[Geoserver-users] Geoserver 2.7.2 couldn't login
Dear Members,
I couldn’'t login through geoserver gui. I couldn’t even open the login page, after loading and loading, it takes me to
http://mydomain/geoserver/j_spring_security_check
And shows a bad request on the page.
Is there any known cause of this problem?
Thank you
Not sure how to answer this one - are you using a default install of 2.7.2 - if so you are the first to report a problem of this nature?
Ideas:
  • are you using the default credentials? Or did you change them like you are supposed to after installation?
  • check your geoserver logs (to confirm what data directory it is using in case you have a previous install)
On 25 September 2015 at 23:22, Wondimagegn Tesfaye <wondim81@anonymised.com> wrote:
Dear Members,
Thank you
Geoserver-users mailing list
Jody Garnett
