[Geoserver-users] geoserver 2.7 publish style
I’m trying to publish a style to geoserver 2.7 via the GeoServerRESTPublisher class.
If I use the publishStyle(File file) API or the publishStyle(String sldBody) I get the following error
17:19:55,192 ERROR [stderr] (http-/0.0.0.0:8080-1) [Fatal Error] :1:1: Content is not allowed in prolog.
17:19:55,193 ERROR [org.geoserver.rest] (http-/0.0.0.0:8080-1) : java.lang.RuntimeException: org.xml.sax.SAXParseException; lineNumber: 1; columnNumber: 1; Content is not allowed in prolog.
at org.geotools.styling.SLDParser.parseSLD(SLDParser.java:438) [gt-main-13.1.jar:]
at org.geoserver.catalog.SLDHandler.parse10(SLDHandler.java:105) [gs-main-2.7.1-nn-1.jar:2.7.1-nn-1]
at org.geoserver.catalog.SLDHandler.parse(SLDHandler.java:97) [gs-main-2.7.1-nn-1.jar:2.7.1-nn-1]
at org.geoserver.catalog.rest.StyleFormat.read(StyleFormat.java:91) [gs-restconfig-2.7.1.jar:2.7.1]
at org.geoserver.rest.format.StreamDataFormat.toObject(StreamDataFormat.java:34) [gs-rest-2.7.1.jar:2.7.1]
at org.geoserver.rest.ReflectiveResource.handlePost(ReflectiveResource.java:118) [gs-rest-2.7.1.jar:2.7.1]
The style xml is below. I formatted it in this email but usually its one long string. I’ve tried trimming for whitespace, removing the encoding, and some other validation checks I’ve found online. I was wondering if anything stands out.
<sld:StyledLayerDescriptor xmlns=“http://www.opengis.net/sld” xmlns:sld=“http://www.opengis.net/sld” xmlns:ogc=“http://www.opengis.net/ogc” xmlns:gml=“http://www.opengis.net/gml” version=“1.0.0”>
sld:NamedLayer
sld:Namenrdb_threshold_132</sld:Name>
sld:UserStyle
sld:Namesurface air temperature</sld:Name>
sld:FeatureTypeStyle
sld:FeatureTypeNameFeature</sld:FeatureTypeName>
sld:Rule
sld:RasterSymbolizer
<sld:ColorMap type=“intervals”>
<sld:ColorMapEntry color=“#FFFF00” opacity=“0.0” quantity=“244.16111108888893” label=“244.16111108888893”/>
<sld:ColorMapEntry color=“#008000” opacity=“1.0” quantity=“283.789” label=“283.789”/>
</sld:ColorMap>
</sld:RasterSymbolizer>
</sld:Rule>
</sld:FeatureTypeStyle>
</sld:UserStyle>
</sld:NamedLayer>
</sld:StyledLayerDescriptor>
Can you try your style in the style editor and confirm it validates?
On 5 June 2015 at 10:31, Bessette-Halsema, Dominique E <Dominique.Bessette@anonymised.com> wrote:
sld:NamedLayer
sld:UserStyle
sld:Rule
</sld:ColorMap>
</sld:Rule>
</sld:UserStyle>
</sld:NamedLayer>
Geoserver-users mailing list
Jody Garnett
I did and it does. I can validate and submit it through the geoserver console.
Dominique Bessette
Software Engineer
General Dynamics Information Technology
Office: 619-881-2748
Jody Garnett
On 5 June 2015 at 10:31, Bessette-Halsema, Dominique E <Dominique.Bessette@…1196…> wrote:
sld:NamedLayer
sld:UserStyle
sld:Rule
</sld:ColorMap>
</sld:Rule>
</sld:UserStyle>
</sld:NamedLayer>
HI Dominique,
do you have by any chance request logging enabled in web.xml (it is not by default, just checking if you did enabled it)?
If so, does your request work if you turn it off?
On Fri, Jun 5, 2015 at 7:31 PM, Bessette-Halsema, Dominique E <Dominique.Bessette@anonymised.com> wrote:
sld:NamedLayer
sld:UserStyle
sld:Rule
</sld:ColorMap>
</sld:Rule>
</sld:UserStyle>
</sld:NamedLayer>
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
I believe it is set to false.
Request Logging Filter
org.geoserver.filters.LoggingFilter
enabled
false
log-request-bodies
false
Dominique Bessette
Software Engineer
HI Dominique,
On Fri, Jun 5, 2015 at 7:31 PM, Bessette-Halsema, Dominique E <Dominique.Bessette@…1196…> wrote:
sld:NamedLayer
sld:UserStyle
sld:Rule
</sld:ColorMap>
</sld:Rule>
</sld:UserStyle>
</sld:NamedLayer>
Ing. Andrea Aime
@geowolf
Technical Lead
