar .....)
it works fine.
That's good information that we might want to put in the blog, or somewhere
else so that
people interested in testing the 2.6-beta release on OSX can move on.
However, I'm weary of making such kind of global change in the GeoServer
installer,
as this might have un-intended system wide issues (like, applets execution,
where
none was intended, maybe for security reasons).
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thanks Chris, I am trying to understand your comment.
So this is not the plist inside the GeoServer.App, but the plist inside the JDK that is an issue? If we switched to the JRE would this issue be resolved…
I suppose the string “BundledApp” is the entry we actually need added, rather than only command line.
I know some applications (indeed any application that is sold through the Apple store) include a JDK as part of their bundle. We could take this approach for GeoServer but it would be a bit of a hit to download size.
Given that not many people will have installed Java 7 this approach may actually be a good idea?
Jody Garnett
On Thu, Jul 24, 2014 at 5:53 PM, Chris Bennight <chris@anonymised.com> wrote:
JVMCapabilities
CommandLine
change it to this:
JVMCapabilities
JNI
BundledApp
WebStart
Applets
CommandLine
  • Java 7 Testing
  • WFS Cascade
  • Coverage Views
  • Startup Testing
  • Pluggable Styles
GeoServer Team
